CP15212_CARMEN-S-B
CP15212_CARMEN-S-B
    LEDIL(芬兰)
CP15212_CARMEN-S-B 数据手册
PRODUCT DATASHEET CP15212_CARMEN-S-B CARMEN-S-B ~14° spot beam. Assembly with holder B compatible with Ø40 mm BJB and B+W connectors. SPECIFICATION: Dimensions Height Ø 69.5 mm 36.3 mm Fastening socket ROHS compliant yes MATERIALS: Component Type Material Colour Finish Length CARMEN-S Single lens PMMA clear 66.4 CARMEN-HLD-B Holder PC black 69.9 ORDERING INFORMATION: Component CP15212_CARMEN-S-B » Box size: 476 x 273 x 292 mm Qty in box Single lens 150 MOQ MPQ 150 15 Box weight (kg) 6.1 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/8 PRODUCT DATASHEET CP15212_CARMEN-S-B See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/8 PRODUCT DATASHEET CP15212_CARMEN-S-B OPTICAL RESULTS (MEASURED): LED V10 Gen7 FWHM / FWTM 14.0° / 34.0° Efficiency 74 % Peak intensity 6.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.6060 LED CLU700/701/702/703 FWHM / FWTM 10.0° / 25.0° Efficiency 77 % Peak intensity 12 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.6060 LED CXA/B 13xx FWHM / FWTM 9.0° / 24.0° Efficiency 81 % Peak intensity 13 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.6120 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/8 PRODUCT DATASHEET CP15212_CARMEN-S-B OPTICAL RESULTS (MEASURED): LED CXA/B 15xx FWHM / FWTM 14.0° / 33.0° Efficiency 75 % Peak intensity 7.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.6101 LED LC003D / LC006D / LC009D / LC013D FWHM / FWTM 15.0° / 35.0° Efficiency 77 % Peak intensity 6.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: A.A.G. STUCCHI: 8100-G2 LED LC003D / LC006D / LC009D / LC013D FWHM / FWTM 15.0° / 35.0° Efficiency 77 % Peak intensity 6.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.6060 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/8 PRODUCT DATASHEET CP15212_CARMEN-S-B OPTICAL RESULTS (MEASURED): LED MJT COB LES 6 FWHM / FWTM 10.0° / 25.0° Efficiency 77 % Peak intensity 12.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.6060 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/8 PRODUCT DATASHEET CP15212_CARMEN-S-B OPTICAL RESULTS (SIMULATED): LED V10 Gen6 FWHM / FWTM 14.0° / 30.0° Efficiency 76 % Peak intensity 8 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.6214 LED CLL02x/CLU02x (LES10) FWHM / FWTM 16.0° / 32.0° Efficiency 75 % Peak intensity 6.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.6060 LED CLU720/721/723 FWHM / FWTM 17.0° / 37.0° Efficiency 74 % Peak intensity 5.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/8 PRODUCT DATASHEET CP15212_CARMEN-S-B OPTICAL RESULTS (SIMULATED): LED COB S-Type (LES 7) FWHM / FWTM 12.0° / 24.0° Efficiency 80 % Peak intensity 11.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.6180 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/8 PRODUCT DATASHEET CP15212_CARMEN-S-B GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/8
CP15212_CARMEN-S-B 价格&库存
很抱歉,暂时无法提供与“CP15212_CARMEN-S-B”相匹配的价格&库存,您可以联系我们找货
