C14605_HB-2X2-RW
C14605_HB-2X2-RW
    LEDIL(芬兰)
C14605_HB-2X2-RW 数据手册
PRODUCT DATASHEET C14605_HB-2X2-RW HB-2X2-RW ~50° wide beam optimized for CREE XP-L and XM-L SPECIFICATION: Dimensions Height Fastening ROHS compliant 50.0 x 50.0 mm 8.5 mm pin, screw yes MATERIALS: Component Type Material Colour HB-2X2-RW Multi-lens PMMA clear Finish ORDERING INFORMATION: Component C14605_HB-2X2-RW » Box size: 476 x 273 x 292 mm Qty in box 800 MOQ MPQ 160 160 Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 9.1 1/23 PRODUCT DATASHEET C14605_HB-2X2-RW See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (MEASURED): LED Bridgelux SMD 5050 FWHM / FWTM 56.0° / 89.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XD16 FWHM / FWTM 44.0° / 71.0° Efficiency 90 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XD16 FWHM / FWTM 54.0° / 85.0° Efficiency 92 % Peak intensity 0.9 cd/lm LEDs/each optic 4 Light colour White Required components: LED XHP35 HD FWHM / FWTM 53.0° / 82.0° Efficiency 84 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (MEASURED): LED XM-L3 FWHM / FWTM 52.0° / 79.0° Efficiency 95 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 45.0° / 73.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 48.0° / 75.0° Efficiency 86 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HI FWHM / FWTM 45.0° / 72.0° Efficiency 92 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (MEASURED): LED XP-L2 FWHM / FWTM 52.0° / 83.0° Efficiency 92 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 55.0° / 87.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON V FWHM / FWTM 52.0° / 81.0° Efficiency 93 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED SST-10-B130 FWHM / FWTM 44.0° / 70.0° Efficiency 96 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour Deep Red Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (MEASURED): LED RecLED 122x50mm 1900lm 730 2x4 Opt G1 FWHM / FWTM 46.0° / 72.5° Efficiency 97 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219F FWHM / FWTM 49.0° / 76.0° Efficiency 96 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219F FWHM / FWTM 48.0° / 76.0° Efficiency 94 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW319B FWHM / FWTM 50.0° / 79.0° Efficiency 94 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (MEASURED): LED NVSW3x9A FWHM / FWTM 50.0° / 78.0° Efficiency 93 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED PrevaLED Brick HP 2x8 FWHM / FWTM 49.0° / 72.0° Efficiency 94 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S8 FWHM / FWTM 56.0° / 89.0° Efficiency 95 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ C 3030 FWHM / FWTM 45.0° / 71.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (MEASURED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 49.0° / 72.0° Efficiency 94 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo FastFlex LED 2x8 DA G4 FWHM / FWTM 45.0° / 71.0° Efficiency 93 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo FastFlex LED 2x8 DA G4+ FWHM / FWTM 48.0° / 77.0° Efficiency 96 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM RC12 Z (LH181B) FWHM / FWTM 41.0° / 71.0° Efficiency 97 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (MEASURED): LED HiLOM RH12 Z (LH351C) FWHM / FWTM 48.0° / 75.0° Efficiency 96 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM RH16 (LH351C) FWHM / FWTM 48.0° / 75.0° Efficiency 94 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM RM12 Z (LH502C) FWHM / FWTM 55.0° / 88.0° Efficiency 95 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM RM16 Z (LH502C) FWHM / FWTM 55.0° / 89.0° Efficiency 96 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (MEASURED): LED HiLOM RM8 Z (LH502C) FWHM / FWTM 56.0° / 88.0° Efficiency 97 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351B FWHM / FWTM 45.0° / 74.0° Efficiency 86 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351D FWHM / FWTM 49.0° / 82.0° Efficiency 94 % LEDs/each optic 1 Light colour White Required components: LED LH508A FWHM / FWTM 56.0° / 87.0° Efficiency 93 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (MEASURED): LED LED-Pa-L15c2W11c2-xxx-C050-01 FWHM / FWTM 47.0° / 76.0° Efficiency 96 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED 2x2 Y22 module - SMJQ-D48W16AA-XX FWHM / FWTM 54.0° / 94.0° Efficiency 92 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M3 FWHM / FWTM 47.0° / 75.0° Efficiency 94 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M4 FWHM / FWTM 49.0° / 76.0° Efficiency 96 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (MEASURED): LED Z8Y19 FWHM / FWTM 54.0° / 94.0° Efficiency 92 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour White Required components: LED Z8Y19 FWHM / FWTM 54.0° / 94.0° Efficiency 92 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour White Required components: LED Z8Y22P FWHM / FWTM 48.0° / 77.0° Efficiency 92 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE 2x4 2000lm HP EXC2 OTD FWHM / FWTM 46.0° / 71.