FS15786_FLORENCE-3R-IP-Z60
    LEDIL(芬兰)
FS15786_FLORENCE-3R-IP-Z60 数据手册
PRODUCT DATASHEET FS15786_FLORENCE-3R-IP-Z60 FLORENCE-3R-IP-Z60 ~60° wide beam SPECIFICATION: Dimensions Height Fastening 321.0 x 79.0 mm 9.4 mm screw Ingress protection classes ROHS compliant IP67 yes MATERIALS: Component Type Material Colour FLORENCE-3R-IP-Z60 Linear lens PC clear FLORENCE-3R-IP-SEAL Seal Silicone clear Finish ORDERING INFORMATION: Component FS15786_FLORENCE-3R-IP-Z60 » Box size: 356 x 356 x 292 mm Qty in box Linear lens 80 MOQ 80 MPQ 4 Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 13.0 1/9 PRODUCT DATASHEET FS15786_FLORENCE-3R-IP-Z60 See also our general installation guide: www.ledil.com/installation_guide Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET FS15786_FLORENCE-3R-IP-Z60 OPTICAL RESULTS (MEASURED): LED LUXEON 5050 Round LES FWHM / FWTM 62.5 + 60.0° / 108.5 + 116.0° Efficiency 87 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED SST-10-B130 FWHM / FWTM 61.0° / 104.0° Efficiency 88 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour Deep Red Required components: LED LinLED 280x55mm 1100lm 840 3x11 33V Opt G2 FWHM / FWTM 60.0 + 57.0° / 102.5 + 105.0° Efficiency 85 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LinLED 280x55mm 2000lm 830 33V Opt G1 FWHM / FWTM 60.0 + 57.0° / 102.0 + 105.5° Efficiency 85 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET FS15786_FLORENCE-3R-IP-Z60 OPTICAL RESULTS (MEASURED): LED NVSxx19B/NVSxx19C FWHM / FWTM 59.0° / 109.0° Efficiency 87 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S2 FWHM / FWTM 58.0° / 117.0° Efficiency 82 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S8 FWHM / FWTM 62.0° / 113.0° Efficiency 86 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 59.0° / 105.0° Efficiency 88 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET FS15786_FLORENCE-3R-IP-Z60 OPTICAL RESULTS (MEASURED): LED SEOUL 5630C FWHM / FWTM 59.0° / 103.0° Efficiency 87 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED SEOUL DC 3030 FWHM / FWTM 60.0 + 57.0° / 101.0 + 104.0° Efficiency 88 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LLE G2 55x280mm 2000lm FWHM / FWTM 59.0° / 105.0° Efficiency 88 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET FS15786_FLORENCE-3R-IP-Z60 OPTICAL RESULTS (SIMULATED): LED Bridgelux SMD 5050 FWHM / FWTM 79.0° / 123.0° Efficiency 83 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 60.0° / 102.0° Efficiency 92 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 59.0° / 102.0° Efficiency 92 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris E 2835 FWHM / FWTM 74.0° / 116.0° Efficiency 84 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET FS15786_FLORENCE-3R-IP-Z60 OPTICAL RESULTS (SIMULATED): LED Duris S10 FWHM / FWTM 74.0° / 120.0° Efficiency 82 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3030 FWHM / FWTM 64.0° / 96.0° Efficiency 90 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour Hyper Red Required components: LED OSCONIQ P 3737 (2W version) FWHM / FWTM 78.0° / 120.0° Efficiency 84 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LM302Z FWHM / FWTM 70.0 + 69.0° / 105.0° Efficiency 83 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET FS15786_FLORENCE-3R-IP-Z60 OPTICAL RESULTS (SIMULATED): LED LM302Z FWHM / FWTM 68.0 + 64.0° / 104.0 + 94.0° Efficiency 85 % Peak intensity 0.7 cd/lm LEDs/each optic 2 Light colour White Required components: LED Z8Y22 FWHM / FWTM 62.0° / 100.0° Efficiency 93 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22P FWHM / FWTM 63.0° / 101.0° Efficiency 93 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET FS15786_FLORENCE-3R-IP-Z60 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
FS15786_FLORENCE-3R-IP-Z60 价格&库存
很抱歉,暂时无法提供与“FS15786_FLORENCE-3R-IP-Z60”相匹配的价格&库存,您可以联系我们找货
  • 1+116.365351+15.13070
  • 4+52.229714+6.79130
  • 12+46.4940012+6.04550
  • 20+40.5844820+5.27710
库存:2
  • 1+108.19727
  • 4+48.54683
  • 12+43.18069
  • 20+37.75466
库存:2
