C12599_LENINA-W
C12599_LENINA-W
    LEDIL(芬兰)
    REFLECTOR RND 1POS 74MM 40MM HT
C12599_LENINA-W 数据手册
PRODUCT DATASHEET C12599_LENINA-W LENINA-W ~55° wide beam SPECIFICATION: Dimensions Ø 74.0 mm Height 40 mm Fastening socket ROHS compliant yes MATERIALS: Component Type Material Colour LENINA-W Reflector PC metal Finish Coating lacquer ORDERING INFORMATION: Component C12599_LENINA-W » Box size: 476 x 273 x 197 mm Qty in box 60 MOQ MPQ 120 60 Box weight (kg) 2.0 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/49 PRODUCT DATASHEET C12599_LENINA-W See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED BXRA ES Rectangle FWHM / FWTM 60.0° / 84.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12153_LENA-STD-BASE-BXRA C12606_LENINA-DL LED BXRA ES Rectangle FWHM / FWTM 58.0° / 82.0° Efficiency 91 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12153_LENA-STD-BASE-BXRA LED BXRA RS FWHM / FWTM 60.0° / 89.0° Efficiency 80 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12229_LENA-STD-BASE-RS C12606_LENINA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED BXRA RS FWHM / FWTM 64.0° / 87.0° Efficiency 88 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12229_LENA-STD-BASE-RS LED V10 Gen6 FWHM / FWTM 47.0° / 80.0° Efficiency 83 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13186_LENA-STD-BASE-CXA15 C12606_LENINA-DL LED V4 HD Gen 7 FWHM / FWTM 48.0° / 79.0° Efficiency 91 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14146_LENA-STD-BASE-CXA18 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED Vero SE 29 FWHM / FWTM 66.0° / 90.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C15083_LENA-STD-BASE-VERO29 LED VERO13 FWHM / FWTM 60.0° / 84.0° Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL LED VERO18 FWHM / FWTM 64.0° / 85.0° Efficiency 89 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED VERO18 FWHM / FWTM 64.0° / 86.0° Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL LED VERO29 FWHM / FWTM 67.0° / 91.0° Efficiency 88 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 LED VERO29 FWHM / FWTM 67.0° / 92.0° Efficiency 84 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CL-L340 FWHM / FWTM 53.0° / 81.0° Efficiency 91 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11995_LENA-STD-BASE-CL340 LED CL-L340 FWHM / FWTM 50.0° / 83.0° Efficiency 78 % LEDs/each optic 1 Light colour/type White Required components: C11995_LENA-STD-BASE-CL340 C12606_LENINA-DL LED CL-L340 FWHM / FWTM 48.0° / 80.0° Efficiency 86 % LEDs/each optic 1 Light colour/type White Required components: C11995_LENA-STD-BASE-CL340 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CLL02x/CLU02x (LES10) FWHM / FWTM 57.0° / 82.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 434 Typ L1 LED CLL03x/CLU03x FWHM / FWTM 60.0° / 83.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 433 Typ L1 LED CLL03x/CLU03x FWHM / FWTM 58.0° / 84.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C12606_LENINA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CLL03x/CLU03x FWHM / FWTM 56.0° / 82.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 LED CLL04x/CLU04x FWHM / FWTM 54.0° / 83.0° Efficiency 87 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2204CT + 50-2100LN LED CLL04x/CLU04x FWHM / FWTM 55.0° / 84.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12606_LENINA-DL IDEAL: 50-2204CT + 50-2100LN Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CLL04x/CLU04x FWHM / FWTM 59.0° / 85.0° Efficiency 84 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED CLL04x/CLU04x FWHM / FWTM 61.0° / 87.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 431 Typ L3 LED CLL04x/CLU04x FWHM / FWTM 56.0° / 87.0° Efficiency 76 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CLL04x/CLU04x FWHM / FWTM 57.0° / 84.0° Efficiency 82 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: A.A.G. STUCCHI: 8102-G2 + S-8000-12 LED CLL04x/CLU04x FWHM / FWTM 58.0° / 85.0° Efficiency 78 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12606_LENINA-DL A.A.G. STUCCHI: 8102-G2 + S-8000-12 LED CLL04x/CLU04x FWHM / FWTM 61.0° / 85.0° Efficiency 91 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 431 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CLU710/711 FWHM / FWTM 55.0° / 82.