4FA11157_RES-O-90
4FA11157_RES-O-90
    LEDIL(芬兰)
4FA11157_RES-O-90 数据手册
LEDIL F’FORM OPTICS RES SQUARE lenses for LUXEON Rebel LEDs - - Designed & optimized for Luxeon Rebel series of LEDs Lens material optical grade PC with high UV and temperature resistance (120°C/248°F). Allows use of high current and temperature conditions Best available optical efficiency, up to 90%, with an extremely good cutoff of light Integrated holder. Fastening to heat sink with a PU foam adhesive tape of automotive grade Please check fastening details from this link: (http://www.ledil.com/datasheets/DataSheet_TAPE.pdf) Compact dimensions 21.6 x 21.6 mm. Square form enables easy build of matrix without any gaps between lenses. LENS TYPES NAME RE SQUARE REAL SPOT RE SQUARE SMOOTH SPOT RE SQUARE DIFFUSER RE SQUARE MEDIUM RE SQUARE WIDE RE SQUARE WIDE-V6 RE SQUARE OVAL RE SQUARE OVAL turned 90° ORDERING CODE FA10856_RES-RS FA10853_RES-SS FA10852_RES-D FA10851_RES-M FA10855_RES-W FA11675_RES-W-V6 FA10854_RES-O 4FA11157_RES-O-90 FWHM Angle ±4° ±6° ±8° ±15° ±17° ±27° ±6° x ±23° ±6° x ±23° © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2010-09-01 LEDIL F’FORM OPTICS MEASUREMENTS RES-RS RES-SS RES-D RES-M © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2010-09-01 LEDIL F’FORM OPTICS RES-O RES-W-V4 Relative Intensity of FA10855_RES-W-V4 100 % 75 % 50 % 25 % 0% 50 40 30 20 10 0 -10 -20 -30 -40 -50 RES-W-V6- © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2010-09-01 LEDIL F’FORM OPTICS PHOTOS RES-RS RES-SS RES-D RES-M RES-W RES-O © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2010-09-01 LEDIL F’FORM OPTICS DRAWING © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2010-09-01
4FA11157_RES-O-90 价格&库存
很抱歉,暂时无法提供与“4FA11157_RES-O-90”相匹配的价格&库存,您可以联系我们找货
