CA13509_STRADA-SQ-T2
    LEDIL(芬兰)
CA13509_STRADA-SQ-T2 数据手册
PRODUCT DATASHEET Strada-SQ series last update 3/10/2013 Ordering number C12726_STRADA-SQ-T-DWC Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Strada-SQ Lens LUXEON M Clear 25 x 25 mm 8 mm Square PMMA Screw, pin, glue On production FWHM Efficiency cd/lm Gerber File Asym degrees 94 % 0.450 Available Ordering number CA12889_STRADA-SQ-T-DWC Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Strada-SQ Assembly LUXEON M Clear 25 x 25 mm 8.15 mm Square PMMA Screw, pin, tape On production FWHM Efficiency cd/lm Gerber File Asym degrees 94 % 0.450 Available October 3rd 2013 17:42 Copyright Ledil Oy - Subject to change without prior notice - Page 1/5 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Strada-SQ series last update 3/10/2013 Ordering number C13118_STRADA-SQ-A-T Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Strada-SQ Lens LUXEON M Clear 25 + 25 mm 9 mm Square PMMA Screw, pin, glue On production FWHM Efficiency cd/lm Gerber File Asym degrees 93 % 0.300 Available FWHM Efficiency cd/lm Gerber File Asym degrees 93 % 0.300 Available FWHM Efficiency cd/lm Gerber File Asym degrees 93 % 0.600 Available Ordering number CA13119_STRADA-SQ-A-T Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Strada-SQ Assembly LUXEON M Clear 25 + 25 mm 9.1 mm Square PMMA Screw, pin, tape On production Ordering number CA13509_STRADA-SQ-T2 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Strada-SQ Assembly LUXEON M Black 25 x 25 mm 8.7 mm Square PMMA Screw, pin, tape On production We recommend a minimum center to center spacing between S Ordering number CA13688_STRADA-SQ-T3 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Strada-SQ Assembly LUXEON M Clear 25 x 25 mm 8.4 mm Square PMMA Pin, tape On production FWHM Efficiency cd/lm Gerber File Asym degrees 92 % 0.500 Available We recommend a minimum center to center spacing between S October 3rd 2013 17:42 Copyright Ledil Oy - Subject to change without prior notice - Page 2/5 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Strada-SQ series last update 3/10/2013 Ordering number C13866_STRADA-SQ-CY Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Strada-SQ Lens LUXEON M Clear 25x25 mm 10.1 mm Square PMMA Pin On production FWHM Efficiency cd/lm Gerber File 120+115 degrees 94 % 0.410 Available FWHM Efficiency cd/lm Gerber File 154 degrees 93 % 0.250 Available FWHM Efficiency cd/lm Gerber File 154 degrees 93 % 0.250 Available FWHM Efficiency cd/lm Gerber File Asym degrees 93 % (simulated) 0.000 Available Ordering number C12727_STRADA-SQ-VSM Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Strada-SQ Lens LUXEON M Clear 25 x 25 mm 6.8 mm Square PMMA Screw, pin, glue On production Ordering number CA12891_STRADA-SQ-VSM Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Strada-SQ Assembly LUXEON M Clear 25 x 25 mm 6.95 mm Square PMMA Screw, pin, tape On production Ordering number C12410 Description 1 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Strada-SQ Lens LUXEON M Clear 25 + 25 mm 9 mm Square PMMA On production Positioning: External position element / Automatic assembling li October 3rd 2013 17:42 Copyright Ledil Oy - Subject to change without prior notice - Page 3/5 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Strada-SQ series last update 3/10/2013 Ordering number CA12411 Description 1 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Strada-SQ Assembly LUXEON M Clear 25 + 25 mm 9.15 mm Square PMMA On production FWHM Efficiency cd/lm Gerber File Asym degrees 93 % 0.410 Available Positioning: External position element / Automatic assembling li NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. October 3rd 2013 17:42 Copyright Ledil Oy - Subject to change without prior notice - Page 4/5 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Strada-SQ series last update 3/10/2013 GENERAL INFORMATION - Product series especially designed & optimized for LUXEON M series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance. Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf October 3rd 2013 17:42 Copyright Ledil Oy - Subject to change without prior notice - Page 5/5 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 Absolute intensity of C12726&CA12889_STRADA-SQ-T-DWC (Luxeon M) cd/klm 500,00 400,00 300,00 200,00 100,00 0,00 90 80 70 60 50 40 30 20 10 0 C000-C180 -10 -20 C90-C270 -30 -40 -50 -60 -70 -80 -90 Absolute intensity of C12726&CA12889_STRADA-SQ-T-DWC (Luxeon M) cd/klm 500,00 400,00 300,00 200,00 100,00 0,00 90 80 70 60 50 40 30 20 10 0 C000-C180 -10 -20 C90-C270 -30 -40 -50 -60 -70 -80 -90 A B C D 4 4 Bottom view 3 9 3 Isometric view 25 Front view 2 2 Tolerances if not otherwise shown: According to DIN ISO 2768-1 Linear measures: Up to 30mm class F, otherwise class M. 25 According to DIN ISO 2768-2 Form and position: class K Top view Control for SPC marked dimensions. This drawing is our property. It can't be reproduced or communicated without our written agreement. 1 DRAWN BY as DATE Ledil Oy Salorankatu 10 FIN 24240 SALO Finland DRAWING TITLE 25.9.2012 CHECKED BY DATE SIZE - DESIGNED BY DATE A4 vs - - D SCALE Mechanical drawing STRADA-SQ-A-T 1 PART NUMBER REV 001 2:1 WEIGHT 4,97 g SHEET A 1/1
CA13509_STRADA-SQ-T2 价格&库存
很抱歉,暂时无法提供与“CA13509_STRADA-SQ-T2”相匹配的价格&库存,您可以联系我们找货
