CP17570_YASMEEN-50-W-B-WHT 数据手册
PRODUCT
DATASHEET
YASMEEN-50-W-B-WHT
~36° spot beam. Assembly with holder B
compatible with Ø35 mm BJB and B+W
connectors. White version.
SPECIFICATION:
Dimensions
Height
ROHS compliant
Ø 49.9 mm
30.5 mm
yes
MATERIALS:
Component
Type
Material
Colour
YASMEEN-50-W
Single lens
PMMA
clear
YASMEEN-50-HLD-B-WHT
Holder
PC
white
Finish
ORDERING INFORMATION:
Component
» Box size: 476 x 273 x 305 mm
Qty in box
Single lens
252
MOQ
MPQ
112
28
Box weight (kg)
9.2
Last update: 13/02/2023
Subject to change without prior notice
Published: 21/10/2020
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/4
PRODUCT
DATASHEET
See also our general installation guide: www.ledil.com/installation_guide
2/4
PRODUCT
DATASHEET
OPTICAL RESULTS (SIMULATED):
LED
V10 Gen 8
FWHM / FWTM
36.0° / 58.0°
Efficiency
92 %
Peak intensity
2.3 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
BJB: 47.360.1020
LED
CLL02x/CLU02x (LES10)
FWHM / FWTM
36.0° / 56.0°
Efficiency
93 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
BJB: 47.360.1020
LED
CLU700/701/702/703
FWHM / FWTM
37.0° / 54.0°
Efficiency
94 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
BJB: 47.360.1020
LED
CMU10xx
FWHM / FWTM
36.0° / 56.0°
Efficiency
92 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
BJB: 47.360.1020
3/4
PRODUCT
DATASHEET
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
Due to use of high power COB's with this product, special attention to proper
thermal design is highly recommended. LEDiL has no liability for direct,
indirect or consecutive damages arising from the LEDiL products being used
outside of the recommended temperature range.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
4/4
CP17570_YASMEEN-50-W-B-WHT 价格&库存
很抱歉,暂时无法提供与“CP17570_YASMEEN-50-W-B-WHT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 112+35.90690112+4.63229
