C11612_ANNA-50-5-S-ES
    LEDIL(芬兰)
C11612_ANNA-50-5-S-ES 数据手册
PRODUCT DATASHEET Anna-50-5 series last update 13/2/2012 Ordering number C11613_ANNA-50-5-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Anna-50-5 Lens LUXEON Rebel ES Transparent 50 mm 10.7 mm Round PMMA Pin, glue Ready FWHM Efficiency cd/lm Gerber File 27 degrees 87 % 2.300 Available FWHM Efficiency cd/lm Gerber File 29 degrees 86 % 2.200 Available FWHM Efficiency cd/lm Gerber File 18 degrees 93 % 6.100 Available Ordering number C11614_ANNA-50-5-W Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Anna-50-5 Lens LUXEON Rebel ES Transparent 50 mm 10.7 mm Round PMMA Pin, glue Ready Ordering number C11612 Description C11612-Anna-50-5-S-RE-ES Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Anna-50-5 Lens LUXEON Rebel ES Transparent 50 mm 10.7 mm Round PMMA Pin, glue Ready NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. March 4th 2012 14:06 Copyright Ledil Oy - Subject to change without prior notice - Page 1/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Anna-50-5 series last update 13/2/2012 GENERAL INFORMATION - Product series especially designed & optimized for LUXEON Rebel ES series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf - Fastening to PCB with appropriate adhesive. By clicking link below you can find Ledil recommended glue options. http://www.ledil.com/datasheets/DataSheet_GLUES.pdf NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the glue. NOTE 2: All surfaces where glue is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer -this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. March 4th 2012 14:06 Copyright Ledil Oy - Subject to change without prior notice - Page 2/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 A B C D 4 12.2 4 2.9 Anna-3 Anna-4 Anna-7 49. 9 Anna-5 1.5 3 Same top side in all versions 3 0.8 Anna-6 Same location pin-circle in all versions 2 Material: PMMA 15 1 DATE DESIGNED BY hh DATE 30.07.2010 D Same led-circle in all versions Led Teh FIN Fin DRAWING TITLE Datasheet Anna50-series Lens pl 05.10.2010 tk 03.08.2010 8 CHECKED BY . DATE 5 DRAWN BY 2 This drawing is our property. It can't be reproduced or communicated without our written agreement. 2 1.96 Number of cones varies; 3, 4, 5, 6 and 7pcs on bottom side depending the version. 60 120 Versions: Anna-3-S Anna-3-M Anna-3-W Anna-4-S Anna-4-M Anna-4-W Anna-5-S Anna-5-M Anna-5-W Anna-6-S Anna-6-M Anna-6-W Anna-7-S Anna-7-M Anna-7-W SIZE DRAWING NUMBER A4 SCALE 1:1 WEIGHT(g) REV - 1 SHEET A 1/1 1
C11612_ANNA-50-5-S-ES 价格&库存
很抱歉,暂时无法提供与“C11612_ANNA-50-5-S-ES”相匹配的价格&库存,您可以联系我们找货
