F14622_ANGELETTE-WW-PLAIN
    LEDIL(芬兰)
    REFLECTOR ROUND 1 POS 110MM (D)
F14622_ANGELETTE-WW-PLAIN 数据手册
PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN ANGELETTE-WW-PLAIN ~60° wide beam. Clean appearance with no additional attachment interface. SPECIFICATION: Dimensions Ø 110.0 mm Height 57.3 mm Fastening socket ROHS compliant yes MATERIALS: Component Type Material Colour ANGELETTE-WW-PLAIN Reflector PC metal Finish Coating HMDS ORDERING INFORMATION: Component F14622_ANGELETTE-WW-PLAIN » Box size: 398 x 298 x 265 mm Qty in box 120 MOQ MPQ 90 30 Box weight (kg) 5.3 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED V13 Gen7 FWHM / FWTM 64.0° / 86.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213254-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED V13 Gen7 FWHM / FWTM 59.0° / 80.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213254-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED V22 Gen6 FWHM / FWTM 65.0° / 88.0° Efficiency 85 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS IDEAL: 50-2204-CT + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED V22 Gen6 FWHM / FWTM 63.0° / 83.0° Efficiency 89 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2204-CT + 50-2100AN LED VERO13 FWHM / FWTM 60.0° / 82.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 LED VERO18 FWHM / FWTM 66.0° / 84.0° Efficiency 89 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED VERO29 FWHM / FWTM 69.0° / 94.0° Efficiency 85 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13584_CLAMP-VERO29 F13671_ANGE-RZ-LENS LED VERO29 FWHM / FWTM 68.0° / 89.0° Efficiency 90 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13584_CLAMP-VERO29 LED Vesta TW 15mm DP FWHM / FWTM 66.0° / 86.0° Efficiency 84 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13658_CLAMP-VERO13-18 F13671_ANGE-RZ-LENS Bender Wirth: 482 Typ L2 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED Vesta TW 15mm DP FWHM / FWTM 65.0° / 82.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 482 Typ L2 LED Vesta TW 18mm (31W) DP FWHM / FWTM 67.0° / 88.0° Efficiency 84 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13584_CLAMP-VERO29 F13671_ANGE-RZ-LENS Bender Wirth: 483 Typ L3 LED Vesta TW 18mm (31W) DP FWHM / FWTM 66.0° / 83.0° Efficiency 89 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13584_CLAMP-VERO29 Bender Wirth: 483 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED Vesta TW 22mm DP FWHM / FWTM 66.0° / 88.0° Efficiency 84 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13584_CLAMP-VERO29 F13671_ANGE-RZ-LENS Bender Wirth: 494 Typ L3 LED Vesta TW 22mm DP FWHM / FWTM 65.0° / 83.0° Efficiency 88 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13584_CLAMP-VERO29 Bender Wirth: 494 Typ L3 LED CLL03x/CLU03x FWHM / FWTM 61.0° / 81.0° Efficiency 89 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213254-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED CLL03x/CLU03x FWHM / FWTM 59.0° / 80.0° Efficiency 89 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2103CT + 50-2100AN LED CLL04x/CLU04x FWHM / FWTM 63.0° / 83.0° Efficiency 89 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2204-CT + 50-2100AN LED CLU730/731/733 FWHM / FWTM 57.0° / 79.0° Efficiency 89 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2204-CT + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED CXA/B 15xx FWHM / FWTM 66.0° / 88.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14123_CLAMP-CXA15-18 F13671_ANGE-RZ-LENS LED CXA/B 15xx FWHM / FWTM 55.0° / 81.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14123_CLAMP-CXA15-18 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 63.0° / 85.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213401-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 68.0° / 89.0° Efficiency 86 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14123_CLAMP-CXA15-18 F13671_ANGE-RZ-LENS LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 64.0° / 83.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14123_CLAMP-CXA15-18 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 58.0° / 80.