PRODUCT
DATASHEET
F15074_ZORYA-SC
ZORYA-SC
~340° omnidirectional decorative beam. Suitable
also for UV-C applications.
SPECIFICATION:
Dimensions
Height
Fastening
ROHS compliant
Ø 56.0 mm
26.7 mm
glue, socket
yes
MATERIALS:
Component
Type
Material
Colour
ZORYA-SC
Single lens
Silicone
clear
Finish
ORDERING INFORMATION:
Component
F15074_ZORYA-SC
» Box size: 398 x 298 x 140 mm
Qty in box
140
MOQ
MPQ
35
Box weight (kg)
3.0
Last update: 08/11/2023
Subject to change without prior notice
Published: 26/07/2018
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/6
PRODUCT
DATASHEET
F15074_ZORYA-SC
See also our general installation guide: www.ledil.com/installation_guide
2/6
PRODUCT
DATASHEET
F15074_ZORYA-SC
OPTICAL RESULTS (MEASURED):
LED
CLL02x/CLU02x (LES10)
FWHM / FWTM
218.0° / 278.0°
Efficiency
94 %
Peak intensity
0.2 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
Bender Wirth: 434 Typ L7
LED
CLL03x/CLU03x
FWHM / FWTM
149.0° / 285.0°
Efficiency
94 %
Peak intensity
0.2 cd/lm
LEDs/each optic
1
Light colour
White
Bender Wirth: 433 Typ L7
LED
CXA/B 25xx
FWHM / FWTM
143.0° / 289.0°
Efficiency
94 %
Peak intensity
0.2 cd/lm
LEDs/each optic
1
Light colour
White
Bender Wirth: 439 Typ L7
LED
COB L-Type (LES 11)
FWHM / FWTM
189.0° / 280.0°
Efficiency
94 %
Peak intensity
0.2 cd/lm
LEDs/each optic
1
Light colour
White
Bender Wirth: 438 Typ L7
3/6
PRODUCT
DATASHEET
F15074_ZORYA-SC
OPTICAL RESULTS (SIMULATED):
LED
LUXEON 7070
FWHM / FWTM
239.0° / 282.0°
Efficiency
91 %
Peak intensity
0.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
NCSU334A
FWHM / FWTM
224.0° / 254.0°
Efficiency
64 %
LEDs/each optic
1
Light colour
UV-C
The UVC LED result tolerance is ±10 %
LED
NF2x757G
FWHM / FWTM
238.0° / 276.0°
Efficiency
90 %
Peak intensity
0.1 cd/lm
LEDs/each optic
4
Light colour
White
LED
NF2x757G
FWHM / FWTM
238.0° / 280.0°
Efficiency
91 %
Peak intensity
0.1 cd/lm
LEDs/each optic
9
Light colour
White
4/6
PRODUCT
DATASHEET
F15074_ZORYA-SC
LED
CUD8AF4D
FWHM / FWTM
226.0° / 264.0°
Efficiency
59 %
LEDs/each optic
1
Light colour
UV-C
LED
WICOP DY9560-27
FWHM / FWTM
245.0° / 296.0°
Efficiency
60 %
LEDs/each optic
4
Light colour
UV-C
LED
WICOP DY9560-27
FWHM / FWTM
244.0° / 280.0°
Efficiency
61 %
LEDs/each optic
1
Light colour
UV-C
LED
WICOP DY9560-27
FWHM / FWTM
254.0° / 304.0°
Efficiency
58 %
LEDs/each optic
24
Light colour
UV-C
5/6
PRODUCT
DATASHEET
F15074_ZORYA-SC
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
Due to use of high power COB's with this product, special attention to proper
thermal design is highly recommended. LEDiL has no liability for direct,
indirect or consecutive damages arising from the LEDiL products being used
outside of the recommended temperature range.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
6/6
很抱歉,暂时无法提供与“F15074_ZORYA-SC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1625.48542
- 2+1584.85062
- 4+1560.46142
- 国内价格
- 1+62.75379
- 9+61.36875
- 18+60.05660
