CA15226_STRADA-SQ-FS3
    LEDIL(芬兰)
CA15226_STRADA-SQ-FS3 数据手册
PRODUCT DATASHEET CA15226_STRADA-SQ-FS3 STRADA-SQ-FS3 Forward throw beam optimized for European tunnels, resulting in extremely efficient lighting with counter-beam method. Version with location pins. Assembly with installation tape. SPECIFICATION: Dimensions Height 25.0 x 25.0 mm 16.2 mm Fastening ROHS compliant tape yes MATERIALS: Component Type Material Colour STRADA-SQ-FS3 Single lens PMMA clear ROSE-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA15226_STRADA-SQ-FS3 » Box size: 480 x 280 x 300 mm Single lens Qty in box MOQ MPQ 1470 294 98 Box weight (kg) 7.4 Last update: 22/12/2023 Subject to change without prior notice Published: 12/11/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/12 PRODUCT DATASHEET CA15226_STRADA-SQ-FS3 See also our general installation guide: www.ledil.com/installation_guide Last update: 22/12/2023 Subject to change without prior notice Published: 12/11/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/12 PRODUCT DATASHEET CA15226_STRADA-SQ-FS3 OPTICAL RESULTS (MEASURED): LED MK-R FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON M/MX FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON MZ FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NV4x144A FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 12/11/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/12 PRODUCT DATASHEET CA15226_STRADA-SQ-FS3 OPTICAL RESULTS (MEASURED): LED NV4x144A FWHM / FWTM Asymmetric Efficiency 78 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED NVSW319B FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S10 FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square PC FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 12/11/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/12 PRODUCT DATASHEET CA15226_STRADA-SQ-FS3 OPTICAL RESULTS (SIMULATED): LED XHP50.2 FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED XHP50.2 FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP70 FWHM / FWTM Asymmetric Efficiency 77 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED XM-L2 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 12/11/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/12 PRODUCT DATASHEET CA15226_STRADA-SQ-FS3 OPTICAL RESULTS (SIMULATED): LED XP-G3 FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour Red Required components: LED XT-E FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Round LES FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 12/11/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/12 PRODUCT DATASHEET CA15226_STRADA-SQ-FS3 OPTICAL RESULTS (SIMULATED): LED LUXEON 5050 Square LES FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 7070 FWHM / FWTM Asymmetric Efficiency 76 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LUXEON M/MX FWHM / FWTM Asymmetric Efficiency 76 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED SFT-40-WCS FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 12/11/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/12 PRODUCT DATASHEET CA15226_STRADA-SQ-FS3 OPTICAL RESULTS (SIMULATED): LED SFT-40-WCS FWHM / FWTM Asymmetric Efficiency 74 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED SFT-70X-WCS FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFT-70X-WCS FWHM / FWTM Asymmetric Efficiency 74 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED NVSxE21A FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 12/11/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/12 PRODUCT DATASHEET CA15226_STRADA-SQ-FS3 OPTICAL RESULTS (SIMULATED): LED NVSxx19B/NVSxx19C FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 7070 FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED OSCONIQ P 7070 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 12/11/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/12 PRODUCT DATASHEET CA15226_STRADA-SQ-FS3 OPTICAL RESULTS (SIMULATED): LED OSLON Square EC FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFH 4715AS FWHM / FWTM Asymmetric Efficiency 87 % LEDs/each optic 1 Light colour IR Required components: LED SFH 4716AS FWHM / FWTM Asymmetric Efficiency 87 % LEDs/each optic 1 Light colour IR Required components: LED LH181B FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 1.2 cd/lm LEDs/each optic 4 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 12/11/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/12 PRODUCT DATASHEET CA15226_STRADA-SQ-FS3 OPTICAL RESULTS (SIMULATED): LED LH351D FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 12/11/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/12 PRODUCT DATASHEET CA15226_STRADA-SQ-FS3 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 22/12/2023 Subject to change without prior notice Published: 12/11/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/12
CA15226_STRADA-SQ-FS3 价格&库存
很抱歉,暂时无法提供与“CA15226_STRADA-SQ-FS3”相匹配的价格&库存,您可以联系我们找货
