CA11766_LAURA-WW-XP-TAPE
    LEDIL(芬兰)
CA11766_LAURA-WW-XP-TAPE 数据手册
PRODUCT DATASHEET Laura-XP series Ordering number CA11365 Description CA11365-Laura-O-XP-G-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Lens XP-G Black 21.6 mm 13.1 mm Square PMMA PC Tape Ready FWHM Efficiency cd/lm Gerber File 0 degrees Available Ordering number CA11525 Description CA11525_Laura-Refl-W-XPG-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Reflector XP-G Black 21.6 mm 13.1 mm Square PC PC Tape Ready FWHM Efficiency cd/lm Gerber File 0 degrees Available FWHM Efficiency cd/lm Gerber File 0 degrees Available Ordering number CA11355 Description CA11355-Laura-M-XP-G-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Lens XP-G Black 21.6 mm 13.1 mm Square PMMA PC Ready Ordering number CA11353 Description CA11353_Laura-RS-XP-G-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Lens XP-G Black 21.6 mm 13.1 mm Square PMMA PC Ready FWHM Efficiency cd/lm Gerber File 11 degrees Available August 4th 2011 13:43 Copyright Ledil Oy - Subject to change without prior notice - Page 1/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Laura-XP series Ordering number CA11643 Description CA11643_Laura-SS-XP-G-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Lens XP-G Black 21.6 mm 13.1 mm Square PMMA PC Tape Ready FWHM Efficiency cd/lm Gerber File 11 degrees Available FWHM Efficiency cd/lm Gerber File 16 degrees Available Ordering number CA11360 Description CA11360-Laura-D-XP-G-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Lens XP-G Black 21.6 mm 13.1 mm Square PMMA PC Tape Ready Ordering number CA12131 Description CA12131_Laura-M-XP-G-tape-white Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Lens XP-G White 21.6 mm 13.1 mm Square PMMA PC Ready FWHM Efficiency cd/lm Gerber File 30 degrees Available FWHM Efficiency cd/lm Gerber File 64 degrees 86 % Available Ordering number CA11766 Description CA11766_Laura-WW-XP-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Lens XP-G Black 21.6 mm 13.1 mm Square PMMA PC Tape Ready August 4th 2011 13:43 Copyright Ledil Oy - Subject to change without prior notice - Page 2/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Laura-XP series Ordering number CA11766 Description CA11766_Laura-WW-XPG-tape Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Laura Lens XP-G Black 21.6 mm 13.1 mm Square PMMA PC Tape Ready FWHM Efficiency cd/lm Gerber File 64 degrees 86 % Available NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. August 4th 2011 13:43 Copyright Ledil Oy - Subject to change without prior notice - Page 3/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Laura-XP series GENERAL INFORMATION - Product series especially designed & optimized for XP-G series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf - Lens material optical grade PC with high UV and temperature resistance (120 degrees of Celcius / 248 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used materials from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PC%20Makrolon%202400_2407_2456_2458-UL .pdf - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (110 degrees of Celcius / 230 degrees of Fahrenheit). - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). - Fastening to heat sink with a PU foam adhesive tape of automotive grade. Please find fastening details by clicking link: http://www.ledil.com/datasheets/DataSheet_TAPE.pdf NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the tape. NOTE 2: Assembly to the surface must be made straight, so the tape bonds constant and balanced with fastening surface. Slanted assembly might cause unbalanced bond to the surface. All surfaces where tape is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer - this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. August 4th 2011 13:43 Copyright Ledil Oy - Subject to change without prior notice - Page 4/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 Relative intensity of CA11837_Laura-M-Pin-XP-G-tape 100% 75% 50% 25% 0% 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 Relative Intensity of CA11959_Laura-RS-Pin-XP-G-tape 100 % 75 % 50 % 25 % 0% 20 15 10 5 0 -5 -10 -15 -20 Relative intensity of CA11361_Laura-D-XP-G-tape 100 % 75 % 50 % 25 % 0% 40 30 20 10 0 -10 -20 -30 -40 Relative intensity of CA12011_Laura-SS-Pin-XP-G-tape 100% 75% 50% 25% 0% 30 20 10 0 -10 -20 -30 Relative intensity of CA12012_Laura-O-Pin-XP-G-tape 100% 75% 50% 25% 0% 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 A B C D 4 4 Isometric view Scale: 1:1 21.6 Bottom view 3 21.6 3 13.1 Lens Holder Front view Tape 2 2 Materials lens: PMMA holder: PC, black Tape: PU Foam 1 This drawing is our property. It can't be reproduced or communicated without our written agreement. DRAWN BY DATE CHECKED BY DATE DESIGNED BY DATE Led Teh FIN Fin DRAWING TITLE pv 11.06.2010 SIZE hh 25.01.2010 hh 21.01.2010 D Datasheet Laura-tape series assy DRAWING NUMBER A4 SCALE 2:1 WEIGHT(g) REV CA11353 1 SHEET A 1/1 1
CA11766_LAURA-WW-XP-TAPE 价格&库存
很抱歉,暂时无法提供与“CA11766_LAURA-WW-XP-TAPE”相匹配的价格&库存,您可以联系我们找货