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213401-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED CXA/B 25xx FWHM / FWTM 65.0° / 84.0° Efficiency 89 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14036_CLAMP_CXA25-30 LED CXA/B 25xx FWHM / FWTM 67.0° / 90.0° Efficiency 85 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14036_CLAMP_CXA25-30 F13671_ANGE-RZ-LENS LED CXA/B 30xx FWHM / FWTM 67.0° / 91.0° Efficiency 86 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14036_CLAMP_CXA25-30 F13671_ANGE-RZ-LENS Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED CXA/B 30xx FWHM / FWTM 66.0° / 86.0° Efficiency 90 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14036_CLAMP_CXA25-30 LED LUXEON CoB 1208 FWHM / FWTM 63.0° / 85.0° Efficiency 84 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS IDEAL: 50-2204-CT + 50-2100AN LED LUXEON CoB 1208 FWHM / FWTM 64.0° / 86.0° Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213130-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1208 FWHM / FWTM 61.0° / 81.0° Efficiency 89 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213130-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED LUXEON CoB 1208 FWHM / FWTM 61.0° / 80.0° Efficiency 89 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2100SH + 50-2100AN LED LUXEON CoB 1211 FWHM / FWTM 63.0° / 82.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2204-CT + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1211 FWHM / FWTM 64.0° / 87.0° Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS IDEAL: 50-2204-CT + 50-2100AN LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 63.0° / 84.0° Efficiency 89 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2204-CT + 50-2100AN LED COB L-Type (LES 11) FWHM / FWTM 53.0° / 79.0° Efficiency 89 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213382-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED COB L-Type (LES 11) FWHM / FWTM 51.0° / 77.0° Efficiency 88 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2100NC + 50-2100AN LED PrevaLED Core Z4 LES19 FWHM / FWTM 62.0° / 81.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: OPTIC CLIP Z50 TYPE1 2213194-1 LED PrevaLED Core Z4 LES19 FWHM / FWTM 64.0° / 86.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213130-2 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED Soleriq S13 19x19 FWHM / FWTM 56.0° / 79.0° Efficiency 88 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2103CT + 50-2100AN LED Soleriq S13 19x19 FWHM / FWTM 56.0° / 80.0° Efficiency 89 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213254-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED Soleriq S19 FWHM / FWTM 63.0° / 82.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213407-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED Soleriq S19 FWHM / FWTM 65.0° / 87.0° Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213407-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED Fortimo SLM L15 + SLM holder FWHM / FWTM 62.0° / 81.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213134-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED LC035T (Tunable white) FWHM / FWTM 66.0° / 89.0° Efficiency 84 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13584_CLAMP-VERO29 F13671_ANGE-RZ-LENS Bender Wirth: 502 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED LC035T (Tunable white) FWHM / FWTM 65.0° / 84.0° Efficiency 89 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13584_CLAMP-VERO29 Bender Wirth: 502 Typ L3 LED LC040C FWHM / FWTM 53.0° / 79.0° Efficiency 89 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213382-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED AC Zhaga COB FWHM / FWTM 71.0° / 92.0° Efficiency 85 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS Optosource: SEHSMJD-A Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (MEASURED): LED AC Zhaga COB FWHM / FWTM 70.0° / 87.0° Efficiency 89 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Optosource: SEHSMJD-A LED WU-M-484 FWHM / FWTM 56.0° / 81.0° Efficiency 89 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: OPTIC CLIP Z50 TYPE1 2213194-1 LED XIM - 19mm LES FWHM / FWTM 66.0° / 84.0° Efficiency 90 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16491_XTM-ADAPTER-50-A Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN OPTICAL RESULTS (SIMULATED): LED V13 Gen7 FWHM / FWTM 51.0° / 79.0° Efficiency 90 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 477 Typ L1 LED V22 Gen7 FWHM / FWTM 55.0° / 78.0° Efficiency 94 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2204-CT + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/21 PRODUCT DATASHEET F14622_ANGELETTE-WW-PLAIN GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/21
F14622_ANGELETTE-WW-PLAIN 价格&库存
很抱歉,暂时无法提供与“F14622_ANGELETTE-WW-PLAIN”相匹配的价格&库存,您可以联系我们找货
  • 30+72.6797330+9.42068