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (MEASURED): LED RLE 2x8 4000lm HP EXC2 OTD FWHM / FWTM 46.0° / 71.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE 2x8 6000lm HP HE EXC3 OTD FWHM / FWTM 53.0° / 86.0° Efficiency 96 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE G1 49x121mm 2000lm xxx EXC OTD FWHM / FWTM 46.0° / 73.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE G1 49x133mm 2000lm xxx EXC OTD FWHM / FWTM 46.0° / 73.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (MEASURED): LED RLE G1 49x223mm 4000lm xxx EXC OTD FWHM / FWTM 46.0° / 73.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE G1 49x245mm 4000lm xxx EXC OTD FWHM / FWTM 46.0° / 73.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (SIMULATED): LED XHP35 HI FWHM / FWTM 52.0° / 68.0° Efficiency 93 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L FWHM / FWTM 54.0° / 74.0° Efficiency 92 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 52.0° / 74.0° Efficiency 89 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED XP-L HD FWHM / FWTM 55.0° / 79.0° Efficiency 93 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (SIMULATED): LED XP-L HD FWHM / FWTM 56.0° / 78.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED XP-L HI FWHM / FWTM 48.0° / 72.0° Efficiency 90 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED XP-L2 FWHM / FWTM 58.0° / 82.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED XP-P FWHM / FWTM 40.0° / 66.0° Efficiency 91 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (SIMULATED): LED LUXEON HL2X FWHM / FWTM 50.0° / 76.0° Efficiency 94 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON HL2X-D FWHM / FWTM 56.0° / 76.0° Efficiency 88 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LUXEON HL2X-D FWHM / FWTM 56.0° / 76.0° Efficiency 96 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON HL2X-P FWHM / FWTM 54.0° / 80.0° Efficiency 94 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (SIMULATED): LED LUXEON HL2Z FWHM / FWTM 46.0° / 66.0° Efficiency 94 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON XR-HL2X (L2H2-xxxxxxxMLU010) FWHM / FWTM 54.0° / 76.0° Efficiency 96 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON XR-HL2X (L2H2-xxxxxxxMLU010) FWHM / FWTM 54.0° / 76.0° Efficiency 88 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED NV4WB35AM FWHM / FWTM 56.0° / 74.0° Efficiency 95 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (SIMULATED): LED NVSW219D FWHM / FWTM 54.0° / 75.0° Efficiency 95 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S8 FWHM / FWTM 57.0° / 83.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED OSCONIQ C 2424 FWHM / FWTM 45.0° / 62.0° Efficiency 96 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3030 FWHM / FWTM 42.0° / 64.0° Efficiency 96 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 3737 (2W version) FWHM / FWTM 45.0° / 68.0° Efficiency 96 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 (3W version) FWHM / FWTM 52.0° / 72.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 Flat FWHM / FWTM 50.0° / 68.0° Efficiency 96 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 50.0° / 72.0° Efficiency 87 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (SIMULATED): LED OSLON Square Flat FWHM / FWTM 43.0° / 64.0° Efficiency 96 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSTAR Projection Compact (KW.CSLNM1.TG) FWHM / FWTM 42.0° / 64.0° Efficiency 96 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo FastFlex LED 2x8 DAX G4 FWHM / FWTM 51.0° / 73.0° Efficiency 94 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM RM16 Z (LH502C) FWHM / FWTM 56.0° / 90.0° Efficiency 89 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/23 PRODUCT DATASHEET C14605_HB-2X2-RW OPTICAL RESULTS (SIMULATED): LED SEOUL DC 5050 6V FWHM / FWTM 54.0° / 79.0° Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22T FWHM / FWTM 51.0° / 69.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/23 PRODUCT DATASHEET C14605_HB-2X2-RW GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/23
C14605_HB-2X2-RW
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光隔离型光电晶体管。
2. 器件简介:EL817是一种光隔离型光电晶体管,具有高输入阻抗和低输出阻抗,适用于高速光耦合器。
3. 引脚分配:EL817有3个引脚,分别为阳极、阴极和发射极。
4. 参数特性:主要参数包括最大正向电流、最大反向电压等。
5. 功能详解:EL817通过光电效应实现电信号的传输,具有隔离作用,可应用于数字信号传输。
6. 应用信息:EL817可用于高速光耦合器、数字信号传输等领域。
7. 封装信息:EL817采用DIP-6封装。
C14605_HB-2X2-RW 价格&库存
很抱歉,暂时无法提供与“C14605_HB-2X2-RW”相匹配的价格&库存,您可以联系我们找货
C14605_HB-2X2-RW
