FCN10809_LC1-REC
FCN10809_LC1-REC
    LEDIL(芬兰)
    LENS AND HOLDER FOR CREE XR-E,C
FCN10809_LC1-REC 数据手册
PRODUCT DATASHEET Leila series last update 14/6/2012 Ordering number FCN11459_LC1-M2 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila XR-E White 21.6 mm 16.5 mm Round PMMA PC Glue Ready FWHM Efficiency cd/lm Gerber File (simulated) 28 (simulated) 0 % Available FWHM Efficiency cd/lm Gerber File 6 degrees (simulated) 0 % Available FWHM Efficiency cd/lm Gerber File 10 degrees (simulated) 0 % Available FWHM Efficiency cd/lm Gerber File 10+42 degrees 85 % Available Ordering number FCN10808_LC1-RS Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila XR-E White 21.6 mm 16.5 mm Round PMMA PC Glue Ready Ordering number FCN10810_LC1-D Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila XR-E White 21.6 mm 16.5 mm Round PMMA PC Glue Ready Ordering number FCN11104_LC1-O-90 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila XR-E White 21.6 mm 16.5 mm Round PMMA PC Glue Ready September 30th 2013 18:42 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Leila series last update 14/6/2012 Ordering number FCN11372_LC1-MD Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila XR-E White 21.6 mm 16.5 mm Round PMMA PC Glue Ready FWHM Efficiency cd/lm Gerber File 24 degrees 90 % Available FWHM Efficiency cd/lm Gerber File 28 degrees (simulated) 0 % Available FWHM Efficiency cd/lm Gerber File 42+22 degrees (simulated) 0 % Available Ordering number FCN10807_LC1-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila XR-E White 21.6 mm 16.5 mm Round PMMA PC Glue Ready Ordering number FCN10809_LC1-REC Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Leila XR-E White 21.6 mm 16.5 mm Round PMMA PC Glue Ready NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. September 30th 2013 18:42 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Leila series last update 14/6/2012 GENERAL INFORMATION - Product series especially designed & optimized for XR-E series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). - Fastening to PCB with appropriate adhesive. By clicking link below you can find Ledil recommended glue options. http://www.ledil.com/datasheets/DataSheet_GLUES.pdf NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the glue. NOTE 2: All surfaces where glue is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer -this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. September 30th 2013 18:42 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 4 16.5 mm 3 21 Materials: Lens PMMA Holder PC DRAWN BY DATE CHECKED BY DATE DESIGNED BY DATE tk 29.04.2009 21.02.2008 D m Led Teh FIN Fin DRAWING TITLE pv 29.04.2009 HH m .6 2 This drawing is our property. It can't be reproduced or communicated without our written agreement. 1 A B C D 2 3 4 7 mm SIZE Datasheet LC1-Series Assy DRAWING NUMBER REV 1 A4 SCALE 2:1 WEIGHT(g) SHEET A 1/1 1
FCN10809_LC1-REC 价格&库存
很抱歉,暂时无法提供与“FCN10809_LC1-REC”相匹配的价格&库存,您可以联系我们找货
