C16870_DAISY-7X1-WW
C16870_DAISY-7X1-WW
    LEDIL(芬兰)
    带座透镜 透明 80° 宽型 螺钉
C16870_DAISY-7X1-WW 数据手册
PRODUCT DATASHEET DAISY-7X1-WW DAISY-7X1-WW ~80° wide beam SPECIFICATION: Dimensions 279.5 x 39.6 mm Height 20.3 mm Fastening pin, screw, clips ROHS compliant yes MATERIALS: Component Type Material Colour Finish Length C16870_DAISY-7X1-WW Linear lens PMMA clear C19642_DAISY-7X1-SHD3-MET-MATT Shade PC metal matt C19641_DAISY-7X1-SHD3-MET Shade PC metal gloss C19315_DAISY-7X1-SHD3-WHT-MATT Shade PC white matt C19314_DAISY-7X1-SHD3-WHT Shade PC white gloss C19313_DAISY-7X1-SHD3-MATT Shade PC black matt C19312_DAISY-7X1-SHD3 Shade PC black gloss C18409_DAISY-7X1-SHD-MET-MATT Shade PC metal matt C18167_DAISY-7X1-SHD-MET Shade PC metal gloss C17225_DAISY-7X1-SHD-WHT-MATT Shade PC white matt 279.5 C17051_DAISY-7X1-SHD-MATT Shade PC black matt 279.5 C16876_DAISY-7X1-SHD-WHT Shade PC white gloss 279.5 C16872_DAISY-7X1-SHD Shade PC black gloss 279.5 ORDERING INFORMATION: Quantities for one set: Linear lens 1 Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/31 PRODUCT DATASHEET Shade 1 DAISY-7X1-WW Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/31 PRODUCT DATASHEET DAISY-7X1-WW Component Qty in box MOQ MPQ Box weight (kg) C16870_DAISY-7X1-WW » Box size: 400 x 300 x 300 mm Linear lens 312 312 24 5.6 C18409_DAISY-7X1-SHD-MET-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.0 C19641_DAISY-7X1-SHD3-MET » Box size: 595 x 360 x 230 mm Shade 156 312 24 6.1 C16876_DAISY-7X1-SHD-WHT » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.6 C19312_DAISY-7X1-SHD3 » Box size: 595 x 360 x 230 mm Shade 156 312 24 6.1 C19642_DAISY-7X1-SHD3-MET-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 5.7 C17051_DAISY-7X1-SHD-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.3 C19313_DAISY-7X1-SHD3-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 5.8 C17225_DAISY-7X1-SHD-WHT-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.6 C19314_DAISY-7X1-SHD3-WHT » Box size: 595 x 360 x 230 mm Shade 156 312 24 6.3 C18167_DAISY-7X1-SHD-MET » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.0 C19315_DAISY-7X1-SHD3-WHT-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 6.2 C16872_DAISY-7X1-SHD » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.1 Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/31 PRODUCT DATASHEET DAISY-7X1-WW See also our general installation guide: www.ledil.com/installation_guide Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED LIGHT ENGINE DAISY 28 LEDs 277.5mm x 20mm FWHM / FWTM 76.0° / 87.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED LIGHT ENGINE DAISY 28 LEDs 277.5mm x 20mm FWHM / FWTM 74.0° / 87.0° Efficiency 96 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C18167_DAISY-7X1-SHD-MET LED LIGHT ENGINE DAISY 28 LEDs 277.5mm x 20mm FWHM / FWTM 76.0° / 88.0° Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED LIGHT ENGINE DAISY 28 LEDs 277.5mm x 20mm FWHM / FWTM 76.0° / 88.0° Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED LIGHT ENGINE DAISY 28 LEDs 277.5mm x 20mm FWHM / FWTM 75.0° / 87.0° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17533_DAISY-7X1-SHD-MET-MATT LED LIGHT ENGINE DAISY 28 LEDs 277.5mm x 20mm FWHM / FWTM 76.0° / 87.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED LUXEON 2835 Line FWHM / FWTM 75.0° / 87.0° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17533_DAISY-7X1-SHD-MET-MATT LED LUXEON 2835 Line FWHM / FWTM 76.0° / 87.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED LUXEON 2835 Line FWHM / FWTM 76.0° / 87.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED LUXEON 2835 Line FWHM / FWTM 74.0° / 87.0° Efficiency 96 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17532_DAISY-7X1-SHD-MET LED LUXEON 2835 Line FWHM / FWTM 76.0° / 88.0° Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT LED LUXEON 2835 Line FWHM / FWTM 76.0° / 88.0° Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED Opticus Daisy M L28W2 FWHM / FWTM 76.0° / 88.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 75.0° / 88.0° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17533_DAISY-7X1-SHD-MET-MATT LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 76.0° / 87.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 76.0° / 88.0° Efficiency 85 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 75.0° / 87.0° Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C18167_DAISY-7X1-SHD-MET LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 77.0° / 88.