CA13747_KIKI-A
CA13747_KIKI-A
    LEDIL(芬兰)
CA13747_KIKI-A 数据手册
PRODUCT DATASHEET CA13747_KIKI-A KIKI-A ~165° wide beam. Assembly with installation tape. SPECIFICATION: Dimensions Height Fastening ROHS compliant 21.6 x 14.0 mm 5.9 mm tape, pin yes MATERIALS: Component Type Material Colour KIKI-A Single lens PMMA clear SIRI-TAPE-3 Tape Finish Length 21.6 ORDERING INFORMATION: Component CA13747_KIKI-A » Box size: 451 x 254 x 152 mm Single lens Qty in box MOQ MPQ 4032 378 126 Box weight (kg) 3.5 Last update: 30/04/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/8 PRODUCT DATASHEET CA13747_KIKI-A See also our general installation guide: www.ledil.com/installation_guide Last update: 30/04/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/8 PRODUCT DATASHEET CA13747_KIKI-A OPTICAL RESULTS (MEASURED): LED LUXEON T FWHM / FWTM 162.0° / 183.0° Efficiency 91 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON TX FWHM / FWTM 162.0° / 185.0° Efficiency 90 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 161.0° / 181.0° Efficiency 88 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 30/04/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/8 PRODUCT DATASHEET CA13747_KIKI-A OPTICAL RESULTS (MEASURED): LED OSLON Square PC FWHM / FWTM 161.0° / 180.0° Efficiency 88 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 30/04/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/8 PRODUCT DATASHEET CA13747_KIKI-A OPTICAL RESULTS (SIMULATED): LED J Series 2835 FWHM / FWTM 158.0° / 171.0° Efficiency 95 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED J Series 3030 FWHM / FWTM 155.0° / 167.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NFSx757G FWHM / FWTM 158.0° / 170.0° Efficiency 95 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 30/04/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/8 PRODUCT DATASHEET CA13747_KIKI-A OPTICAL RESULTS (SIMULATED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 166.0° / 180.0° Efficiency 93 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LM28xB Series FWHM / FWTM 159.0° / 168.0° Efficiency 95 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LM28xB Series FWHM / FWTM 157.0° / 172.0° Efficiency 96 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 30/04/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/8 PRODUCT DATASHEET CA13747_KIKI-A OPTICAL RESULTS (SIMULATED): LED LM301B FWHM / FWTM 158.0° / 170.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z8Y11 FWHM / FWTM 152.0° / 165.0° Efficiency 93 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 30/04/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/8 PRODUCT DATASHEET CA13747_KIKI-A GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 30/04/2024 Subject to change without prior notice Published: 19/12/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/8
CA13747_KIKI-A 价格&库存
很抱歉,暂时无法提供与“CA13747_KIKI-A”相匹配的价格&库存,您可以联系我们找货
CA13747_KIKI-A
  • 126+11.81166126+1.53102
CA13747_KIKI-A
    CA13747_KIKI-A
