C10265_LEDILSTAR-L-S
    LEDIL(芬兰)
    Lens with Integrated Mount Clear 12° Spot Ostar® LE W Exx series Adhesive, Screw
C10265_LEDILSTAR-L-S 数据手册
PRODUCT DATASHEET LedilStar series last update 9/3/2014 Product number C10265_LEDILSTAR-L-S Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status LedilStar Lens Ostar Lighting Clear 35 mm 24.6 mm Round PMMA Screw, glue On production Product number C10266_LEDILSTAR-L-W Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status LedilStar Lens Ostar Lighting Clear 35 mm 24.6 mm Round PMMA Screw, glue On production FWHM Efficiency cd/lm Gerber File 12 degrees Available FWHM Efficiency cd/lm Gerber File 32 degrees Available NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. May 14th 2015 12:26 Copyright Ledil Oy - Subject to change without prior notice - Page 1/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET LedilStar series last update 9/3/2014 GENERAL INFORMATION - Product series especially designed & optimized for Ostar Lighting series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance. Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf May 14th 2015 12:26 Copyright Ledil Oy - Subject to change without prior notice - Page 2/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001
C10265_LEDILSTAR-L-S 价格&库存
很抱歉,暂时无法提供与“C10265_LEDILSTAR-L-S”相匹配的价格&库存,您可以联系我们找货
