PRODUCT
DATASHEET
CA11267_HEIDI-O-90
HEIDI-O-90
~13° x 45° oval beam optimized for Cree XP-G
and XP-E. Variant with beam direction rotated
90°.
SPECIFICATION:
Dimensions
Ø 21.6 mm
Height
12.1 mm
Fastening
tape, pin
ROHS compliant
yes
MATERIALS:
Component
Type
Material
Colour
HEIDI-O-90
Single lens
PMMA
clear
HEIDI-TAPE
Tape
Acrylic foam
black
Finish
ORDERING INFORMATION:
Component
CA11267_HEIDI-O-90
» Box size: 480 x 280 x 300 mm
Single lens
Qty in box
MOQ
MPQ
3264
204
204
Last update: 27/11/2023
Subject to change without prior notice
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
Box weight (kg)
10.4
1/11
PRODUCT
DATASHEET
CA11267_HEIDI-O-90
See also our general installation guide: www.ledil.com/installation_guide
2/11
PRODUCT
DATASHEET
CA11267_HEIDI-O-90
OPTICAL RESULTS (MEASURED):
LED
XB-D
FWHM / FWTM
12.0 + 49.0° / 34.0 + 78.0°
Efficiency
87 %
Peak intensity
3.5 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
LED
XB-H
FWHM / FWTM
11.0 + 52.0° / 34.0 + 80.0°
Efficiency
80 %
Peak intensity
3.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
XD16
FWHM / FWTM
11.0 + 52.0° / 30.0 + 76.0°
Efficiency
88 %
Peak intensity
3.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-E
FWHM / FWTM
9.0 + 50.0° / 25.0 + 72.0°
Efficiency
87 %
Peak intensity
4.2 cd/lm
LEDs/each optic
1
Light colour
White
3/11
PRODUCT
DATASHEET
CA11267_HEIDI-O-90
LED
XP-E2
FWHM / FWTM
9.0 + 55.0° / 23.0 + 76.0°
Efficiency
84 %
Peak intensity
4.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G
FWHM / FWTM
14.0 + 44.0° / 32.0 + 70.0°
Efficiency
87 %
Peak intensity
3.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
XQ-E HD
FWHM / FWTM
7.0 + 56.0° / 23.0 + 77.0°
Efficiency
94 %
Peak intensity
4.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
XQ-E HI
FWHM / FWTM
6.0 + 57.0° / 20.0 + 76.0°
Efficiency
94 %
Peak intensity
5.3 cd/lm
LEDs/each optic
1
Light colour
White
4/11
PRODUCT
DATASHEET
CA11267_HEIDI-O-90
LED
LUXEON C
FWHM / FWTM
9.0 + 54.0° / 23.0 + 76.0°
Efficiency
79 %
Peak intensity
3.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON CZ
FWHM / FWTM
8.0 + 52.0° / 19.0 + 73.0°
Efficiency
92 %
Peak intensity
5 cd/lm
LEDs/each optic
1
Light colour
White
LED
NCSxx19A
FWHM / FWTM
10.0 + 50.0° / 30.0 + 75.0°
Efficiency
82 %
Peak intensity
3.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxx19A
FWHM / FWTM
10.0 + 49.0° / 31.0 + 76.0°
Efficiency
82 %
Peak intensity
3.4 cd/lm
LEDs/each optic
1
Light colour
White
5/11
PRODUCT
DATASHEET
CA11267_HEIDI-O-90
LED
NVSxx19B/NVSxx19C
FWHM / FWTM
14.0 + 48.0° / 38.0 + 78.0°
Efficiency
85 %
Peak intensity
2.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Square CSSRM2/CSSRM3
FWHM / FWTM
15.0 + 51.0° / 35.0 + 78.0°
Efficiency
78 %
Peak intensity
2.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Square EC
FWHM / FWTM
12.0 + 48.0° / 34.0 + 74.0°
Efficiency
86 %
Peak intensity
3.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON SSL 150
FWHM / FWTM
9.0 + 48.0° / 25.0 + 72.0°
Efficiency
86 %
Peak intensity
4.7 cd/lm
LEDs/each optic
1
Light colour
White
6/11
PRODUCT
DATASHEET
CA11267_HEIDI-O-90
LED
OSLON SSL 80
FWHM / FWTM
9.0 + 42.0° / 27.0 + 70.0°
Efficiency
83 %
Peak intensity
4.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH181B
FWHM / FWTM
14.0 + 51.0° / 35.0 + 77.0°
Efficiency
89 %
Peak intensity
2.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351B
FWHM / FWTM
13.0 + 52.0° / 34.0 + 78.0°
Efficiency
83 %
Peak intensity
3 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351Z
FWHM / FWTM
11.0 + 54.0° / 31.0 + 78.0°
Efficiency
82 %
Peak intensity
3.5 cd/lm
LEDs/each optic
1
Light colour
White
7/11
PRODUCT
DATASHEET
CA11267_HEIDI-O-90
LED
Z5
FWHM / FWTM
8.0 + 50.0° / 21.0 + 72.0°
Efficiency
86 %
Peak intensity
4.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z5M1/Z5M2
FWHM / FWTM
11.0 + 53.0° / 31.0 + 77.0°
Efficiency
84 %
Peak intensity
3.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
Double Dome (GM2BB)
FWHM / FWTM
16.0 + 44.0° / 40.0 + 70.0°
Efficiency
82 %
Peak intensity
2.6 cd/lm
LEDs/each optic
1
Light colour
White
8/11
PRODUCT
DATASHEET
CA11267_HEIDI-O-90
OPTICAL RESULTS (SIMULATED):
LED
LUXEON HL2Z
FWHM / FWTM
12.0 + 54.0° / 28.0 + 76.0°
Efficiency
88 %
Peak intensity
3.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON SunPlus 20 Line (120 deg)
FWHM / FWTM
9.0 + 52.0° / 22.0 + 76.0°
Efficiency
91 %
Peak intensity
4.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON SunPlus 20 Line (150 deg)
FWHM / FWTM
9.0 + 52.0° / 20.0 + 76.0°
Efficiency
87 %
Peak intensity
4.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON Z ES
FWHM / FWTM
8.7 + 52.0° / 21.0 + 74.0°
Efficiency
92 %
Peak intensity
4.4 cd/lm
LEDs/each optic
1
Light colour
White
9/11
PRODUCT
DATASHEET
CA11267_HEIDI-O-90
LED
OSCONIQ P 3030
FWHM / FWTM
7.9 + 55.0° / 20.0 + 77.0°
Efficiency
93 %
Peak intensity
4.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
SFH 4170S
FWHM / FWTM
7.0 + 51.0° / 17.0 + 70.0°
Efficiency
83 %
LEDs/each optic
1
Light colour
IR
10/11
PRODUCT
DATASHEET
CA11267_HEIDI-O-90
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
11/11
很抱歉,暂时无法提供与“CA11267_HEIDI-O-90”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2+24.40483
- 10+23.42593
- 20+22.45224
