F17031_DAISY-MINI-WW
    LEDIL(芬兰)
F17031_DAISY-MINI-WW 数据手册
PRODUCT DATASHEET DAISY-MINI-WW DAISY-MINI-WW ~65° wide beam SPECIFICATION: Dimensions x mm Height 0 mm Fastening pin, screw, snaps ROHS compliant yes MATERIALS: Component Type Material Colour Finish F17031_DAISY-MINI-WW Linear lens PMMA clear F17667_DAISY-MINI-SHD-MET-MATT Shade PC metal matt F17666_DAISY-MINI-SHD-MET Shade PC metal gloss F17465_DAISY-MINI-SHD-WHT-MATT Shade PC white matt F17034_DAISY-MINI-SHD-MATT Shade PC black matt F17033_DAISY-MINI-SHD-WHT Shade PC white gloss F17028_DAISY-MINI-SHD Shade PC black gloss ORDERING INFORMATION: Quantities for one set: Linear lens 1 Shade 1 Last update: 08/11/2023 Subject to change without prior notice Published: 09/03/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/14 PRODUCT DATASHEET DAISY-MINI-WW Component Qty in box MOQ MPQ Box weight (kg) F17031_DAISY-MINI-WW » Box size: 398 x 298 x 265 mm Linear lens 252 252 12 5.9 F17667_DAISY-MINI-SHD-MET-MATT » Box size: 398 x 298 x 265 mm Shade 252 252 4 6.2 F17034_DAISY-MINI-SHD-MATT » Box size: 398 x 298 x 265 mm Shade 252 252 4 6.1 F17028_DAISY-MINI-SHD » Box size: 398 x 298 x 265 mm Shade 252 252 4 5.9 F17465_DAISY-MINI-SHD-WHT-MATT » Box size: 398 x 298 x 265 mm Shade 252 252 4 6.2 F17666_DAISY-MINI-SHD-MET » Box size: 398 x 298 x 265 mm Shade 252 252 4 5.9 F17033_DAISY-MINI-SHD-WHT » Box size: 398 x 298 x 265 mm Shade 252 252 4 5.9 Last update: 08/11/2023 Subject to change without prior notice Published: 09/03/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/14 PRODUCT DATASHEET DAISY-MINI-WW See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice Published: 09/03/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/14 PRODUCT DATASHEET DAISY-MINI-WW OPTICAL RESULTS (MEASURED): LED J Series 2835 FWHM / FWTM 63.0° / 76.0° Efficiency 89 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: F17667_DAISY-MINI-SHD-MET-MATT LED Opticus Daisy Mini M L28W2 FWHM / FWTM 63.0° / 74.0° Efficiency 80 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: F17034_DAISY-MINI-SHD-MATT LED LinLED 280x20mm 1100lm 8x0 2C 42V Opt G1 FWHM / FWTM 61.0° / 84.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 2 Light colour White Required components: F17465_DAISY-MINI-SHD-WHT-MATT LED LinLED 280x20mm 1100lm 8x0 2C 42V Opt G1 FWHM / FWTM 61.0° / 82.0° Efficiency 78 % Peak intensity 0.8 cd/lm LEDs/each optic 2 Light colour White Required components: F17028_DAISY-MINI-SHD Last update: 08/11/2023 Subject to change without prior notice Published: 09/03/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/14 PRODUCT DATASHEET DAISY-MINI-WW OPTICAL RESULTS (MEASURED): LED LinLED 280x20mm 1100lm 8x0 2C 42V Opt G1 FWHM / FWTM 63.0° / 84.0° Efficiency 91 % Peak intensity 0.9 cd/lm LEDs/each optic 2 Light colour White Required components: F17666_DAISY-MINI-SHD-MET LED LinLED 280x20mm 1100lm 8x0 2C 42V Opt G1 FWHM / FWTM 62.0° / 85.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 2 Light colour White Required components: F17033_DAISY-MINI-SHD-WHT LED LinLED 280x20mm 1100lm 8x0 2C 42V Opt G1 FWHM / FWTM 62.0° / 85.0° Efficiency 90 % Peak intensity 0.9 cd/lm LEDs/each optic 2 Light colour White Required components: F17667_DAISY-MINI-SHD-MET-MATT LED LinLED 280x20mm 1100lm 8x0 2C 42V Opt G1 FWHM / FWTM 60.0° / 82.0° Efficiency 78 % Peak intensity 0.8 cd/lm LEDs/each optic 2 Light colour White Required components: F17034_DAISY-MINI-SHD-MATT