C14607_HB-2X2-M
C14607_HB-2X2-M
    LEDIL(芬兰)
    Module
C14607_HB-2X2-M 数据手册
PRODUCT DATASHEET C14607_HB-2X2-M HB-2X2-M ~25° medium beam optimized for CREE XP-L and XM-L SPECIFICATION: Dimensions Height Fastening ROHS compliant 50.0 x 50.0 mm 8.5 mm pin, screw yes MATERIALS: Component Type Material Colour HB-2X2-M Multi-lens PMMA clear Finish Length 50.0 ORDERING INFORMATION: Component C14607_HB-2X2-M » Box size: 480 x 280 x 300 mm Qty in box 800 MOQ MPQ 160 160 Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 9.2 1/34 PRODUCT DATASHEET C14607_HB-2X2-M See also our general installation guide: www.ledil.com/installation_guide Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED Bridgelux SMD 5050 FWHM / FWTM 36.0° / 66.0° Efficiency 94 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XD16 FWHM / FWTM 19.0° / 39.0° Efficiency 90 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XD16 FWHM / FWTM 33.0° / 59.0° Efficiency 94 % Peak intensity 2 cd/lm LEDs/each optic 4 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED XM-L FWHM / FWTM 32.0° / 61.0° Efficiency 93 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XM-L2 FWHM / FWTM 32.0° / 61.0° Efficiency 92 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XM-L3 FWHM / FWTM 28.0° / 54.0° Efficiency 95 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED XP-G2 FWHM / FWTM 25.0° / 49.0° Efficiency 0% Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L HD FWHM / FWTM 31.0° / 60.0° Efficiency 94 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L2 FWHM / FWTM 31.0° / 61.0° Efficiency 93 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED LUXEON 5050 Round LES FWHM / FWTM 34.0° / 65.0° Efficiency 94 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON MZ FWHM / FWTM 30.0° / 55.0° Efficiency 91 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON V FWHM / FWTM 29.0° / 58.0° Efficiency 94 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED LUXEON V2 FWHM / FWTM 23.0° / 47.0° Efficiency 94 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SST-10-B130 FWHM / FWTM 21.0° / 42.0° Efficiency 95 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour/type Deep Red Required components: LED RecLED 122x50mm 1900lm 730 2x4 Opt G1 FWHM / FWTM 24.0° / 46.0° Efficiency 95 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED NVSW219D FWHM / FWTM 29.0° / 55.0° Efficiency 94 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW219F FWHM / FWTM 28.0° / 53.0° Efficiency 95 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW319B FWHM / FWTM 29.0° / 57.0° Efficiency 94 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED NVSW3x9A FWHM / FWTM 28.0° / 53.0° Efficiency 94 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NWSx229A FWHM / FWTM 33.0° / 58.0° Efficiency 87 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED PL-BRICK HP 3800 2x8 SSG FWHM / FWTM 26.0° / 50.0° Efficiency 94 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED PrevaLED Brick HP 2x8 FWHM / FWTM 23.0° / 44.0° Efficiency 91 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Duris S8 FWHM / FWTM 38.0° / 68.0° Efficiency 94 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ C 3030 FWHM / FWTM 21.0° / 42.0° Efficiency 93 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 23.0° / 44.0° Efficiency 91 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Fortimo FastFlex LED 2x8 DA G4 FWHM / FWTM 25.0° / 51.0° Efficiency 92 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Fortimo FastFlex LED 2x8 DA G4+ FWHM / FWTM 30.0° / 59.0° Efficiency 96 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED Fortimo FastFlex LED 2x8 DA G5 FWHM / FWTM 24.0° / 47.0° Efficiency 94 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Fortimo FastFlex LED 2x8 DA HE FWHM / FWTM 32.0° / 61.0° Efficiency 96 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED HiLOM RC12 Z (LH181B) FWHM / FWTM 21.0° / 45.0° Efficiency 96 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED HiLOM RH12 Z (LH351C) FWHM / FWTM 27.0° / 55.0° Efficiency 95 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED HiLOM RH16 (LH351C) FWHM / FWTM 30.0° / 55.0° Efficiency 94 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED HiLOM RM12 Z (LH502C) FWHM / FWTM 35.0° / 67.0° Efficiency 95 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED HiLOM RM16 Z (LH502C) FWHM / FWTM 36.0° / 68.0° Efficiency 96 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED HiLOM RM8 Z (LH502C) FWHM / FWTM 36.0° / 68.0° Efficiency 96 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH351B FWHM / FWTM 28.0° / 52.0° Efficiency 85 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED LH351D FWHM / FWTM 35.0° / 64.0° Efficiency 91 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LED-Pa-L15c2W11c2-xxx-C050-01 FWHM / FWTM 24.0° / 48.0 + 47.0° Efficiency 95 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED 2x2 Y22 module - SMJQ-D48W16AA-XX FWHM / FWTM 34.0° / 64.0° Efficiency 93 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED Z5M3 FWHM / FWTM 25.0° / 51.0° Efficiency 94 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M4 FWHM / FWTM 26.0° / 52.0° Efficiency 95 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z8Y19 FWHM / FWTM 34.0° / 64.0° Efficiency 93 % Peak intensity 1.5 cd/lm LEDs/each optic 4 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED Z8Y19 FWHM / FWTM 34.0° / 64.0° Efficiency 93 % Peak intensity 1.5 cd/lm LEDs/each optic 4 Light colour/type White Required components: LED Z8Y22P FWHM / FWTM 25.0° / 48.0° Efficiency 92 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED RLE 2x4 2000lm HP EXC2 OTD FWHM / FWTM 23.0° / 48.0° Efficiency 94 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED RLE 2x8 4000lm HP EXC2 OTD FWHM / FWTM 23.0° / 48.0° Efficiency 94 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED RLE 2x8 6000lm HP HE EXC3 OTD FWHM / FWTM 33.0° / 64.0° Efficiency 