F14325_JENNY-8X1-CY
F14325_JENNY-8X1-CY
    LEDIL(芬兰)
F14325_JENNY-8X1-CY 数据手册
PRODUCT DATASHEET F14325_JENNY-8X1-CY JENNY-8X1-CY ~105° + 105° batwing light distribution for canopy and symmetrical tunnel lighting. Variant with 8 lenses and cable channels on the sides. TECHNICAL SPECIFICATIONS: Dimensions 280.0 x 35.0 mm Height 11.5 mm Fastening glue, pin ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour JENNY-8X1-CY Multi-lens Silicone clear Finish ORDERING INFORMATION: Component F14325_JENNY-8X1-CY » Box size: 398 x 298 x 265 mm Qty in box 180 MOQ MPQ 20 10 Box weight (kg) 9.9 Last update: 06/11/2019 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/10 PRODUCT DATASHEET F14325_JENNY-8X1-CY See also our general installation guide: www.ledil.com/installation_guide Last update: 06/11/2019 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/10 PRODUCT DATASHEET F14325_JENNY-8X1-CY PHOTOMETRIC DATA (MEASURED): LED V10 Gen6 FWHM / FWTM 102.0° / 117.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED V6 Gen6 FWHM / FWTM 110.0° / 123.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED V8 Gen6 FWHM / FWTM 105.0° / 121.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED CLL01x FWHM / FWTM 104.0° / 117.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 06/11/2019 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/10 PRODUCT DATASHEET F14325_JENNY-8X1-CY PHOTOMETRIC DATA (MEASURED): LED CLL02x/CLU02x (LES10) FWHM / FWTM 103.0° / 116.0° Efficiency 93 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED CLU700/701/702 FWHM / FWTM 102.0° / 116.0 + 118.0° Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED CXA/B 13xx FWHM / FWTM 105.0° / 119.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED CXA/B 15xx FWHM / FWTM 106.0° / 119.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 06/11/2019 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/10 PRODUCT DATASHEET F14325_JENNY-8X1-CY PHOTOMETRIC DATA (MEASURED): LED MK-R FWHM / FWTM 105.0° / 120.0° Efficiency 92 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50 FWHM / FWTM 105.0° / 117.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L EZW FWHM / FWTM 103.0° / 119.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5258 FWHM / FWTM 103.0° / 118.0 + 120.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 06/11/2019 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/10 PRODUCT DATASHEET F14325_JENNY-8X1-CY PHOTOMETRIC DATA (MEASURED): LED LUXEON M/MX FWHM / FWTM 104.0° / 120.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NSMx286M FWHM / FWTM 105.0° / 118.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S10 FWHM / FWTM 108.0° / 124.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S8 FWHM / FWTM 102.0° / 118.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 06/11/2019 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/10 PRODUCT DATASHEET F14325_JENNY-8X1-CY PHOTOMETRIC DATA (MEASURED): LED LC003D / LC006D / LC009D / LC013D FWHM / FWTM 106.0° / 121.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED MJT COB LES 6 FWHM / FWTM 111.0° / 130.0° Efficiency 91 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED MJT COB LES 9.8 FWHM / FWTM 105.0° / 128.0° Efficiency 93 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 06/11/2019 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/10 PRODUCT DATASHEET F14325_JENNY-8X1-CY PHOTOMETRIC DATA (SIMULATED): LED V10 Gen7 FWHM / FWTM 97.0 + 100.0° / 107.0 + 110.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED MX-6 FWHM / FWTM 102.0° Efficiency 93 % LEDs/each optic 1 Light colour White Required components: LED XHP50.2 FWHM / FWTM 106.0° / 115.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 100.0° / 110.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 06/11/2019 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/10 PRODUCT DATASHEET F14325_JENNY-8X1-CY PHOTOMETRIC DATA (SIMULATED): LED OSCONIQ P 7070 FWHM / FWTM 100.0° / 106.0° Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED Soleriq S9 FWHM / FWTM 104.0° / 116.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Mini Zenigata (GW6BM) FWHM / FWTM 105.0° Efficiency 93 % LEDs/each optic 1 Light colour White Required components: Last update: 06/11/2019 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/10 PRODUCT DATASHEET F14325_JENNY-8X1-CY GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 06/11/2019 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/10
F14325_JENNY-8X1-CY 价格&库存
很抱歉,暂时无法提供与“F14325_JENNY-8X1-CY”相匹配的价格&库存,您可以联系我们找货
