FP11055_LISA2-RS-PIN
    LEDIL(芬兰)
FP11055_LISA2-RS-PIN 数据手册
PRODUCT DATASHEET FP11055_LISA2-RS-PIN LISA2-RS-PIN ~19° spot beam. 6.8 mm high variant with location pin installation. SPECIFICATION: Dimensions Height Fastening ROHS compliant Ø 9.9 mm 6.8 mm glue, pin yes MATERIALS: Component Type Material Colour Finish Length LISA2-RS Single lens PMMA clear 9.9 LISA2-HLD-PIN Holder PC black 9.9 ORDERING INFORMATION: Component FP11055_LISA2-RS-PIN » Box size: 310 x 230 x 60 mm Single lens Qty in box MOQ MPQ 2000 300 100 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 1.4 1/11 PRODUCT DATASHEET FP11055_LISA2-RS-PIN See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/11 PRODUCT DATASHEET FP11055_LISA2-RS-PIN OPTICAL RESULTS (MEASURED): LED XD16 FWHM / FWTM 15.0° / 42.0° Efficiency 70 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G FWHM / FWTM 24.0° Efficiency 90 % LEDs/each optic 1 Light colour/type White Required components: LED XQ-E HI FWHM / FWTM 11.0° / 27.0° Efficiency 86 % Peak intensity 11.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/11 PRODUCT DATASHEET FP11055_LISA2-RS-PIN OPTICAL RESULTS (MEASURED): LED LUXEON Z ES FWHM / FWTM 15.0° / 38.0° Efficiency 84 % Peak intensity 6.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NCSxE17A FWHM / FWTM 13.0° / 43.0° Efficiency 72 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SFH 4180S FWHM / FWTM 9.0° / 24.0° Efficiency % LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/11 PRODUCT DATASHEET FP11055_LISA2-RS-PIN OPTICAL RESULTS (MEASURED): LED LH181B FWHM / FWTM 16.0° / 50.0° Efficiency 71 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Double Dome (GM2BB) FWHM / FWTM 18.0° Efficiency 90 % LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/11 PRODUCT DATASHEET FP11055_LISA2-RS-PIN OPTICAL RESULTS (SIMULATED): LED CSP 2323 (BXCP) FWHM / FWTM 16.0° / 44.0° Efficiency 77 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XQ-A FWHM / FWTM 10.0° / 20.0° Efficiency 90 % Peak intensity 21.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XQ-E HD FWHM / FWTM 14.5° / 28.5° Efficiency 91 % Peak intensity 10.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/11 PRODUCT DATASHEET FP11055_LISA2-RS-PIN OPTICAL RESULTS (SIMULATED): LED LUXEON IR 2720 FWHM / FWTM 14.0° / 34.0° Efficiency 88 % LEDs/each optic 1 Light colour/type IR Required components: LED LUXEON Z ES FWHM / FWTM 16.0° / 34.0° Efficiency 91 % Peak intensity 7.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SST-10-IR-B90 FWHM / FWTM 18.0° / 40.0° Efficiency 89 % LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/11 PRODUCT DATASHEET FP11055_LISA2-RS-PIN OPTICAL RESULTS (SIMULATED): LED OSLON Black Flat (LUW HWQP) FWHM / FWTM 12.0° / 28.0° Efficiency 89 % Peak intensity 11.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Pure 1414 FWHM / FWTM 14.0 + 13.0° / 26.0° Efficiency 93 % Peak intensity 12.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square EC FWHM / FWTM 18.0° / 40.0° Efficiency 90 % Peak intensity 5.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/11 PRODUCT DATASHEET FP11055_LISA2-RS-PIN OPTICAL RESULTS (SIMULATED): LED OSLON SSL 150 FWHM / FWTM 16.0° / 32.0° Efficiency 92 % Peak intensity 9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON SSL 80 FWHM / FWTM 16.0° / 35.0° Efficiency 90 % Peak intensity 7.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SFH 4170S FWHM / FWTM 10.0° / 22.0° Efficiency 77 % LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/11 PRODUCT DATASHEET FP11055_LISA2-RS-PIN OPTICAL RESULTS (SIMULATED): LED SFH 4770S FWHM / FWTM 13.0° / 31.0° Efficiency 88 % LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/11 PRODUCT DATASHEET FP11055_LISA2-RS-PIN GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/11
FP11055_LISA2-RS-PIN 价格&库存
很抱歉,暂时无法提供与“FP11055_LISA2-RS-PIN”相匹配的价格&库存,您可以联系我们找货
  • 1+15.66722
  • 100+12.49305
  • 300+11.84624
  • 500+10.99580
    • 1+20.775551+2.69864
    • 10+14.9622310+1.94352
    • 100+11.48158100+1.49140
    • 500+9.94834500+1.29224
    • 1000+9.448501000+1.22732
    • 2000+9.025162000+1.17233
    • 5000+8.563675000+1.11238
    • 10000+8.2765410000+1.07508
    库存:4320
    • 1+16.789731+2.18090
    • 100+13.39699100+1.74020
    • 300+12.70104300+1.64980
    • 500+11.83111500+1.53680
    • 100+11.60623
    • 200+11.31672
    • 400+11.14177
    库存:327
