PRODUCT DATASHEET
Gt3 series
Ordering number C10891
Description
C10891_GT3-RE-S
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Gt3
Lens
Luxeon-Rebel
Transparent
35 mm
9 mm
Round
PMMA
Ready
FWHM
Efficiency
cd/lm
Gerber File
16 degrees
Available
FWHM
Efficiency
cd/lm
Gerber File
28 degrees
Available
FWHM
Efficiency
cd/lm
Gerber File
38 degrees
Available
Ordering number C10892
Description
C10892_GT3-RE-M
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Gt3
Lens
Luxeon-Rebel
Transparent
35 mm
9 mm
Round
PMMA
Glue, pin
Ready
Ordering number C10893
Description
C10893_GT3-RE-W
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Gt3
Lens
Luxeon-Rebel
Transparent
35 mm
9 mm
Round
PMMA
Ready
NOTE: The typical divergence will be changed by different color, chip size and chip position
tolerance. The typical total divergence is the full angle measured where the luminous intensity
is half of the peak value.
August 22nd 2011 10:40 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
http://www.ledil.com
email: ledil@ledil.com
FAX: +358-2-733 8001
PRODUCT DATASHEET
Gt3 series
GENERAL INFORMATION
- Product series especially designed & optimized for Luxeon-Rebel series of LEDs.
- Special care taken to make light distribution as uniform as possible.
- Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220
degrees of Fahrenheit). Allows use of high current and temperature conditions.
Please find more information about used material from below:
http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf
http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf
- Fastening to PCB with appropriate adhesive. By clicking link below you can find Ledil recommended glue
options.
http://www.ledil.com/datasheets/DataSheet_GLUES.pdf
NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end
product. For example, mechanical stress, vibration and holes on the surface of the circuit boar
weaken the strength of the glue.
NOTE 2: All surfaces where glue is applied must be clean, dry and free from grease and dirt. If
cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED
manufacturer -this is important as cleaning shall under no circumstances damage LEDs or other
electronics components on the PCB.
Further note that optical components shall not be cleaned with any chemicals - only micro fiber
cloth may be used to remove fingerprints or other traces from handling.
August 22nd 2011 10:40 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
PRODUCT DATASHEET
Gt3 series
C10891
C10892
C10893
August 22nd 2011 10:40 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
Relative intensity of C11624-GT3-RE-WW
100%
75%
50%
25%
0%
60
50
40
30
-20
-30
-40
-50
-60
Relative intensity of C10891_GT3-RE-S
100%
75%
50%
25%
0%
70
60
50
40
30
-20
-30
-40
-50
-60
-70
A
B
C
D
28
4
4
17
Isometric view
Scale: 1:1
3
Bottom view
60
35
2.2
3
This drawing is our property.
It can't be reproduced
or communicated without
our written agreement.
1
30.35
DRAWN BY
DATE
Front view
CHECKED BY
DATE
tk
07.01.2010
hh
DATE
07.01.2010
D
2
Led
Teh
FIN
Fin
DRAWING TITLE
pv
08.01.2010
DESIGNED BY
8.9
60
6.9
1.8
Part no.s:
C10891_GT3-XP-S
C10891_GT3-XP-G-S
C10891_GT3-OSL-S
C10891_GT3-DD-S
C10891_GT3-RE-ES-M
C10891_GT3-Z5-S
C10892_GT3-XP-M
C10892_GT3-XP-G-M
C10892_GT3-OSL-M
C10892_GT3-DD-M
C10892_GT3-XP-M
C10892_GT3-Z5-M
C10893_GT3-XP-W
C10893_GT3-XP-G-W
C10893_GT3-OSL-W
C10893_GT3-DD-W
C10893_GT3-RE-ES-W
C11623_GT3-RE-WW
C11623_GT3-N19-WW
C11624_GT3-XP-WW
C11624_GT3-XP-G-WW
C11624_GT3-OSL-WW
C11624_GT3-DD-WW
C11624_GT3-Z5-WW
1.45
2
3
Material: PMMA
SIZE
Datasheet GT3-Series Lens
DRAWING NUMBER
A4
SCALE
2:1 WEIGHT(g)
REV
1
SHEET
A
1/1
1
很抱歉,暂时无法提供与“C10893 GT3-RE-W”相匹配的价格&库存,您可以联系我们找货
