C11347_REGINA
C11347_REGINA
    LEDIL(芬兰)
    REFLECTOR FOR XP-E,C,G & N119
C11347_REGINA 数据手册
PRODUCT DATASHEET Regina series last update 26/6/2013 Product number C11347_REGINA Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Regina Reflector XP-G Metal 19 mm 15.3 mm Round PC Pin, glue On production FWHM Efficiency cd/lm Gerber File 10 degrees 86 % (simulated) 0.000 Available NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. May 14th 2015 12:27 Copyright Ledil Oy - Subject to change without prior notice - Page 1/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Regina series last update 26/6/2013 GENERAL INFORMATION - Product series especially designed & optimized for XP-G series of LEDs. - Special care taken to make light distribution as uniform as possible. - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (short term 100 degrees of Celcius / 212 degrees of Fahrenheit). May 14th 2015 12:27 Copyright Ledil Oy - Subject to change without prior notice - Page 2/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 Relative intensity of C11347_Regina-RE-ES 100% 75% 50% 25% 0% 20 15 10 5 0 -5 -10 -15 -20 Relative Intensity of C11347_Regina-XP-G 100 % 75 % 50 % 25 % 0% 30 25 20 15 10 5 0 -5 -10 -15 -20 -25 -30
C11347_REGINA 价格&库存
很抱歉,暂时无法提供与“C11347_REGINA”相匹配的价格&库存,您可以联系我们找货
C11347_REGINA
  • 1+36.612271+4.74257
  • 10+26.9951510+3.49682
  • 112+21.08047112+2.73066
  • 560+18.64656560+2.41539
  • 1008+17.966971008+2.32735
  • 2016+17.279962016+2.23836
  • 5040+16.531895040+2.14146
库存:525
C11347_REGINA
    C11347_REGINA
      库存:28
      C11347_REGINA
      • 1+17.359791+2.24870
      • 112+13.78315112+1.78540
      • 336+12.99804336+1.68370
      • 560+12.12569560+1.57070
      库存:282
      C11347_REGINA
        库存:28