95 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED RLE G1 49x121mm 2000lm xxx EXC OTD FWHM / FWTM 24.0° / 51.0° Efficiency 94 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (MEASURED): LED RLE G1 49x133mm 2000lm xxx EXC OTD FWHM / FWTM 24.0° / 51.0° Efficiency 94 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED RLE G1 49x223mm 4000lm xxx EXC OTD FWHM / FWTM 24.0° / 51.0° Efficiency 94 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED RLE G1 49x245mm 4000lm xxx EXC OTD FWHM / FWTM 24.0° / 51.0° Efficiency 94 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (SIMULATED): LED J Series 5050 Round LES FWHM / FWTM 35.0° / 64.0° Efficiency 92 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 HE FWHM / FWTM 35.0° / 58.0° Efficiency 92 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G3 FWHM / FWTM 28.0° / 50.0° Efficiency 92 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (SIMULATED): LED XP-G4 FWHM / FWTM 28.0° / 50.0° Efficiency 85 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED XP-G4 FWHM / FWTM 28.0° / 50.0 + 49.0° Efficiency 93 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L2 FWHM / FWTM 32.0° / 62.0° Efficiency 82 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (SIMULATED): LED LUXEON 3030 2D (Round LES) FWHM / FWTM 21.0° / 41.0° Efficiency 91 % Peak intensity 4.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 3535 2D FWHM / FWTM 22.0° / 42.0° Efficiency 92 % Peak intensity 4.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 34.0° / 64.0° Efficiency 87 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (SIMULATED): LED LUXEON 5050 Square LES FWHM / FWTM 34.0° / 62.0° Efficiency 88 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED LUXEON 5050 Square LES FWHM / FWTM 34.0° / 62.0° Efficiency 93 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON HL2X FWHM / FWTM 34.0° / 58.0° Efficiency 87 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (SIMULATED): LED LUXEON HL2X-D FWHM / FWTM 34.0° / 58.0° Efficiency 85 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED LUXEON HL2X-D FWHM / FWTM 34.0° / 58.0° Efficiency 94 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON HL2X-P FWHM / FWTM 36.0° / 62.0° Efficiency 91 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 24/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (SIMULATED): LED LUXEON XR-HL2X (L2H2-xxxxxxxMLU010) FWHM / FWTM 32.0° / 58.0° Efficiency 85 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED LUXEON XR-HL2X (L2H2-xxxxxxxMLU010) FWHM / FWTM 32.0° / 56.0° Efficiency 94 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NV4WB35AM FWHM / FWTM 30.0° / 54.0° Efficiency 93 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 25/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (SIMULATED): LED NVSxx19B/NVSxx19C FWHM / FWTM 28.0° / 50.0° Efficiency 92 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Duris S8 FWHM / FWTM 38.0° / 69.0° Efficiency 89 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED OSCONIQ C 2424 FWHM / FWTM 19.0 + 20.0° / 36.0° Efficiency 93 % Peak intensity 5.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 26/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 3030 FWHM / FWTM 18.0° / 36.0° Efficiency 94 % Peak intensity 5.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ P 3737 (2W version) FWHM / FWTM 22.0° / 40.0° Efficiency 92 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ P 3737 (2W version) FWHM / FWTM 22.0° / 40.0° Efficiency 87 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 27/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 3737 Flat FWHM / FWTM 24.0° / 44.0° Efficiency 93 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Pure 1414 FWHM / FWTM 18.0° / 30.0° Efficiency 93 % Peak intensity 7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 22.0° / 42.0° Efficiency 89 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 28/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (SIMULATED): LED OSLON Square Flat FWHM / FWTM 20.0° / 35.0° Efficiency 94 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSTAR Projection Compact (KW.CSLNM1.TG) FWHM / FWTM 21.0° / 38.0° Efficiency 94 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Fortimo FastFlex LED 2x8 DAX G4 FWHM / FWTM 28.0° / 50.0° Efficiency 92 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 29/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (SIMULATED): LED LH231B FWHM / FWTM 24.0° / 46.0° Efficiency 92 % Peak intensity 3.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: LED LH351C FWHM / FWTM 32.0° / 56.0° Efficiency 91 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH351D FWHM / FWTM 36.0° / 64.0° Efficiency 92 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 30/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (SIMULATED): LED LH502C FWHM / FWTM 36.0° / 70.0° Efficiency 89 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED LH508A Plus FWHM / FWTM 32.0° / 62.0° Efficiency 93 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED MJT 5050 FWHM / FWTM 36.0° / 66.0° Efficiency 92 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 31/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (SIMULATED): LED SEOUL DC 5050 6V FWHM / FWTM 34.0° / 62.0° Efficiency 94 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M5 FWHM / FWTM 28.0° / 50.0° Efficiency 85 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED Z5M5 FWHM / FWTM 28.0° / 50.0° Efficiency 94 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 32/34 PRODUCT DATASHEET C14607_HB-2X2-M OPTICAL RESULTS (SIMULATED): LED Z8Y22T FWHM / FWTM 23.0° / 44.0° Efficiency 91 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 33/34 PRODUCT DATASHEET C14607_HB-2X2-M GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 16/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 34/34
C14607_HB-2X2-M 价格&库存
很抱歉,暂时无法提供与“C14607_HB-2X2-M”相匹配的价格&库存,您可以联系我们找货
