CA10932_FLARE-B
CA10932_FLARE-B
    LEDIL(芬兰)
CA10932_FLARE-B 数据手册
PRODUCT DATASHEET CA10932_FLARE-B FLARE-B 29 x 23 mm lens with ~100° x 10° oval beam. Assembly with installation tape. SPECIFICATION: Dimensions Height Fastening ROHS compliant 29.0 x 22.8 mm 12.8 mm tape, screw yes MATERIALS: Component Type Material Colour FLARE-B Single lens PMMA clear FLARE-B-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA10932_FLARE-B » Box size: 476 x 273 x 292 mm Single lens Qty in box MOQ MPQ 2448 288 144 Box weight (kg) 9.8 Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/14 PRODUCT DATASHEET CA10932_FLARE-B See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/14 PRODUCT DATASHEET CA10932_FLARE-B OPTICAL RESULTS (MEASURED): LED XB-D FWHM / FWTM 10.0 + 108.0° / 30.0 + 167.0° Efficiency 93 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E FWHM / FWTM 102.0 + 10.0° / 154.0 + 26.0° Efficiency 93 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 11.0 + 101.0° / 22.0 + 150.0° Efficiency 94 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel FWHM / FWTM 101.0 + 14.0° / 142.0 + 29.0° Efficiency 93 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/14 PRODUCT DATASHEET CA10932_FLARE-B OPTICAL RESULTS (MEASURED): LED LUXEON Rebel ES FWHM / FWTM 12.0 + 104.0° / 35.0 + 154.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON T FWHM / FWTM 13.0 + 105.0° / 29.0 + 152.0° Efficiency 93 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 14.0 + 114.0° / 29.0 + 156.0° Efficiency 93 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxx19A FWHM / FWTM 9.0 + 88.0° / 26.0 + 154.0° Efficiency 94 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/14 PRODUCT DATASHEET CA10932_FLARE-B OPTICAL RESULTS (MEASURED): LED NCSxx19B FWHM / FWTM 11.0 + 103.0° / 28.0 + 160.0° Efficiency 94 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219F FWHM / FWTM 15.0 + 108.0° / 28.0 + 150.0° Efficiency 94 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 14.0 + 110.0° / 27.0 + 151.0° Efficiency 94 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square EC FWHM / FWTM 13.0 + 104.0° / 26.0 + 157.0° Efficiency 94 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/14 PRODUCT DATASHEET CA10932_FLARE-B OPTICAL RESULTS (MEASURED): LED OSLON Square EC FWHM / FWTM 12.0 + 104.0° / 33.0 + 162.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 150 FWHM / FWTM 9.0 + 117.0° Efficiency 93 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 80 FWHM / FWTM 83.0 + 11.0° / 144.0 + 24.0° Efficiency 93 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED WICOP 5050 FWHM / FWTM 26.0 + 111.0° / 44.0 + 159.0° Efficiency 97 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/14 PRODUCT DATASHEET CA10932_FLARE-B OPTICAL RESULTS (MEASURED): LED Z5 FWHM / FWTM 12.0 + 96.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED Z5M3 FWHM / FWTM 15.0 + 108.0° / 30.0 + 161.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Double Dome (GM2BB) FWHM / FWTM 104.0 + 10.0° Efficiency % LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/14 PRODUCT DATASHEET CA10932_FLARE-B OPTICAL RESULTS (SIMULATED): LED XP-E2 FWHM / FWTM 82.0 + 8.0° / 140.0 + 16.0° Efficiency 97 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour Blue Required components: LED XP-G2 FWHM / FWTM 11.0 + 83.0° / 21.0 + 146.0° Efficiency 94 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 99.0 + 14.0° / 153.0 + 26.0° Efficiency 95 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HD FWHM / FWTM 106.0 + 16.0° / 151.0 + 30.0° Efficiency 97 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/14 PRODUCT DATASHEET CA10932_FLARE-B OPTICAL RESULTS (SIMULATED): LED LUXEON C FWHM / FWTM 83.0 + 8.0° / 169.0 + 16.0° Efficiency 94 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour Blue Required components: LED LUXEON CZ FWHM / FWTM 6.0 + 54.0° / 15.0 + 134.0° Efficiency 97 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour Red Required components: LED LUXEON H50-2 FWHM / FWTM 13.0 + 90.0° / 22.0 + 140.0° Efficiency 94 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rubix FWHM / FWTM 62.0 + 6.0° / 141.0 + 13.0° Efficiency 97 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/14 PRODUCT DATASHEET CA10932_FLARE-B OPTICAL RESULTS (SIMULATED): LED LUXEON Rubix FWHM / FWTM 60.0 + 6.0° / 140.0 + 12.0° Efficiency 97 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour Blue Required components: LED LUXEON Rubix FWHM / FWTM 61.0 + 6.0° / 140.0 + 12.0° Efficiency 97 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour Green Required components: LED LUXEON Rubix FWHM / FWTM 52.0 + 6.0° / 134.0 + 12.0° Efficiency 97 % Peak intensity 4.5 cd/lm LEDs/each optic 1 Light colour Red Required components: LED LUXEON Z ES FWHM / FWTM 8.0 + 84.0° / 16.0 + 142.0° Efficiency 97 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/14 PRODUCT DATASHEET CA10932_FLARE-B OPTICAL RESULTS (SIMULATED): LED SFT-40-WCS FWHM / FWTM 88.0 + 10.0° / 145.0 + 20.0° Efficiency 97 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFT-70X-WCS FWHM / FWTM 96.0 + 14.0° / 148.0 + 23.0° Efficiency 98 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 (3W version) FWHM / FWTM 94.0 + 16.0° / 150.0 + 28.0° Efficiency 97 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Signal FWHM / FWTM 8.0 + 81.0° / 15.0 + 148.0° Efficiency 97 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/14 PRODUCT DATASHEET CA10932_FLARE-B OPTICAL RESULTS (SIMULATED): LED OSLON Signal FWHM / FWTM 8.0 + 80.0° / 14.0 + 148.0° Efficiency 97 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Signal FWHM / FWTM 75.0 + 8.0° / 143.0 + 16.0° Efficiency 97 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour Blue Required components: LED OSLON Signal FWHM / FWTM 8.0 + 79.0° / 16.0 + 148.0° Efficiency 97 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351C FWHM / FWTM 97.0 + 16.0° / 137.0 + 27.0° Efficiency 97 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/14 PRODUCT DATASHEET CA10932_FLARE-B OPTICAL RESULTS (SIMULATED): LED Z5M1/Z5M2 FWHM / FWTM 93.0 + 12.0° / 143.0 + 22.0° Efficiency 97 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/14 PRODUCT DATASHEET CA10932_FLARE-B GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/14
CA10932_FLARE-B 价格&库存
很抱歉,暂时无法提供与“CA10932_FLARE-B”相匹配的价格&库存,您可以联系我们找货
