C10684_EVA-D
C10684_EVA-D
    LEDIL(芬兰)
C10684_EVA-D 数据手册
PRODUCT DATASHEET C10684_EVA-D EVA-D ~16° diffused spot beam SPECIFICATION: Dimensions Height Ø 35.0 mm 16.4 mm Fastening ROHS compliant glue yes MATERIALS: Component Type Material Colour EVA-D Single lens PMMA clear Finish ORDERING INFORMATION: Component C10684_EVA-D » Box size: Qty in box 540 MOQ MPQ 90 45 Box weight (kg) 4.0 Last update: 08/11/2023 Subject to change without prior notice Published: 07/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/9 PRODUCT DATASHEET C10684_EVA-D See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice Published: 07/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET C10684_EVA-D OPTICAL RESULTS (MEASURED): LED CLU7A2/7A3 FWHM / FWTM 16.0° / 33.0° Efficiency 92 % Peak intensity 7.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED MC-E FWHM / FWTM 16.0° Efficiency 92 % Peak intensity 6 cd/lm LEDs/each optic 1 Light colour White Required components: LED MHB-A/B FWHM / FWTM 19.0° / 40.0° Efficiency 83 % Peak intensity 5.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HI FWHM / FWTM 22.0° / 46.0° Efficiency 79 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 07/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET C10684_EVA-D OPTICAL RESULTS (MEASURED): LED XM-L FWHM / FWTM 16.0° Efficiency 91 % LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 16.0° / 30.0° Efficiency 87 % LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 14.0° Efficiency % Peak intensity 7.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 18.0° / 35.0° Efficiency 91 % Peak intensity 6.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 07/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET C10684_EVA-D OPTICAL RESULTS (MEASURED): LED LUXEON M/MX FWHM / FWTM 21.0° Efficiency 90 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON MZ FWHM / FWTM 16.0° / 33.0° Efficiency 88 % Peak intensity 7.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED NS9x383 FWHM / FWTM 16.0° / 34.0° Efficiency 89 % Peak intensity 6.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED NSMx286M FWHM / FWTM 20.0° / 44.0° Efficiency 91 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 07/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET C10684_EVA-D OPTICAL RESULTS (MEASURED): LED Duris S8 FWHM / FWTM 18.0° / 36.0° Efficiency 84 % Peak intensity 6.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y15 FWHM / FWTM 13.0° / 28.0° Efficiency 86 % Peak intensity 11.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y19 FWHM / FWTM 13.0° / 28.0° Efficiency 87 % Peak intensity 11 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 07/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET C10684_EVA-D OPTICAL RESULTS (SIMULATED): LED LUXEON 5258 FWHM / FWTM 17.0° / 30.0° Efficiency 92 % Peak intensity 8.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED CXM-3 FWHM / FWTM 14.0° / 26.0° Efficiency 95 % Peak intensity 11.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED CXM-4 FWHM / FWTM 18.0° / 34.0° Efficiency 95 % Peak intensity 7.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NFMW48xA FWHM / FWTM 22.0° / 39.0° Efficiency 96 % Peak intensity 5.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 07/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET C10684_EVA-D OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 7070 FWHM / FWTM 20.0° / 33.0° Efficiency 94 % Peak intensity 6.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 07/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET C10684_EVA-D GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice Published: 07/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
C10684_EVA-D 价格&库存
很抱歉,暂时无法提供与“C10684_EVA-D”相匹配的价格&库存,您可以联系我们找货
C10684_EVA-D
  • 6+23.348146+3.03017
  • 45+21.1812945+2.74895
  • 135+15.69478135+2.03690
  • 540+14.42538540+1.87215
  • 1035+13.623611035+1.76810
  • 2025+13.252252025+1.71990
  • 5040+12.633335040+1.63958
库存:340
C10684_EVA-D
  • 1+34.652641+4.49728
C10684_EVA-D
    • 2+24.87866
    • 10+23.88414
    • 20+22.89482
    库存:8