Last update: 08/11/2023 Subject to change without prior notice Published: 09/03/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/14 PRODUCT DATASHEET DAISY-MINI-WW OPTICAL RESULTS (MEASURED): LED LLE 20x280mm 750lm 827-865 LV MD ADV1 FWHM / FWTM 60.0° / 82.0° Efficiency 80 % Peak intensity 0.8 cd/lm LEDs/each optic 2 Light colour Tunable White Required components: F17028_DAISY-MINI-SHD LED LLE 20x280mm 750lm 840 LV MD ADV1 FWHM / FWTM 63.0° / 94.0° Efficiency 88 % Peak intensity 0.8 cd/lm LEDs/each optic 2 Light colour White Required components: F17667_DAISY-MINI-SHD-MET-MATT LED LLE 20x280mm 750lm 840 LV MD ADV1 FWHM / FWTM 59.0° / 82.0° Efficiency 79 % Peak intensity 0.8 cd/lm LEDs/each optic 2 Light colour White Required components: F17028_DAISY-MINI-SHD LED LLE 20x280mm 750lm 840 LV MD ADV1 FWHM / FWTM 60.0° / 86.0° Efficiency 69 % Peak intensity 0.7 cd/lm LEDs/each optic 2 Light colour White Required components: F17034_DAISY-MINI-SHD-MATT Last update: 08/11/2023 Subject to change without prior notice Published: 09/03/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/14 PRODUCT DATASHEET DAISY-MINI-WW OPTICAL RESULTS (MEASURED): LED LLE 20x280mm 750lm 840 LV MD ADV1 FWHM / FWTM 62.0° / 92.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 2 Light colour White Required components: F17465_DAISY-MINI-SHD-WHT-MATT LED LLE 20x280mm 750lm 840 LV MD ADV1 FWHM / FWTM 65.0° / 92.0° Efficiency 89 % Peak intensity 0.8 cd/lm LEDs/each optic 2 Light colour White Required components: F17666_DAISY-MINI-SHD-MET LED LLE 20x280mm 750lm 840 LV MD ADV1 FWHM / FWTM 62.0° / 93.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 2 Light colour White Required components: F17033_DAISY-MINI-SHD-WHT Last update: 08/11/2023 Subject to change without prior notice Published: 09/03/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/14 PRODUCT DATASHEET DAISY-MINI-WW OPTICAL RESULTS (SIMULATED): LED XQ-E HI FWHM / FWTM 66.0° / 76.0° Efficiency 76 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: F17034_DAISY-MINI-SHD-MATT LED XQ-E HI FWHM / FWTM 68.0° / 76.0° Efficiency 89 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: F17666_DAISY-MINI-SHD-MET LED LUXEON 2835 Line FWHM / FWTM 57.0° / 84.0° Efficiency 83 % Peak intensity 0.9 cd/lm LEDs/each optic 2 Light colour White Required components: F17034_DAISY-MINI-SHD-MATT LED LUXEON 5050 HE FWHM / FWTM 62.0° / 82.0° Efficiency 82 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: F17028_DAISY-MINI-SHD Last update: 08/11/2023 Subject to change without prior notice Published: 09/03/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/14 PRODUCT DATASHEET DAISY-MINI-WW OPTICAL RESULTS (SIMULATED): LED LUXEON 5050 HE FWHM / FWTM 62.0° / 82.0° Efficiency 83 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: F17034_DAISY-MINI-SHD-MATT LED LUXEON 5050 HE FWHM / FWTM 64.0° / 84.0° Efficiency 90 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: F17033_DAISY-MINI-SHD-WHT LED LUXEON HL1Z FWHM / FWTM 60.0° / 70.0° Efficiency 83 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: F17028_DAISY-MINI-SHD LED NF2W757G-MT (Tunable White) FWHM / FWTM 66.0° / 78.0° Efficiency 85 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour Tunable White Required components: F17034_DAISY-MINI-SHD-MATT Last update: 08/11/2023 Subject to change without prior notice Published: 09/03/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/14 PRODUCT DATASHEET