PRODUCT DATASHEET
Lisa series
last update 31/10/2012
Ordering number CP11626
Description
CA11626_Lisa-01-RS
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Lisa
Assembly
Golden Dragon
White
11 mm
7.9 mm
Round
PMMA
PC
Glue
Ready
FWHM
Efficiency
cd/lm
Gerber File
12 degrees
91 %
Available
FWHM
Efficiency
cd/lm
Gerber File
16 degrees
90 %
5.900
Available
Ordering number CP10444
Description
CA10444_Lisa-O1-SS
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Lisa
Assembly
Golden Dragon
White
10.8 mm
7.3 mm
Round
PMMA
PC
Glue
Ready
NOTE: The typical divergence will be changed by different color, chip size and chip position
tolerance. The typical total divergence is the full angle measured where the luminous intensity
is half of the peak value.
September 30th 2013 18:35 Copyright Ledil Oy - Subject to change without prior notice - Page 1/2
Ledil Oy
Salorankatu 10
24240 SALO
Finland
http://www.ledil.com
email: ledil@ledil.com
FAX: +358-2-733 8001
PRODUCT DATASHEET
Lisa series
GENERAL INFORMATION
- Product series especially designed & optimized for Golden Dragon series of LEDs.
- Special care taken to make light distribution as uniform as possible.
- Fastening to PCB with appropriate adhesive. By clicking link below you can find Ledil recommended glue
options.
http://www.ledil.com/datasheets/DataSheet_GLUES.pdf
NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end
product. For example, mechanical stress, vibration and holes on the surface of the circuit boar
weaken the strength of the glue.
NOTE 2: All surfaces where glue is applied must be clean, dry and free from grease and dirt. If
cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED
manufacturer -this is important as cleaning shall under no circumstances damage LEDs or other
electronics components on the PCB.
Further note that optical components shall not be cleaned with any chemicals - only micro fiber
cloth may be used to remove fingerprints or other traces from handling.
September 30th 2013 18:35 Copyright Ledil Oy - Subject to change without prior notice - Page 2/2
Ledil Oy
Salorankatu 10
24240 SALO
Finland
A
B
C
D
4
Holder
4
6.9
Lens
4
Bottom view
5.9
3
7.9
Side view
3
11
2
Top view
Material:
Lens PMMA
Holder PC
2
NOTE:
Please be careful when remove assembly from LED.
Otherwise clips might break some of led's corner.
If needed, secure assembly with proper glue between
holder and pcb.
This drawing is our property.
It can't be reproduced
or communicated without
our written agreement.
1
DRAWN BY
ah
DATE
Ledil Oy
Salorankatu
FIN-24100 SALO
Finland
DRAWING TITLE
Datasheet Lisa-O1 series Assy
13.7.2012
CHECKED BY
vs
DATE
13.7.2012
DESIGNED BY
HH
DATE
06.01.2008
D
SIZE
DRAWING NUMBER
REV
5
A4
SCALE
4:1 WEIGHT(g)
SHEET
A
1/1
1
很抱歉,暂时无法提供与“CP10444_LISA-SS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+34.886361+4.47455
- 10+25.6527410+3.29024
- 100+20.18508100+2.58896
- 500+17.78686500+2.28136
- 1000+17.006231000+2.18124
- 2000+16.345742000+2.09652
- 5000+15.626505000+2.00427
