C14731_STRADA-2X2-FN-PC
    LEDIL(芬兰)
C14731_STRADA-2X2-FN-PC 数据手册
PRODUCT DATASHEET C14731_STRADA-2X2-FN-PC STRADA-2X2-FN-PC Narrow forward throw beam for area lighting. Excellent for lighting stadiums and airports from high masts. Variant made from PC. SPECIFICATION: Dimensions Height Fastening ROHS compliant 50.0 x 50.0 mm 10 mm pin, screw yes MATERIALS: Component Type Material Colour STRADA-2X2-FN-PC Multi-lens PC clear Finish ORDERING INFORMATION: Component C14731_STRADA-2X2-FN-PC » Box size: 480 x 280 x 300 mm Qty in box 800 MOQ MPQ 160 160 Box weight (kg) 9.0 Last update: 29/01/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/7 PRODUCT DATASHEET C14731_STRADA-2X2-FN-PC See also our general installation guide: www.ledil.com/installation_guide Last update: 29/01/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/7 PRODUCT DATASHEET C14731_STRADA-2X2-FN-PC OPTICAL RESULTS (MEASURED): LED NVSW3x9A FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S8 FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/01/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/7 PRODUCT DATASHEET C14731_STRADA-2X2-FN-PC OPTICAL RESULTS (SIMULATED): LED LUXEON TX FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NV4WB35AM FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NV4WB35AM FWHM / FWTM Asymmetric Efficiency 77 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED NVSW519A FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/01/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/7 PRODUCT DATASHEET C14731_STRADA-2X2-FN-PC OPTICAL RESULTS (SIMULATED): LED NVSW519A FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED Duris S8 FWHM / FWTM Asymmetric Efficiency 76 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM Asymmetric Efficiency 76 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LH351D FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/01/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/7 PRODUCT DATASHEET C14731_STRADA-2X2-FN-PC OPTICAL RESULTS (SIMULATED): LED LH502D FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH502D FWHM / FWTM Asymmetric Efficiency 77 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED RLE 2x4 3000lm HP HE EXC3 OTD FWHM / FWTM Asymmetric Efficiency 77 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED RLE 2x4 3000lm HP HE EXC3 OTD FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/01/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/7 PRODUCT DATASHEET C14731_STRADA-2X2-FN-PC GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 29/01/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/7
C14731_STRADA-2X2-FN-PC 价格&库存
很抱歉,暂时无法提供与“C14731_STRADA-2X2-FN-PC”相匹配的价格&库存,您可以联系我们找货
