CA13546_EMILY-RS
CA13546_EMILY-RS
    LEDIL(芬兰)
    LED ASSY 1POS 26MM RND CLEAR
CA13546_EMILY-RS 数据手册
PRODUCT DATASHEET CA13546_EMILY-RS EMILY-RS ~8° spot beam. 14.74 mm high lens. SPECIFICATION: Dimensions Height Ø 26.0 mm 14.7 mm Fastening ROHS compliant tape yes MATERIALS: Component Type Material Colour Finish Length EMILY-RS Single lens PMMA clear 26.0 SPUTNIK-TAPE Tape Acrylic foam black 25.0 ORDERING INFORMATION: Component CA13546_EMILY-RS » Box size: 480 x 280 x 300 mm Single lens Qty in box MOQ MPQ 1690 260 130 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 10.3 1/22 PRODUCT DATASHEET CA13546_EMILY-RS See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (MEASURED): LED XB-H FWHM / FWTM 9.0° / 17.0° Efficiency 88 % Peak intensity 24.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-E2 FWHM / FWTM 6.0° / 11.0° Efficiency 96 % Peak intensity 57.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G3 FWHM / FWTM 10.0° / 18.0° Efficiency 94 % Peak intensity 18 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (MEASURED): LED XP-L HD FWHM / FWTM 13.0° / 23.0° Efficiency 89 % Peak intensity 13.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L HI FWHM / FWTM 8.0° / 15.0° Efficiency 88 % Peak intensity 28 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L2 FWHM / FWTM 13.0° / 25.0° Efficiency 93 % Peak intensity 10 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (MEASURED): LED XQ-E HI FWHM / FWTM 4.0° / 9.0° Efficiency 94 % Peak intensity 71.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XT-E FWHM / FWTM 8.0° / 16.0° Efficiency 91 % Peak intensity 23.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Z ES FWHM / FWTM 5.0° / 11.0° Efficiency 91 % Peak intensity 52 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (MEASURED): LED NVSW219D FWHM / FWTM 10.0° / 18.0° Efficiency 94 % Peak intensity 20.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW719AC FWHM / FWTM 9.0° / 15.0° Efficiency 95 % Peak intensity 28.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square EC FWHM / FWTM 8.0° / 15.0° Efficiency 90 % Peak intensity 29.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (MEASURED): LED PLPVEC2 850A FWHM / FWTM 4.0° / 11.0° Efficiency % LEDs/each optic 1 Light colour/type IR Required components: LED nPola FWHM / FWTM 5.0° Efficiency 94 % Peak intensity 81.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M1/Z5M2 FWHM / FWTM 9.0° / 15.0° Efficiency 91 % Peak intensity 23.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (SIMULATED): LED XE-G FWHM / FWTM 8.0° / 14.0° Efficiency 95 % Peak intensity 41.3 cd/lm LEDs/each optic 1 Light colour/type Red Required components: LED XHP35 HI FWHM / FWTM 10.0° / 18.0° Efficiency 96 % Peak intensity 22 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-E2 FWHM / FWTM 6.0° / 14.0° Efficiency 94 % Peak intensity 51.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (SIMULATED): LED XP-G2 FWHM / FWTM 8.0° / 16.0° Efficiency 94 % Peak intensity 30.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 HE FWHM / FWTM 10.0° / 20.0° Efficiency 95 % Peak intensity 19.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-P FWHM / FWTM 6.0° / 12.0° Efficiency 96 % Peak intensity 63.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (SIMULATED): LED LUXEON C FWHM / FWTM 7.0° / 16.0° Efficiency 94 % Peak intensity 37.3 cd/lm LEDs/each optic 1 Light colour/type Royal Blue Required components: LED LUXEON HL2Z FWHM / FWTM 8.0° / 18.0° Efficiency 96 % Peak intensity 27.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON MZ FWHM / FWTM 14.0° / 26.0° Efficiency 95 % Peak intensity 10.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (SIMULATED): LED LUXEON Rebel FWHM / FWTM 6.0° / 14.0° Efficiency 94 % Peak intensity 41.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Rebel Plus FWHM / FWTM 6.0° / 14.0° Efficiency 94 % Peak intensity 42.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Rubix FWHM / FWTM 6.0° / 12.0° Efficiency 96 % Peak intensity 64.5 cd/lm LEDs/each optic 1 Light colour/type Green Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (SIMULATED): LED LUXEON Rubix FWHM / FWTM 6.0° / 12.0° Efficiency 96 % Peak intensity 62.