CA10322_SPUTNIK-Z-O
CA10322_SPUTNIK-Z-O
    LEDIL(芬兰)
    LENS FOR SEOUL P3, P4
CA10322_SPUTNIK-Z-O 数据手册
LEDIL F’FORM OPTICS FULLY SEALABLE SPUTNIK-Z lenses for SSC P3, P4 - - - Use with Seoul Semiconductor P3 and P4 series of white and monochromate LEDs Lens material optical grade PMMA with high UV and temperature resistance (105°C/220°F) High optical efficiency, up to 90% NEW smooth spot and oval versions with improved efficiency and color uniformity also compatible with the new P4 package No lens holder. Fastening to heat sink with a PU foam adhesive tape of automotive grade Lens foot can be potted with resin without loosing anything in optical efficiency (fully sealed construction possible) Diameter 26 mm (approximately 1”) Easy build of a complete luminaire using SPUTNIK, P3 or P4 and heat sink Mechanical CAD models available upon request All lens types have the same outer dimensions, which allow a cross use of them in the same lighting fixture LENS TYPES NAME Sputnik-Z Sputnik-Z Sputnik-Z Sputnik-Z ORDERING CODE smooth spot medium oval wide CA10321_Sputnik-Z-SS CA10249_Sputnik-Z-M CA10322_Sputnik-Z-O CA10241_Sputnik-Z-W FWHM Angle ±5° ±13° ±7° x ±18° ±32° SMOOTH SPOT lens is a pure collimator lens with light mixing properties. It smoothens the beam pattern and makes a uniform color distribution over the whole beam angle. Light intensity is lower than for the REAL SPOT lens. SMOOTH SPOT lens is recommended for white light applications, where pleasant, high-quality illumination is wished. OVAL lens is optimal for cases where a narrow stripe of light is wished. If a wider vertical distribution is needed, please consider LEDIL SSS-O with wider vertical distribution and a color mixing structure. © Ledil Oy - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-28 LEDIL F’FORM OPTICS MEASUREMENTS SPUTNIK-Z-SS SPUTNIK-Z-M SPUTNIK-Z-O SPUTNIK-Z-W © Ledil Oy - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-28 LEDIL F’FORM OPTICS PHOTOGRAPHS SPUTNIK-Z-SS SPUTNIK-Z-M SPUTNIK-Z-O SPUTNIK-Z-W DIMENSIONS SPUTNIK-Z-SS and SPUTNIK-Z-M SPUTNIK-Z-O SPUTNIK-Z-W © Ledil Oy - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-28 LEDIL F’FORM OPTICS PACKAGING Lenses are packed on plastic trays of 77 lenses. One box contains 13 trays, i.e. 1001 lenses. SPECIAL VERSIONS Special versions available on request, e.g. fully metallized outer surface allowing full potting of lens up to the top surface or different packing methods. © Ledil Oy - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-28
CA10322_SPUTNIK-Z-O 价格&库存
很抱歉,暂时无法提供与“CA10322_SPUTNIK-Z-O”相匹配的价格&库存,您可以联系我们找货
