F15256_HEKLA-SOCKET-D
    LEDIL(芬兰)
F15256_HEKLA-SOCKET-D 数据手册
PRODUCT DATASHEET Konntakt series last update 21/8/2017 DETAILS Product Number F15256_HEKLA-SOCKET-D Family Konntakt Type Base part Color white Diameter 44 mm Height 5,5 mm Style round Optic Material Holder Material PBT Fastening screw Status production ready ROHS Compliant Yes Date Updated 21/08/2017 OPTICAL PROPERTIES Viewing Light Effi- LED Angle Beam ciency cd/lm Connector CXA/B 15xx NA deg - - - December 1st 2017 0:06 Copyright Ledil Oy - Subject to change without prior notice - Page 1/1 Ledil Oy Salorankatu 10 24240 SALO, Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 A B C D E F G H 4 4 89.5 Isometric view (1:1) A 5.5 44 16.2 3.4 (2x) 3 7.5 3 (2x) 16.2 0.95 35 2 C/ A 11.2 C 2 1 COMPONENTS INDEX PRODUCT TYPE F15256_HEKLA-SOCKET-D 1 MATERIAL SOCKET PBT COLOUR/COATING WHITE MECHANICAL DRAWING 1 PRODUCT KONNTAKT-family Notes 1 2 3 4 H PCB or Heat Sink level Led location see marking. Ensure LED fitting, see our web site and/or 3D model for part detail. See installation details FP15502 G Tolerances if not otherwise shown According to DIN ISO 2768-1 Linear measures: Up to 30mm class M, otherwise class C. According to DIN ISO 2768-2 Form and position: class L SCALE 2:1 (1:1) FIRST ANGLE PROJECTION: SIZE This drawing is the property of LEDiL Oy. It may not be reproduced, copied or communicated without a written agreement with LEDiL Oy. A3 B 1 SHEET A 1 NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. GENERAL INFORMATION - Product series especially designed & optimized for series of LEDs. - Special care taken to make light distribution as uniform as possible. Note! Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range.
F15256_HEKLA-SOCKET-D 价格&库存
很抱歉,暂时无法提供与“F15256_HEKLA-SOCKET-D”相匹配的价格&库存,您可以联系我们找货
