CP15309_LARISA-RZ-PIN
    LEDIL(芬兰)
CP15309_LARISA-RZ-PIN 数据手册
PRODUCT DATASHEET CP15309_LARISA-RZ-PIN LARISA-RZ-PIN ~25° diffused beam and holder with location pins SPECIFICATION: Dimensions Height Fastening ROHS compliant 9.9 x 9.9 mm 7.5 mm glue, pin yes MATERIALS: Component Type Material Colour LARISA-RZ Single lens PMMA clear LARISA-HOLDER-PIN Holder PC black Finish ORDERING INFORMATION: Component CP15309_LARISA-RZ-PIN » Box size: 300 x 250 x 250 mm Single lens Qty in box MOQ MPQ 10000 300 100 Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 7.1 1/6 PRODUCT DATASHEET CP15309_LARISA-RZ-PIN See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/6 PRODUCT DATASHEET CP15309_LARISA-RZ-PIN OPTICAL RESULTS (MEASURED): LED XD16 FWHM / FWTM 26.0° / 57.0° Efficiency 66 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HD FWHM / FWTM 24.0° / 53.0° Efficiency 77 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HI FWHM / FWTM 22.0° / 47.0° Efficiency 72 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON C FWHM / FWTM 26.0° / 51.0° Efficiency 73 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/6 PRODUCT DATASHEET CP15309_LARISA-RZ-PIN OPTICAL RESULTS (MEASURED): LED LUXEON Z FWHM / FWTM 21.0° / 47.0° Efficiency 74 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Z ES FWHM / FWTM 26.0° / 62.0° Efficiency 71 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxE17A FWHM / FWTM 26.0° / 60.0° Efficiency 60 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM 28.0° / 65.0° Efficiency 60 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/6 PRODUCT DATASHEET CP15309_LARISA-RZ-PIN OPTICAL RESULTS (MEASURED): LED Duris S5 (2 chip) FWHM / FWTM 32.0° / 70.0° Efficiency 72 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/6 PRODUCT DATASHEET CP15309_LARISA-RZ-PIN GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/6
CP15309_LARISA-RZ-PIN 价格&库存
很抱歉,暂时无法提供与“CP15309_LARISA-RZ-PIN”相匹配的价格&库存,您可以联系我们找货
