CA10864_TITANUM-O-C
CA10864_TITANUM-O-C
    LEDIL(芬兰)
    LENS FOR OSRAM DRAGON
CA10864_TITANUM-O-C 数据手册
LEDIL F’FORM OPTICS FULLY SEALABLE TITANUM lenses for Dragon - - Use with all Osram Dragon series of white and monochromate LEDs, both OLD and NEW package types NEW smooth spot and oval versions with improved efficiency and color uniformity also compatible with the new Dragon package Lens material optical grade PMMA with high UV and temperature resistance (105°C/220°F) High optical efficiency, up to 90% No lens holder. Fastening to heat sink with a PU foam adhesive tape of automotive grade Lens foot can be potted with resin without losses in optical efficiency (fully sealed construction of luminaire possible) Diameter 26 mm (approximately 1”) Easy build of a complete luminaire using TITANUM, Dragon and heat sink All lens types have the same outer dimensions, which allow a cross use of them in the same lighting fixture. LENS TYPES NAME ORDERING CODE Titanum smooth spot Titanum smooth spot metallized Titanum medium Titanum oval Titanum oval metallized Titanum oval (90°) Titanum oval metallized (90°) Titanum wide CA10318_Titanum-O-SS CA10968_Titanum-O-SS_MetalPlated CA10252_Titanum-O-M CA10319_Titanum-O-O CA10864_Titanum-O-OC CA11240_Titanum-O-O-90 CA11241_Titanum-O-OC-90 CA10244_Titanum-O-W FWHM Angle ±7° ±7° ±13° ±3° x ±18° ±3° x ±18° ±3° x ±18° ±3° x ±18° ±35° SMOOTH SPOT lens is a pure collimator lens with light mixing properties. It smoothens the beam pattern and makes a uniform color distribution over the whole beam angle. Light intensity is lower than for the REAL SPOT lens. SMOOTH SPOT lens is recommended for white light applications, where pleasant, high-quality illumination is wished. OVAL lens is optimal for cases where a narrow stripe of light is wished. If a wider vertical distribution is needed, please consider LEDIL OSS-O with wider vertical distribution and a color mixing structure. © Ledil Oy – Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-12-21 LEDIL F’FORM OPTICS MEASUREMENTS TITANUM-SS TITANUM-M TITANUM-O TITANUM-W © Ledil Oy – Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-12-21 LEDIL F’FORM OPTICS PHOTOGRAPHS TITANUM-SS TITANUM-O TITANUM-M TITANUM-W DIMENSIONS TITANUM-SS and TITANUM-M TITANUM-O TITANUM-W © Ledil Oy – Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-12-21 LEDIL F’FORM OPTICS PACKAGING Lenses are packed on plastic trays of 77 lenses. One box contains 13 trays, i.e. 1001 lenses. SPECIAL VERSIONS Special versions available on request, e.g. fully metallized outer surface allowing full potting of lens up to the top surface or different packing methods. © Ledil Oy – Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-12-21 LEDIL F’FORM OPTICS DRAWINGS © Ledil Oy – Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-12-21
CA10864_TITANUM-O-C 价格&库存
很抱歉,暂时无法提供与“CA10864_TITANUM-O-C”相匹配的价格&库存,您可以联系我们找货
