FP10992_LISA2-M-PIN
FP10992_LISA2-M-PIN
    LEDIL(芬兰)
    LENS FOR LUXEON REBEL
FP10992_LISA2-M-PIN 数据手册
PRODUCT DATASHEET Lisa2 series last update 25/10/2012 Product number FP11056_LISA2-RS-PIN Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lisa2 Assembly LUXEON Rebel Black 9.9 mm 6.6 mm Round PMMA PC Pin, glue On production Product number FP10992_LISA2-M-PIN Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lisa2 Assembly LUXEON Rebel Black 9.9 mm 6.6 mm Round PMMA PC Pin, glue On production Product number FP10993_LISA2-W-PIN Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lisa2 Assembly LUXEON Rebel Black 9.9 mm 6.6 mm Round PMMA PC Pin, glue On production Product number FP11126_LISA2-O-PIN Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lisa2 Assembly LUXEON Rebel Black 9.9 mm 6.6 mm Round PMMA PC Pin, glue On production FWHM Efficiency cd/lm Gerber File 18 degrees 91 % Available FWHM Efficiency cd/lm Gerber File 25 degrees 90 % Available FWHM Efficiency cd/lm Gerber File 36 degrees 90 % 1.800 Available FWHM Efficiency cd/lm Gerber File 48+19 degrees 83 % 2.150 Available May 14th 2015 11:19 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lisa2 series last update 25/10/2012 Product number FP11853_LISA2-O-90-PIN Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lisa2 Assembly LUXEON Rebel Black 9.9 mm 6.6 mm Round PMMA PC Pin, glue On production Product number FP11951_LISA2-WWW-PIN Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lisa2 Assembly LUXEON Rebel Black 9.9 mm 6.6 mm Round PMMA PC Pin, glue On production FWHM Efficiency cd/lm Gerber File 48+19 degrees 83 % (simulated) 0.000 Available FWHM Efficiency cd/lm Gerber File 80 degrees 79 % (simulated) 0.000 Available NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. May 14th 2015 11:19 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lisa2 series last update 25/10/2012 GENERAL INFORMATION - Product series especially designed & optimized for LUXEON Rebel series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance. Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). May 14th 2015 11:19 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 Relative intensity of FA11951_Lisa2-WWW-Pin-RE 100% 75% 50% 25% 0% 70 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 -70 A B C D Lens 4 Holder 4 Led 2 Isometric views Scale: 2:1 9. Bottom view 9 8. 6 6.6 3 3 2 1.2 Side view Materials: Lens PMMA Holder PC 2 1 This drawing is our property. It can't be reproduced or communicated without our written agreement. DRAWN BY DATE CHECKED BY DATE DESIGNED BY DATE Led Teh FIN Fin DRAWING TITLE Datasheet Lisa2-Rebel series assy 1 pv 10.11.2009 tk 07.08.2009 hh 09.08.2009 D SIZE DRAWING NUMBER REV 0.1 A4 SCALE 4:1 WEIGHT(g) SHEET A 1/1
FP10992_LISA2-M-PIN 价格&库存
很抱歉,暂时无法提供与“FP10992_LISA2-M-PIN”相匹配的价格&库存,您可以联系我们找货
FP10992_LISA2-M-PIN
  • 100+13.70762100+1.70940
  • 200+13.61861200+1.69830
  • 300+13.52960300+1.68720
  • 400+13.44059400+1.67610
  • 500+13.35158500+1.66500
