CA14367_FLARE-MAXI-D-TAPE
    LEDIL(芬兰)
CA14367_FLARE-MAXI-D-TAPE 数据手册
PRODUCT DATASHEET CA14367_FLARE-MAXI-D-TAPE FLARE-MAXI-D-TAPE 34 x 33 mm lens with ~110° x 15° diffused oval beam. Assembly with installation tape. SPECIFICATION: Dimensions 33.9 x 33.3 mm Height 16.9 mm Fastening tape, pin ROHS compliant yes MATERIALS: Component Type Material Colour FLARE-MAXI-D Single lens PMMA clear FLARE-MAXI-TAPE Tape Acrylic foam clear Finish ORDERING INFORMATION: Component CA14367_FLARE-MAXI-D-TAPE » Box size: 457 x 260 x 260 mm Qty in box Single lens 864 MOQ MPQ 144 72 Box weight (kg) 10.0 Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/12 PRODUCT DATASHEET CA14367_FLARE-MAXI-D-TAPE See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/12 PRODUCT DATASHEET CA14367_FLARE-MAXI-D-TAPE OPTICAL RESULTS (MEASURED): LED MK-R FWHM / FWTM 100.0 + 23.0° / 184.0° Efficiency 92 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50 FWHM / FWTM 109.0 + 20.0° / 155.0 + 35.0° Efficiency 92 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP70 FWHM / FWTM 107.0 + 27.0° / 154.0 + 42.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L FWHM / FWTM 110.0 + 15.0° / 178.0° Efficiency 94 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/12 PRODUCT DATASHEET CA14367_FLARE-MAXI-D-TAPE OPTICAL RESULTS (MEASURED): LED XM-L2 FWHM / FWTM 101.0 + 17.0° / 174.0° Efficiency 94 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM 115.0 + 15.0° / 178.0° Efficiency 94 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 106.0 + 14.0° / 174.0° Efficiency 94 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HD FWHM / FWTM 119.0 + 16.0° / 154.0 + 27.0° Efficiency 94 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/12 PRODUCT DATASHEET CA14367_FLARE-MAXI-D-TAPE OPTICAL RESULTS (MEASURED): LED XP-L2 FWHM / FWTM 107.0 + 16.0° / 158.0 + 28.0° Efficiency 92 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 117.0 + 14.0° / 185.0° Efficiency 94 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON A FWHM / FWTM 104.0 + 12.0° / 172.0° Efficiency 94 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON M/MX FWHM / FWTM 102.0 + 25.0° / 185.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/12 PRODUCT DATASHEET CA14367_FLARE-MAXI-D-TAPE OPTICAL RESULTS (MEASURED): LED LUXEON Rebel ES FWHM / FWTM 104.0 + 13.0° / 175.0° Efficiency 94 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON T FWHM / FWTM 102.0 + 13.0° / 174.0° Efficiency 92 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 103.0 + 13.0° / 143.0° Efficiency 93 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxx19B FWHM / FWTM 107.0 + 13.0° / 179.0° Efficiency 94 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/12 PRODUCT DATASHEET CA14367_FLARE-MAXI-D-TAPE OPTICAL RESULTS (MEASURED): LED NS9x383 FWHM / FWTM 110.0 + 16.0° / 182.0° Efficiency 93 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219F FWHM / FWTM 108.0 + 14.0° / 146.0 + 24.0° Efficiency 93 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 116.0 + 13.0° / 179.0° Efficiency 94 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S10 FWHM / FWTM 92.0 + 21.0° / 142.0 + 40.0° Efficiency 93 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/12 PRODUCT DATASHEET CA14367_FLARE-MAXI-D-TAPE OPTICAL RESULTS (MEASURED): LED OSLON Square EC FWHM / FWTM 99.0 + 14.0° / 176.0° Efficiency 94 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square PC FWHM / FWTM 104.0 + 12.0° / 175.0° Efficiency 94 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351Z FWHM / FWTM 97.0 + 13.0° / 128.0 + 22.0° Efficiency 94 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED WICOP 5050 FWHM / FWTM 115.0 + 19.0° / 160.0 + 33.0° Efficiency 91 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/12 PRODUCT DATASHEET CA14367_FLARE-MAXI-D-TAPE OPTICAL RESULTS (MEASURED): LED Z5M1/Z5M2 FWHM / FWTM 104.0 + 14.0° / 169.0° Efficiency 94 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M3 FWHM / FWTM 108.0 + 13.0° / 155.0 + 24.0° Efficiency 94 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22P FWHM / FWTM 116.0 + 13.0° / 158.0 + 25.0° Efficiency 92 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y50P FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/12 PRODUCT DATASHEET CA14367_FLARE-MAXI-D-TAPE OPTICAL RESULTS (SIMULATED): LED XHP35 HD FWHM / FWTM 92.0 + 15.0° / 142.0 + 25.0° Efficiency 92 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HI FWHM / FWTM 86.0 + 11.0° / 140.0 + 20.0° Efficiency 93 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50.2 FWHM / FWTM 96.0 + 19.0° / 146.0 + 32.0° Efficiency 94 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON H50-2 FWHM / FWTM 10.0 + 65.0° / 144.0° Efficiency 92 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/12 PRODUCT DATASHEET CA14367_FLARE-MAXI-D-TAPE OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 7070 FWHM / FWTM 88.0 + 17.0° / 144.0 + 27.0° Efficiency 93 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/12 PRODUCT DATASHEET CA14367_FLARE-MAXI-D-TAPE GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/12
CA14367_FLARE-MAXI-D-TAPE 价格&库存
很抱歉,暂时无法提供与“CA14367_FLARE-MAXI-D-TAPE”相匹配的价格&库存,您可以联系我们找货
