C17362_DAISY-7X1-W-D
    LEDIL(芬兰)
C17362_DAISY-7X1-W-D 数据手册
PRODUCT DATASHEET DAISY-7X1-W-D DAISY-7X1-W-D ~50° wide beam. Variant with diffused lenses. SPECIFICATION: Dimensions 279.5 x 39.6 mm Height 20.3 mm Fastening pin, screw, clips ROHS compliant yes MATERIALS: Component Type Material Colour Finish Length C17362_DAISY-7X1-W-D Linear lens PMMA milky C19642_DAISY-7X1-SHD3-MET-MATT Shade PC metal matt 40.0 C19641_DAISY-7X1-SHD3-MET Shade PC metal gloss 40.0 C19315_DAISY-7X1-SHD3-WHT-MATT Shade PC white matt 40.0 C19314_DAISY-7X1-SHD3-WHT Shade PC white gloss 40.0 C19313_DAISY-7X1-SHD3-MATT Shade PC black matt 40.0 C19312_DAISY-7X1-SHD3 Shade PC black gloss 40.0 C18409_DAISY-7X1-SHD-MET-MATT Shade PC metal matt 279.5 C18167_DAISY-7X1-SHD-MET Shade PC metal gloss C17225_DAISY-7X1-SHD-WHT-MATT Shade PC white matt 279.5 C17051_DAISY-7X1-SHD-MATT Shade PC black matt 279.5 C16876_DAISY-7X1-SHD-WHT Shade PC white gloss 279.5 C16872_DAISY-7X1-SHD Shade PC black gloss ORDERING INFORMATION: Quantities for one set: Linear lens 1 Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/29 PRODUCT DATASHEET Shade 1 DAISY-7X1-W-D Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/29 PRODUCT DATASHEET DAISY-7X1-W-D Component Qty in box MOQ MPQ Box weight (kg) C17362_DAISY-7X1-W-D » Box size: 400 x 300 x 300 mm Linear lens 312 312 24 6.3 C19312_DAISY-7X1-SHD3 » Box size: 595 x 360 x 230 mm Shade 156 312 24 6.1 C19642_DAISY-7X1-SHD3-MET-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 5.7 C17225_DAISY-7X1-SHD-WHT-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.6 C19313_DAISY-7X1-SHD3-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 5.8 C19314_DAISY-7X1-SHD3-WHT » Box size: 595 x 360 x 230 mm Shade 156 312 24 6.3 C16872_DAISY-7X1-SHD » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.1 C18167_DAISY-7X1-SHD-MET » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.0 C19315_DAISY-7X1-SHD3-WHT-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 6.2 C16876_DAISY-7X1-SHD-WHT » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.6 C18409_DAISY-7X1-SHD-MET-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.0 C19641_DAISY-7X1-SHD3-MET » Box size: 595 x 360 x 230 mm Shade 156 312 24 6.1 C17051_DAISY-7X1-SHD-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.3 Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/29 PRODUCT DATASHEET DAISY-7X1-W-D See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED LIGHT ENGINE DAISY 28 LEDs 277.5mm x 20mm FWHM / FWTM 65.0° / 92.0° Efficiency 89 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED LIGHT ENGINE DAISY 28 LEDs 277.5mm x 20mm FWHM / FWTM 64.0° / 90.0° Efficiency 88 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17533_DAISY-7X1-SHD-MET-MATT LED LIGHT ENGINE DAISY 28 LEDs 277.5mm x 20mm FWHM / FWTM 64.0° / 89.0° Efficiency 78 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED LIGHT ENGINE DAISY 28 LEDs 277.5mm x 20mm FWHM / FWTM 63.0° / 88.0° Efficiency 77 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED LIGHT ENGINE DAISY 28 LEDs 277.5mm x 20mm FWHM / FWTM 64.0° / 90.0° Efficiency 90 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C18167_DAISY-7X1-SHD-MET LED LIGHT ENGINE DAISY 28 LEDs 277.5mm x 20mm FWHM / FWTM 65.0° / 92.0° Efficiency 90 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED LUXEON 2835 Line FWHM / FWTM 64.0° / 91.0° Efficiency 88 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17533_DAISY-7X1-SHD-MET-MATT LED LUXEON 2835 Line FWHM / FWTM 64.0° / 89.0° Efficiency 78 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED LUXEON 2835 Line FWHM / FWTM 63.0° / 88.0° Efficiency 77 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED LUXEON 2835 Line FWHM / FWTM 64.0° / 90.0° Efficiency 90 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17532_DAISY-7X1-SHD-MET LED LUXEON 2835 Line FWHM / FWTM 65.0° / 93.0° Efficiency 90 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT LED LUXEON 2835 Line FWHM / FWTM 65.0° / 92.0° Efficiency 89 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 64.0° / 89.0° Efficiency 76 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 64.0° / 91.0° Efficiency 88 