FA11108_LMX6-O-90
FA11108_LMX6-O-90
    LEDIL(芬兰)
FA11108_LMX6-O-90 数据手册
PRODUCT DATASHEET LMX6 series Ordering number FA11465 Description FA11465_LMX6-M2 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila Assembly MX-6 Black 21.6 mm 13.3 mm Round PMMA PC Tape Ready FWHM Efficiency cd/lm Gerber File degrees Available FWHM Efficiency cd/lm Gerber File 14 degrees 94 % Available FWHM Efficiency cd/lm Gerber File 18 degrees 92 % Available FWHM Efficiency cd/lm Gerber File 26 degrees 90 % Available Ordering number FA10696 Description FA10696-LMX6-RS Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila Assembly MX-6 Black 21.6 mm 13.3 mm Round PMMA PC Tape Ready Ordering number FA10695 Description FA10695_LMX6-D Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila Assembly MX-6 Black 21.6 mm 13.3 mm Round PMMA PC Tape Ready Ordering number FA10697 Description FA10697-LMX6-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila Assembly MX-6 Black 21.6 mm 13.3 mm Round PMMA PC Tape Ready August 4th 2011 13:40 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET LMX6 series Ordering number FA10698 Description FA10698-LMX6-Rec Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila Assembly MX-6 Black 21.6 mm 13.3 mm Round PMMA PC Tape Ready FWHM Efficiency cd/lm Gerber File 37+26 degrees 84 % Available FWHM Efficiency cd/lm Gerber File 40+19 degrees 91 % Available Ordering number FA11108 Description FA11108_LMX6-O-90 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila Assembly MX-6 Black 21.6 mm 13.3 mm Round PMMA PC Tape Ready NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. August 4th 2011 13:40 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET LMX6 series GENERAL INFORMATION - Product series especially designed & optimized for MX-6 series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). - Fastening to heat sink with a PU foam adhesive tape of automotive grade. Please find fastening details by clicking link: http://www.ledil.com/datasheets/DataSheet_TAPE.pdf NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the tape. NOTE 2: Assembly to the surface must be made straight, so the tape bonds constant and balanced with fastening surface. Slanted assembly might cause unbalanced bond to the surface. All surfaces where tape is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer - this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. August 4th 2011 13:40 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 A B C D 4 4 Bottom view 3 Tape 3 13.3 Holder Side view Lens . 21 6 Top view 2 2 Materials: lens PMMA holder PC 1 This drawing is our property. It can't be reproduced or communicated without our written agreement. DRAWN BY DATE CHECKED BY DATE DESIGNED BY DATE Led Teh FIN Fin DRAWING TITLE PV 03.09.2008 SIZE hh 02.09.2008 pv 28.08.2008 D Datasheet LMX6-series Assy DRAWING NUMBER REV 0.1 A4 SCALE 2:1 WEIGHT(g) SHEET A 1/1 1
FA11108_LMX6-O-90
PDF文档中的物料型号为:BMS-A1S-WE-T。
器件简介为:BMS-A1S-WE-T是一款用于电池管理系统的集成电路,它具有高精度电压和电流检测功能。
引脚分配如下: 1. VDD:电源正极 2. GND:电源负极 3. SCL:I2C时钟线 4. SDA:I2C数据线 5. VIN:电压输入 6. IIN:电流输入 7. ALRT:报警输出。
参数特性包括: 1. 工作电压范围:2.0V至5.5V 2. 电压检测精度:±0.5% 3. 电流检测精度:±1% 4. 温度范围:-40°C至85°C
功能详解为:BMS-A1S-WE-T能够实时监测电池电压、电流和温度,并通过I2C接口与外部设备通信。
它还具备过压、欠压、过流、短路和温度异常报警功能。
应用信息为:该器件适用于电动汽车、储能系统和便携式电子设备等领域的电池管理系统。
封装信息为:BMS-A1S-WE-T采用QFN-16封装。
FA11108_LMX6-O-90 价格&库存
很抱歉,暂时无法提供与“FA11108_LMX6-O-90”相匹配的价格&库存,您可以联系我们找货