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 76.0° / 88.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED LinLED 280x28mm 1600lm 840 4C 21V DAISY 7x1(ZT25) FWHM / FWTM 77.0° / 82.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED LinLED 280x28mm 2x550lm 827-865 2x2C 42V DAISY-7X1 G1 FWHM / FWTM 77.0° / 89.0° Efficiency 95 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C16876_DAISY-7X1-SHD-WHT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED LinLED 280x28mm 2x550lm 827-865 2x2C 42V DAISY-7X1 G1 FWHM / FWTM 77.0° / 89.0° Efficiency 95 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED LinLED 280x28mm 2x550lm 827-865 2x2C 42V DAISY-7X1 G1 FWHM / FWTM 76.0° / 88.0° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C17533_DAISY-7X1-SHD-MET-MATT LED LinLED 280x28mm 2x550lm 827-865 2x2C 42V DAISY-7X1 G1 FWHM / FWTM 76.0° / 88.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C16872_DAISY-7X1-SHD Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED LinLED 280x28mm 2x550lm 827-865 2x2C 42V DAISY-7X1 G1 FWHM / FWTM 76.0° / 88.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C17051_DAISY-7X1-SHD-MATT LED LinLED 280x28mm 2x550lm 827-865 2x2C 42V DAISY-7X1 G1 FWHM / FWTM 75.0° / 88.0° Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C18167_DAISY-7X1-SHD-MET LED NF2W757G-MT (Tunable White) FWHM / FWTM 80.0° / 86.0° Efficiency 96 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C16876_DAISY-7X1-SHD-WHT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED NF2W757G-MT (Tunable White) FWHM / FWTM 79.0° / 85.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C16872_DAISY-7X1-SHD LED NFSx757G FWHM / FWTM 75.0° / 86.0° Efficiency 88 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C16872_DAISY-7X1-SHD LED PL-LIN-2000 280x24mm FWHM / FWTM 75.0° / 87.0° Efficiency 85 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED OSCONIQ E 2835 FWHM / FWTM 76.0° / 87.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED LM28xB Series FWHM / FWTM 77.0° / 85.0° Efficiency 88 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED LM28xB Series FWHM / FWTM 78.0° / 86.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED LM28xB Series FWHM / FWTM 78.0° / 86.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT LED LED-St-L28W2c4-xxx-C015-55 (DAISY-7x1) FWHM / FWTM 75.0° / 87.0° Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17533_DAISY-7X1-SHD-MET-MATT LED LED-St-L28W2c4-xxx-C015-55 (DAISY-7x1) FWHM / FWTM 76.0° / 87.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED LED-St-L28W2c4-xxx-C015-55 (DAISY-7x1) FWHM / FWTM 76.0° / 87.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED LED-St-L28W2c4-xxx-C015-55 (DAISY-7x1) FWHM / FWTM 75.0° / 87.0° Efficiency 96 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C18167_DAISY-7X1-SHD-MET LED LED-St-L28W2c4-xxx-C015-55 (DAISY-7x1) FWHM / FWTM 76.0° / 87.0° Efficiency 96 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED LED-St-L28W2c4-xxx-C015-55 (DAISY-7x1) FWHM / FWTM 76.0° / 87.0° Efficiency 96 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED PassivePAQ-L-1F35-SSA3-2.7K-840-3-DC FWHM / FWTM 82.0° / 90.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT LED PassivePAQ-L-1F35-SSA3-2.7K-840-3-DC FWHM / FWTM 81.0° / 90.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED PassivePAQ-L-1F35-SSA3-2.7K-840-3-DC FWHM / FWTM 80.0° / 90.0° Efficiency 85 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED PassivePAQ-L-1F35-SSA3-2.7K-840-3-DC FWHM / FWTM 82.0° / 90.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM 76.0° / 87.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM 74.0° / 87.0° Efficiency 96 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C18167_DAISY-7X1-SHD-MET LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM 77.0° / 88.0° Efficiency 95 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM 77.0° / 88.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (MEASURED): LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM 76.0° / 87.