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C18167_DAISY-7X1-SHD-MET LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 64.0° / 89.0° Efficiency 77 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 65.0° / 93.0° Efficiency 88 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 65.0° / 93.0° Efficiency 88 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 64.0° / 92.0° Efficiency 87 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17533_DAISY-7X1-SHD-MET-MATT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED LinLED 280x28mm 1600lm 840 4C 21V DAISY 7x1(ZT25) FWHM / FWTM 56.0° / 81.0° Efficiency 81 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED LinLED 280x28mm 2x550lm 827-865 2x2C 42V DAISY-7X1 G1 FWHM / FWTM 66.0° / 94.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED LinLED 280x28mm 2x550lm 827-865 2x2C 42V DAISY-7X1 G1 FWHM / FWTM 65.0° / 92.0° Efficiency 87 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C17533_DAISY-7X1-SHD-MET-MATT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED LinLED 280x28mm 2x550lm 827-865 2x2C 42V DAISY-7X1 G1 FWHM / FWTM 65.0° / 90.0° Efficiency 77 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C16872_DAISY-7X1-SHD LED LinLED 280x28mm 2x550lm 827-865 2x2C 42V DAISY-7X1 G1 FWHM / FWTM 65.0° / 90.0° Efficiency 76 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C17051_DAISY-7X1-SHD-MATT LED LinLED 280x28mm 2x550lm 827-865 2x2C 42V DAISY-7X1 G1 FWHM / FWTM 65.0° / 91.0° Efficiency 89 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C18167_DAISY-7X1-SHD-MET Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED LinLED 280x28mm 2x550lm 827-865 2x2C 42V DAISY-7X1 G1 FWHM / FWTM 66.0° / 94.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C16876_DAISY-7X1-SHD-WHT LED NF2W757G-MT (Tunable White) FWHM / FWTM 62.0° / 86.0° Efficiency 93 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C16876_DAISY-7X1-SHD-WHT LED NF2W757G-MT (Tunable White) FWHM / FWTM 61.0° / 84.0° Efficiency 82 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C16872_DAISY-7X1-SHD Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED PL-LIN-2000 280x24mm FWHM / FWTM 64.0° / 89.0° Efficiency 76 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED OSCONIQ E 2835 FWHM / FWTM 64.0° / 89.0° Efficiency 76 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED LM28xB Series FWHM / FWTM 61.0° / 85.0° Efficiency 82 % Peak intensity 0.9 cd/lm LEDs/each optic 2 Light colour/type White Required components: C16872_DAISY-7X1-SHD Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED LM28xB Series FWHM / FWTM 62.0° / 88.0° Efficiency 92 % Peak intensity 0.9 cd/lm LEDs/each optic 2 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT LED LM28xB Series FWHM / FWTM 60.0° / 84.0° Efficiency 77 % Peak intensity 0.8 cd/lm LEDs/each optic 2 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED LED-St-L28W2c4-xxx-C015-55 (DAISY-7x1) FWHM / FWTM 65.0° / 93.0° Efficiency 90 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED LED-St-L28W2c4-xxx-C015-55 (DAISY-7x1) FWHM / FWTM 65.0° / 93.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED LED-St-L28W2c4-xxx-C015-55 (DAISY-7x1) FWHM / FWTM 63.0° / 91.0° Efficiency 90 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17533_DAISY-7X1-SHD-MET-MATT LED LED-St-L28W2c4-xxx-C015-55 (DAISY-7x1) FWHM / FWTM 64.0° / 89.0° Efficiency 78 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED LED-St-L28W2c4-xxx-C015-55 (DAISY-7x1) FWHM / FWTM 64.0° / 89.0° Efficiency 77 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED LED-St-L28W2c4-xxx-C015-55 (DAISY-7x1) FWHM / FWTM 64.0° / 90.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C18167_DAISY-7X1-SHD-MET LED PassivePAQ-L-1F35-SSA3-2.7K-840-3-DC FWHM / FWTM 68.0° / 94.0° Efficiency 71 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED PassivePAQ-L-1F35-SSA3-2.7K-840-3-DC FWHM / FWTM 68.0° / 93.0° Efficiency 71 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED PassivePAQ-L-1F35-SSA3-2.7K-840-3-DC FWHM / FWTM 70.0° / 100.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED PassivePAQ-L-1F35-SSA3-2.7K-840-3-DC FWHM / FWTM 70.0° / 100.