C13083_PF-SOCKET
C13083_PF-SOCKET
    LEDIL(芬兰)
    BASE RND 38MM DIA 5.5MM WHITE
C13083_PF-SOCKET 数据手册
PRODUCT DATASHEET C13083_PF-SOCKET PF-SOCKET Socket with press fit interface. Compatible with MIRELLA-PF and BARBARA-PF TECHNICAL SPECIFICATIONS: Dimensions Ø 38.0 mm Height 5.5 mm Fastening screw, tape, glue Colour white Box size 480 x 280 x 300 mm Box weight 6.1 kg Quantity in Box 4608 pcs ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour PF-SOCKET Base part PC white Last update: 24/03/2016 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/3 PRODUCT DATASHEET C13083_PF-SOCKET Last update: 24/03/2016 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/3 PRODUCT DATASHEET C13083_PF-SOCKET GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 24/03/2016 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/3
C13083_PF-SOCKET 价格&库存
很抱歉,暂时无法提供与“C13083_PF-SOCKET”相匹配的价格&库存,您可以联系我们找货
C13083_PF-SOCKET
    C13083_PF-SOCKET
    库存:64
    C13083_PF-SOCKET
      C13083_PF-SOCKET
        • 1+10.650391+1.37763
