PRODUCT DATASHEET
Leila series
last update 12/4/2013
Ordering number FCN11456_LD1-M2
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Leila
Diamond Dragon
White
21.6 mm
15.4 mm
Round
PMMA
PC
Tape
Ready
FWHM
Efficiency
cd/lm
Gerber File
(simulated) 28
(simulated) 0 %
Available
FWHM
Efficiency
cd/lm
Gerber File
8 degrees
(simulated) 0 %
Available
FWHM
Efficiency
cd/lm
Gerber File
14 degrees
(simulated) 0 %
Available
FWHM
Efficiency
cd/lm
Gerber File
24 degrees
(simulated) 0 %
Available
Ordering number FCN10796_LD1-RS
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Leila
Diamond Dragon
White
21.6 mm
15.4 mm
Round
PMMA
PC
Glue
Ready
Ordering number FCN10798_LD1-D
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Leila
Diamond Dragon
White
21.6 mm
15.4 mm
Round
PMMA
PC
Glue
Ready
Ordering number FCN10795_LD1-M
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Leila
Diamond Dragon
White
21.6 mm
15.4 mm
Round
PMMA
PC
Glue
Ready
September 30th 2013 18:38 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
http://www.ledil.com
email: ledil@ledil.com
FAX: +358-2-733 8001
PRODUCT DATASHEET
Leila series
Ordering number FCN10797_LD1-REC
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Leila
Diamond Dragon
White
21.6 mm
15.4 mm
Round
PMMA
PC
Glue
Ready
FWHM
Efficiency
cd/lm
Gerber File
40+24 degrees
(simulated) 0 %
Available
FWHM
Efficiency
cd/lm
Gerber File
40+14 degrees
(simulated) 0 %
Available
Ordering number FCN11107_LD1-O-90
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Leila
Diamond Dragon
White
21.6 mm
15.4 mm
Round
PMMA
PC
Glue
Ready
NOTE: The typical divergence will be changed by different color, chip size and chip position
tolerance. The typical total divergence is the full angle measured where the luminous intensity
is half of the peak value.
September 30th 2013 18:38 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
PRODUCT DATASHEET
Leila series
GENERAL INFORMATION
- Product series especially designed & optimized for Diamond Dragon series of LEDs.
- Special care taken to make light distribution as uniform as possible.
- Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220
degrees of Fahrenheit). Allows use of high current and temperature conditions.
Please find more information about used material from below:
http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf
http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf
- Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit).
- Fastening to heat sink with a PU foam adhesive tape of automotive grade. Please find fastening details by
clicking link: http://www.ledil.com/datasheets/DataSheet_TAPE.pdf
- Fastening to PCB with appropriate adhesive. By clicking link below you can find Ledil recommended glue
options.
http://www.ledil.com/datasheets/DataSheet_GLUES.pdf
NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end
product. For example, mechanical stress, vibration and holes on the surface of the circuit boar
weaken the strength of the tape.
NOTE 2: Assembly to the surface must be made straight, so the tape bonds constant and
balanced with fastening surface. Slanted assembly might cause unbalanced bond to the
surface. All surfaces where tape is applied must be clean, dry and free from grease and dirt.
If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your
LED manufacturer - this is important as cleaning shall under no circumstances damage LEDs or
other electronics components on the PCB.
Further note that optical components shall not be cleaned with any chemicals - only micro fiber
cloth may be used to remove fingerprints or other traces from handling.
weaken the strength of the glue.
NOTE 2: All surfaces where glue is applied must be clean, dry and free from grease and dirt. If
cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED
manufacturer -this is important as cleaning shall under no circumstances damage LEDs or other
September 30th 2013 18:38 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
A
B
C
D
4
21
2
15.4
3
Lens
3
Holder
Materials:
Lens PMMA
Holder PC
2
This drawing is our property.
It can't be reproduced
or communicated without
our written agreement.
1
4
.6
DRAWN BY
DATE
CHECKED BY
DATE
DESIGNED BY
DATE
Led
Teh
FIN
Fin
DRAWING TITLE
pv
26.03.2010
tk
29.04.2009
HH
21.02.2008
D
SIZE
Datasheet LD1-Series Assy
DRAWING NUMBER
REV
1
A4
SCALE
2:1 WEIGHT(g)
SHEET
A
1/1
1
很抱歉,暂时无法提供与“FCN10798_LD1-D”相匹配的价格&库存,您可以联系我们找货