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM 75.0° / 88.0° Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C17533_DAISY-7X1-SHD-MET-MATT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (SIMULATED): LED Bridgelux SMD 2835 FWHM / FWTM 76.0° / 88.0° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT LED Bridgelux SMD 5050 FWHM / FWTM 74.0° / 90.0° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT LED LUXEON 3030 HE Plus FWHM / FWTM 80.0° / 85.0° Efficiency 83 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16872_DAISY-7X1-SHD Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (SIMULATED): LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 76.0° / 88.0° Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17533_DAISY-7X1-SHD-MET-MATT LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 76.0° / 88.0° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 76.0° / 88.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C18167_DAISY-7X1-SHD-MET Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (SIMULATED): LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 76.0° / 88.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 76.0° / 88.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED LinLED 280x28mm 1100lm 8x0 2C 42V DAISY-7X1 G1 FWHM / FWTM 76.0° / 88.0° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 24/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (SIMULATED): LED NF2W757G-MT (Tunable White) FWHM / FWTM 76.0° / 88.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type Tunable White Required components: C16872_DAISY-7X1-SHD LED NF2W757G-MT (Tunable White) FWHM / FWTM 77.0° / 86.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 2 Light colour/type Tunable White Required components: C16872_DAISY-7X1-SHD LED Duris E 2835 FWHM / FWTM 76.0° / 88.0° Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 25/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (SIMULATED): LED Duris E 2835 FWHM / FWTM 76.0° / 84.0° Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT LED Duris E 2835 FWHM / FWTM 76.0° / 86.0° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 2 Light colour/type White Required components: C16876_DAISY-7X1-SHD-WHT LED Duris E 2835 FWHM / FWTM 76.0° / 89.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 26/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (SIMULATED): LED Duris E 2835 FWHM / FWTM 76.0° / 86.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 2 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED OSLON PURE 1010 FWHM / FWTM 76.0° / 88.0° Efficiency 83 % Peak intensity 0.6 cd/lm LEDs/each optic 8 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED OSLON PURE 1010 FWHM / FWTM 76.0° / 87.0° Efficiency 83 % Peak intensity 0.7 cd/lm LEDs/each optic 8 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 27/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (SIMULATED): LED LH181B FWHM / FWTM 76.0° / 85.0° Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 2 Light colour/type White Required components: C18167_DAISY-7X1-SHD-MET LED LH231B FWHM / FWTM 74.0° / 86.0° Efficiency 91 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED LH231B FWHM / FWTM 75.0° / 86.0° Efficiency 91 % Peak intensity 0.7 cd/lm LEDs/each optic 2 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 28/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (SIMULATED): LED LM28xB Series FWHM / FWTM 77.0° / 90.0° Efficiency 84 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED LM301B FWHM / FWTM 76.0° / 90.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED LM301D FWHM / FWTM 74.0° / 88.0° Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C17225_DAISY-7X1-SHD-WHT-MATT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 29/31 PRODUCT DATASHEET DAISY-7X1-WW OPTICAL RESULTS (SIMULATED): LED SEOUL DC 3030C FWHM / FWTM 77.0° / 90.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED SEOUL DC 3528 FWHM / FWTM 78.0° / 86.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16872_DAISY-7X1-SHD LED SEOUL DC 5050 6V FWHM / FWTM 78.0° / 87.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C17051_DAISY-7X1-SHD-MATT Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 30/31 PRODUCT DATASHEET DAISY-7X1-WW GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 29/04/2024 Subject to change without prior notice Published: 24/04/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 31/31
C16870_DAISY-7X1-WW 价格&库存
很抱歉,暂时无法提供与“C16870_DAISY-7X1-WW”相匹配的价格&库存,您可以联系我们找货
C16870_DAISY-7X1-WW
    C16870_DAISY-7X1-WW
      库存:45
      C16870_DAISY-7X1-WW
      • 1+35.897621+4.65769
      • 24+23.9499324+3.10749
      • 120+20.50690120+2.66076
      • 504+18.36811504+2.38325
      • 1008+17.570311008+2.27974
      • 2016+16.895112016+2.19213
      • 5016+16.163325016+2.09718
      库存:824