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM 65.0° / 90.0° Efficiency 76 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM 65.0° / 90.0° Efficiency 76 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM 66.0° / 95.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (MEASURED): LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM 66.0° / 95.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (SIMULATED): LED SMD 3838 RGBW 3V FWHM / FWTM 56.0° / 86.0° Efficiency 80 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type RGBW Required components: C16872_DAISY-7X1-SHD LED J Series 2835 FWHM / FWTM 62.0° / 90.0° Efficiency 78 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 62.0° / 86.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (SIMULATED): LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 62.0° / 86.0° Efficiency 90 % Peak intensity 0.9 cd/lm LEDs/each optic 4 Light colour/type White Required components: C18167_DAISY-7X1-SHD-MET LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 62.0° / 86.0° Efficiency 74 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 62.0° / 86.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (SIMULATED): LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 62.0° / 86.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17533_DAISY-7X1-SHD-MET-MATT LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 62.0° / 85.0° Efficiency 74 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED Duris E 2835 FWHM / FWTM 62.0° / 90.0° Efficiency 83 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (SIMULATED): LED Duris E 2835 FWHM / FWTM 61.0° / 91.0° Efficiency 88 % Peak intensity 0.9 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED OSLON PURE 1010 FWHM / FWTM 50.0° / 76.0° Efficiency 86 % Peak intensity 1.3 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED LH231B FWHM / FWTM 56.0° / 84.0° Efficiency 75 % Peak intensity 0.9 cd/lm LEDs/each optic 2 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 24/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (SIMULATED): LED LM101B FWHM / FWTM 54.0° / 78.0° Efficiency 86 % Peak intensity 1.1 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED LM101B FWHM / FWTM 58.0° / 82.0° Efficiency 88 % Peak intensity 1 cd/lm LEDs/each optic 4 Light colour/type White Required components: C18167_DAISY-7X1-SHD-MET LED LM28xB Series FWHM / FWTM 60.0° / 84.0° Efficiency 87 % Peak intensity 1 cd/lm LEDs/each optic 4 Light colour/type White Required components: C19641_DAISY-7X1-SHD3-MET Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 25/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (SIMULATED): LED LM28xB Series FWHM / FWTM 55.0° / 80.0° Efficiency 89 % Peak intensity 1.1 cd/lm LEDs/each optic 2 Light colour/type White Required components: C19641_DAISY-7X1-SHD3-MET LED LM301Z Plus FWHM / FWTM 60.0° / 86.0° Efficiency 75 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED LM301Z Plus FWHM / FWTM 62.0° / 86.0° Efficiency 88 % Peak intensity 0.9 cd/lm LEDs/each optic 4 Light colour/type White Required components: C18167_DAISY-7X1-SHD-MET Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 26/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (SIMULATED): LED LM301Z Plus FWHM / FWTM 60.0° / 86.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED SEOUL DC 3030C FWHM / FWTM 62.0° / 88.0° Efficiency 80 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED SEOUL DC 3528 FWHM / FWTM 59.0° / 84.0° Efficiency 76 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16872_DAISY-7X1-SHD Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 27/29 PRODUCT DATASHEET DAISY-7X1-W-D OPTICAL RESULTS (SIMULATED): LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM 62.0° / 88.0° Efficiency 88 % Peak intensity 0.9 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17533_DAISY-7X1-SHD-MET-MATT LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM 62.0° / 89.0° Efficiency 93 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 28/29 PRODUCT DATASHEET DAISY-7X1-W-D GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 09/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 29/29
C17362_DAISY-7X1-W-D 价格&库存
很抱歉,暂时无法提供与“C17362_DAISY-7X1-W-D”相匹配的价格&库存,您可以联系我们找货
  • 312+18.82644312+2.43352