DAISY-MINI-WW OPTICAL RESULTS (SIMULATED): LED NFSWE11A FWHM / FWTM 58.0° / 74.0° Efficiency 77 % Peak intensity 0.9 cd/lm LEDs/each optic 4 Light colour White Required components: F17028_DAISY-MINI-SHD LED NFSx757G FWHM / FWTM 64.0° / 76.0° Efficiency 85 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: F17028_DAISY-MINI-SHD LED NFSx757G FWHM / FWTM 64.0° / 78.0° Efficiency 92 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: F17033_DAISY-MINI-SHD-WHT LED NFSx757G FWHM / FWTM 64.0° / 78.0° Efficiency 90 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: F17666_DAISY-MINI-SHD-MET Last update: 08/11/2023 Subject to change without prior notice Published: 09/03/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/14 PRODUCT DATASHEET DAISY-MINI-WW OPTICAL RESULTS (SIMULATED): LED Duris E 2835 FWHM / FWTM 64.0° / 78.0° Efficiency 92 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: F17028_DAISY-MINI-SHD LED LM28xB Series FWHM / FWTM 76.0° / 93.0° Efficiency 70 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: F17028_DAISY-MINI-SHD LED LM28xB Series FWHM / FWTM 76.0° / 93.0° Efficiency 70 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: F17034_DAISY-MINI-SHD-MATT LED LM28xB Series FWHM / FWTM 76.0° / 94.0° Efficiency 77 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: F17667_DAISY-MINI-SHD-MET-MATT Last update: 08/11/2023 Subject to change without prior notice Published: 09/03/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/14 PRODUCT DATASHEET DAISY-MINI-WW OPTICAL RESULTS (SIMULATED): LED LM28xB Series FWHM / FWTM 76.0° / 94.0° Efficiency 79 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: F17033_DAISY-MINI-SHD-WHT LED LM28xB Series FWHM / FWTM 76.0° / 94.0° Efficiency 77 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: F17666_DAISY-MINI-SHD-MET LED LM28xB Series FWHM / FWTM 76.0° / 97.0° Efficiency 79 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: F17465_DAISY-MINI-SHD-WHT-MATT LED LM302D FWHM / FWTM 64.0° / 76.0° Efficiency 89 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: F17465_DAISY-MINI-SHD-WHT-MATT Last update: 08/11/2023 Subject to change without prior notice Published: 09/03/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/14 PRODUCT DATASHEET DAISY-MINI-WW OPTICAL RESULTS (SIMULATED): LED LM302D FWHM / FWTM 64.0° / 76.0° Efficiency 83 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: F17028_DAISY-MINI-SHD LED SEOUL 3030 FWHM / FWTM 66.0° / 78.0° Efficiency 85 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: F17028_DAISY-MINI-SHD Last update: 08/11/2023 Subject to change without prior notice Published: 09/03/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/14 PRODUCT DATASHEET DAISY-MINI-WW GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice Published: 09/03/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/14
F17031_DAISY-MINI-WW 价格&库存
很抱歉,暂时无法提供与“F17031_DAISY-MINI-WW”相匹配的价格&库存,您可以联系我们找货
    • 12+12.2104212+1.53180
    • 48+12.0334648+1.50960
    • 180+11.85650180+1.48740
    • 480+11.67953480+1.46520
    • 1200+11.502571200+1.44300
    • 1+26.973301+3.43540
    • 12+21.1658012+2.69570
    • 504+18.18040504+2.31550
    • 1008+18.098801008+2.30510
    • 2508+17.667302508+2.25020
    • 5004+17.585705004+2.23980
    库存:224
      • 12+13.2722012+1.66500
      • 60+13.0067560+1.63170
      • 240+12.82979240+1.60950
      • 600+12.65283600+1.58730
      • 1500+12.387381500+1.55400