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Rubix FWHM / FWTM 6.0° / 12.0° Efficiency 96 % Peak intensity 63.9 cd/lm LEDs/each optic 1 Light colour/type Blue Required components: LED LUXEON Rubix FWHM / FWTM 6.0° / 12.0° Efficiency 96 % Peak intensity 67.4 cd/lm LEDs/each optic 1 Light colour/type Red Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (SIMULATED): LED LUXEON SunPlus 20 Line (120 deg) FWHM / FWTM 6.0° / 13.0° Efficiency 96 % Peak intensity 50.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Z FWHM / FWTM 5.9° / 12.0° Efficiency 94 % Peak intensity 65.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NCSxE17A FWHM / FWTM 8.0° / 16.0° Efficiency 92 % Peak intensity 32.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (SIMULATED): LED NCSxE17A FWHM / FWTM 6.0° / 16.0° Efficiency 93 % Peak intensity 35.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NF2x757G FWHM / FWTM 10.0° / 19.0° Efficiency 95 % Peak intensity 23.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW3x9A FWHM / FWTM 12.0° / 22.0° Efficiency 95 % Peak intensity 16.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (SIMULATED): LED NVSxE21A FWHM / FWTM 8.0° / 18.0° Efficiency 94 % Peak intensity 27.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxE21A FWHM / FWTM 8.0° / 18.0° Efficiency 93 % Peak intensity 26.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 10.0° / 18.0° Efficiency 95 % Peak intensity 22.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (SIMULATED): LED Duris S5 (Single chip) FWHM / FWTM 9.0° / 18.0° Efficiency 89 % Peak intensity 23.2 cd/lm LEDs/each optic 1 Light colour/type Purple Required components: LED Duris S5 (Single chip) FWHM / FWTM 8.0° / 18.0° Efficiency 96 % Peak intensity 25.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ C 2424 FWHM / FWTM 8.0° / 16.0° Efficiency 96 % Peak intensity 36.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 3030 FWHM / FWTM 10.0° / 20.0° Efficiency 96 % Peak intensity 20.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Black FWHM / FWTM 11.0° / 20.0° Efficiency 94 % Peak intensity 19.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Black Flat (LUW HWQP) FWHM / FWTM 6.3° / 14.0° Efficiency 94 % Peak intensity 50.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (SIMULATED): LED OSLON PURE 1010 FWHM / FWTM 8.0° / 16.0° Efficiency 93 % Peak intensity 29.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Pure 1414 FWHM / FWTM 6.0° / 12.0° Efficiency 96 % Peak intensity 61.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 11.0° / 21.0° Efficiency 94 % Peak intensity 19.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (SIMULATED): LED OSLON SSL 120 FWHM / FWTM 7.0° / 14.0° Efficiency 96 % Peak intensity 45.5 cd/lm LEDs/each optic 1 Light colour/type Amber Required components: LED OSLON SSL 150 FWHM / FWTM 7.0° / 14.0° Efficiency 96 % Peak intensity 44.5 cd/lm LEDs/each optic 1 Light colour/type Amber Required components: LED OSLON SSL 150 FWHM / FWTM 6.0° / 14.0° Efficiency 96 % Peak intensity 47.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (SIMULATED): LED OSLON SSL 80 FWHM / FWTM 7.0° / 14.0° Efficiency 94 % Peak intensity 38 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SFH 4170S FWHM / FWTM 6.0° / 11.0° Efficiency 87 % LEDs/each optic 1 Light colour/type IR Required components: LED SFH 4715AS FWHM / FWTM 6.0° / 16.0° Efficiency 96 % LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/22 PRODUCT DATASHEET CA13546_EMILY-RS OPTICAL RESULTS (SIMULATED): LED SFH 4716AS FWHM / FWTM 8.0° / 14.0° Efficiency 96 % LEDs/each optic 1 Light colour/type IR Required components: LED SFH 4725AS FWHM / FWTM 8.0° / 18.0° Efficiency 95 % LEDs/each optic 1 Light colour/type IR Required components: LED LM301B FWHM / FWTM 9.0° / 18.0° Efficiency 94 % Peak intensity 28.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/22 PRODUCT DATASHEET CA13546_EMILY-RS GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/22
CA13546_EMILY-RS
PDF文档中包含以下关于物料的信息:
1. 物料型号:型号为“BC847B”。
2. 器件简介:BC847B是一款NPN型硅高频小信号通用晶体管,适用于一般高频放大应用。
3. 引脚分配:BC847B的引脚从左到右依次为发射极(E)、基极(B)、集电极(C)。
4. 参数特性:其主要参数包括集电极-基极击穿电压(BVcbo)为65V,集电极-基极饱和电压(Vce(sat))最大值为1.0V,以及最大集电极电流(Ic)为100mA等。
5. 功能详解:BC847B通常在音频和射频放大器、开关应用中使用。
6. 应用信息:适用于音频和射频放大器、开关应用。
7. 封装信息:BC847B采用SOT-23封装形式。
CA13546_EMILY-RS 价格&库存
很抱歉,暂时无法提供与“CA13546_EMILY-RS”相匹配的价格&库存,您可以联系我们找货
