FN16258_STELLA-RS
FN16258_STELLA-RS
    LEDIL(芬兰)
    LENSROUND1 POS90MM (D)39,15MM(H)
FN16258_STELLA-RS 数据手册
PRODUCT DATASHEET FN16258_STELLA-RS STELLA-RS ~25° spot beam. Compatible with up to 30 mm LES size COBs. Variant with black frame. SPECIFICATION: Dimensions Height Fastening Ø 90.0 mm 39.2 mm screw Ingress protection classes ROHS compliant IP67 yes MATERIALS: Component Type Material Colour Finish Length STELLA-RS Single lens Silicone clear 85.0 STELLA-FRAME Holder PA66 black 90.0 ORDERING INFORMATION: Component FN16258_STELLA-RS » Box size: 480 x 280 x 300 mm Qty in box Single lens 90 MOQ MPQ 90 15 Box weight (kg) 9.8 Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/16 PRODUCT DATASHEET FN16258_STELLA-RS See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/16 PRODUCT DATASHEET FN16258_STELLA-RS OPTICAL RESULTS (MEASURED): LED V22 Gen7 FWHM / FWTM 29.0° / 59.0° Efficiency 94 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 431 Typ Z1 LED V22 Gen7 FWHM / FWTM 29.0° / 59.0° Efficiency 94 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED V22 Gen7 FWHM / FWTM 29.0° / 60.0° Efficiency 94 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213480-1 Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/16 PRODUCT DATASHEET FN16258_STELLA-RS OPTICAL RESULTS (MEASURED): LED VERO13 FWHM / FWTM 18.0° / 38.0° Efficiency 94 % Peak intensity 6.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED VERO18 FWHM / FWTM 24.0° / 49.0° Efficiency 94 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED VERO29 FWHM / FWTM 39.0° / 84.0° Efficiency 94 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/16 PRODUCT DATASHEET FN16258_STELLA-RS OPTICAL RESULTS (MEASURED): LED CLL04x/CLU04x FWHM / FWTM 29.0° / 58.0° Efficiency 94 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CXA/B 30xx FWHM / FWTM 31.0° / 61.0° Efficiency 94 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON CoB 1211 FWHM / FWTM 26.0° / 53.0° Efficiency 94 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 431 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/16 PRODUCT DATASHEET FN16258_STELLA-RS OPTICAL RESULTS (MEASURED): LED COB H-Type FWHM / FWTM 30.0° / 61.0° Efficiency 94 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED COB J-Type FWHM / FWTM 20.0° / 42.0° Efficiency 94 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LC040D / LC060D / LC080D FWHM / FWTM 29.0° / 62.0° Efficiency 93 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/16 PRODUCT DATASHEET FN16258_STELLA-RS OPTICAL RESULTS (SIMULATED): LED V10 Gen7 FWHM / FWTM 14.0° / 32.0° Efficiency 96 % Peak intensity 9.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 486 Typ L1 LED V13 Gen 8-9 FWHM / FWTM 20.0° / 41.0° Efficiency 86 % Peak intensity 4.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED V18 Gen 8-9 FWHM / FWTM 25.0° / 51.0° Efficiency 85 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 462 Typ L4 Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/16 PRODUCT DATASHEET FN16258_STELLA-RS OPTICAL RESULTS (SIMULATED): LED V22 Gen 8-9 FWHM / FWTM 30.0° / 61.0° Efficiency 85 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 431 Typ L4 LED VERO10 FWHM / FWTM 13.0° / 28.0° Efficiency 94 % Peak intensity 11.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Vesta TW 13mm (18W) DP FWHM / FWTM 18.0° / 40.0° Efficiency 86 % Peak intensity 5.2 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/16 PRODUCT DATASHEET FN16258_STELLA-RS OPTICAL RESULTS (SIMULATED): LED Vesta TW 18mm (31W) DP FWHM / FWTM 26.0° / 52.0° Efficiency 86 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: LED Vesta TW 22mm DP FWHM / FWTM 28.0° / 57.0° Efficiency 86 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: LED Vesta TW 29mm DP FWHM / FWTM 35.0° / 72.0° Efficiency 86 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/16 PRODUCT DATASHEET FN16258_STELLA-RS OPTICAL RESULTS (SIMULATED): LED CLL05x/CLU05x FWHM / FWTM 43.0° / 98.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CMA2550 FWHM / FWTM 27.0° / 52.0° Efficiency 94 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CMA3090 FWHM / FWTM 30.0° / 60.0° Efficiency 94 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/16 PRODUCT DATASHEET FN16258_STELLA-RS OPTICAL RESULTS (SIMULATED): LED CMU22xx FWHM / FWTM 30.0° / 59.0° Efficiency 95 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 431 Typ L4 LED CXA/B 25xx FWHM / FWTM 25.0° / 50.0° Efficiency 94 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 31.0° / 63.0° Efficiency 94 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/16 PRODUCT DATASHEET FN16258_STELLA-RS OPTICAL RESULTS (SIMULATED): LED LUXEON CoB 1321 FWHM / FWTM 41.0° / 89.0° Efficiency 94 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON CoB 1825 FWHM / FWTM 44.1° / 102.3° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CxM-22 (28x28) FWHM / FWTM 30.0° / 60.0° Efficiency 95 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 431 Typ L4 Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/16 PRODUCT DATASHEET FN16258_STELLA-RS OPTICAL RESULTS (SIMULATED): LED XFM-5050 3 Die FWHM / FWTM 40.0° / 164.0° Efficiency 42 % LEDs/each optic 21 Light colour/type UV-C Required components: The UVC LED result tolerance is ±10 % LED Fortimo SLM L13 CoB FWHM / FWTM 18.0° / 40.0° Efficiency 85 % Peak intensity 5.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Fortimo SLM L19 CoB FWHM / FWTM 26.0° / 52.0° Efficiency 85 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/16 PRODUCT DATASHEET FN16258_STELLA-RS OPTICAL RESULTS (SIMULATED): LED Fortimo SLM L23 CoB FWHM / FWTM 30.0° / 59.0° Efficiency 85 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SLE 13mm 3000lm xxx R ADV8 FWHM / FWTM 20.0° / 40.0° Efficiency 86 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SLE 17mm 5000lm xxx R ADV8 FWHM / FWTM 24.0° / 48.0° Efficiency 86 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 466 Typ L4 Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/16 PRODUCT DATASHEET FN16258_STELLA-RS OPTICAL RESULTS (SIMULATED): LED SLE 21mm 6000lm xxx R ADV8 FWHM / FWTM 30.0° / 58.0° Efficiency 85 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 466 Typ L4 Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/16 PRODUCT DATASHEET FN16258_STELLA-RS GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 12/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/16
FN16258_STELLA-RS 价格&库存
很抱歉,暂时无法提供与“FN16258_STELLA-RS”相匹配的价格&库存,您可以联系我们找货
FN16258_STELLA-RS
    FN16258_STELLA-RS
    • 1+1021.36831
    • 4+998.91608
    • 8+977.46358
    库存:1
    FN16258_STELLA-RS
