CA12090_VENLA-S-IRIS
    LEDIL(芬兰)
CA12090_VENLA-S-IRIS 数据手册
PRODUCT DATASHEET Venla series Ordering number C11773 Description C11773_Venla-S-Vega Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Venla Reflector Luxeon S Metal 45 mm 25 mm Round PC Clips Ready FWHM Efficiency cd/lm Gerber File 13 degrees Available Used with Tyco connector Ordering number C11775 Description C11775_Venla-M-Vega Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Venla Reflector Luxeon S Metal 45 mm 25 mm Round PC Clips Ready FWHM Efficiency cd/lm Gerber File 28 degrees Available Used with Tyco holder Ordering number C11776 Description C11776_Venla-W-Vega Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Venla Reflector Luxeon S Metal 45 mm 25 mm Round PC Clips Ready FWHM Efficiency cd/lm Gerber File 48 degrees Available Used with Tyco holder Ordering number C11777 Description C11777_Venla-WW-Vega Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Venla Reflector Luxeon S Metal 45 mm 25 mm Round PC Clips Ready FWHM Efficiency cd/lm Gerber File 56 degrees 87 % Available Used with Tyco connector August 4th 2011 13:58 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Venla series Ordering number CA12090 Description CA12090_Venla-S-Iris Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Venla Reflector Luxeon S Transparent 45 mm 27 mm Round PMMA Ready FWHM Efficiency cd/lm Gerber File 0 degrees Available NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. August 4th 2011 13:58 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Venla series GENERAL INFORMATION - Product series especially designed & optimized for Luxeon S series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PC with high UV and temperature resistance (120 degrees of Celcius / 248 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used materials from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PC%20Makrolon%202400_2407_2456_2458-UL .pdf - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (110 degrees of Celcius / 230 degrees of Fahrenheit). August 4th 2011 13:58 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2.25 Note A B C D 'Spot' CA12090_Venla-S-Iris is Spot reflector+ lens inside. Color WHITE. 40 Detail B Scale: 4:1 11 'Medium' 4 1 4 0.75 45 .2 A A 'Wide' 3 3 'WiderW' 25 2 Material: PC with metal coating and clear lacquer Part no's: C11773_Venla-S-Vega C11775_Venla-M-Vega C11776_Venla-W-Vega C11777_Venla-WW-Vega CA12090_Venla-S-Iris B 2 Tolerances: Dimensions less < 20mm +-0.1mm Dimensions between (21-45)mm +-0.2mm 1 This drawing is our property. It can't be reproduced or communicated without our written agreement. DRAWN BY DATE CHECKED BY DATE (27.2mm in S-IRIS) Bottom view 1.5 Section view A-A Led Teh FIN Fin DRAWING TITLE pv 15.04.2011 tk 27.12.2010 DESIGNED BY hh/ol/pl D DATE 06.10.2010 2 Datasheet Venla-series-Vega Reflector SIZE DRAWING NUMBER A4 SCALE 2:1 WEIGHT(g) REV - 1 SHEET A 1/1 1
CA12090_VENLA-S-IRIS 价格&库存
很抱歉,暂时无法提供与“CA12090_VENLA-S-IRIS”相匹配的价格&库存,您可以联系我们找货