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C12606_LENINA-DL LED CLU720/721/723 FWHM / FWTM 57.0° / 83.0° Efficiency 83 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C12606_LENINA-DL LED CLU720/721/723 FWHM / FWTM 54.0° / 81.0° Efficiency 87 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CLU730/731/733 FWHM / FWTM 50.0° / 82.0° Efficiency 83 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL LED CLU730/731/733 FWHM / FWTM 49.0° / 80.0° Efficiency 93 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED CMA1840 FWHM / FWTM 48.0° / 79.0° Efficiency 91 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14146_LENA-STD-BASE-CXA18 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CMA2550 FWHM / FWTM 51.0° / 80.0° Efficiency 91 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13324_LENA-STD-BASE-CXA25 LED CMT14xx FWHM / FWTM 55.0° / 81.0° Efficiency 91 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 434 Typ L1 LED CMT19xx FWHM / FWTM 54.0° / 81.0° Efficiency 91 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 Bender Wirth: 477 Typ L1 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CMT19xx FWHM / FWTM 55.0° / 82.0° Efficiency 91 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 477 Typ L1 LED CMT28xx FWHM / FWTM 60.0° / 84.0° Efficiency 91 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 471 Typ L3 LED CMT28xx FWHM / FWTM 56.0° / 82.0° Efficiency 92 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CXA/B 15xx FWHM / FWTM 48.0° / 79.0° Efficiency 83 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13186_LENA-STD-BASE-CXA15 C12606_LENINA-DL LED CXA/B 15xx FWHM / FWTM 57.0° / 82.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 441 Typ L1 LED CXA/B 1830 FWHM / FWTM 60.0° / 83.0° Efficiency 91 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 437 Typ L1 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CXA/B 1830 FWHM / FWTM 61.0° / 85.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 437 Typ L1 LED CXA/B 25xx FWHM / FWTM 51.0° / 80.0° Efficiency 84 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13324_LENA-STD-BASE-CXA25 LED CXA/B 25xx FWHM / FWTM 52.0° / 80.0° Efficiency 76 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13324_LENA-STD-BASE-CXA25 C12606_LENINA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CXA2011 FWHM / FWTM 52.0° / 83.0° Efficiency 78 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12105_LENA-STD-BASE-CXA20 C12606_LENINA-DL LED CXA2011 FWHM / FWTM 50.0° / 80.0° Efficiency 86 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12105_LENA-STD-BASE-CXA20 LED CHI3030 19W FWHM / FWTM 62.0° / 88.0° Efficiency 90 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 468 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CHI3030 29W FWHM / FWTM 63.0° / 92.0° Efficiency 86 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 468 Typ L3 LED LUXEON CoB 1204/1205 FWHM / FWTM 55.0° / 81.0° Efficiency 89 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ LED LUXEON CoB 1204/1205 FWHM / FWTM 57.0° / 82.0° Efficiency 84 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1204HD FWHM / FWTM 51.0° / 79.0° Efficiency 91 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11981_LENA-STD-BASE-COB-L110 LED LUXEON CoB 1205HD FWHM / FWTM 54.0° / 80.0° Efficiency 91 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11981_LENA-STD-BASE-COB-L110 LED LUXEON CoB 1208 FWHM / FWTM 60.0° / 83.0° Efficiency 84 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1208 FWHM / FWTM 58.0° / 82.0° Efficiency 88 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ LED LUXEON CoB 1211 FWHM / FWTM 60.0° / 84.0° Efficiency 91 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 431 Typ L3 LED LUXEON CoB 1211 FWHM / FWTM 60.0° / 86.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 431 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 58.0° / 85.0° Efficiency 84 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: A.A.G. STUCCHI: 8102-G2 + S-8000-12 LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 58.0° / 86.0° Efficiency 80 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12606_LENINA-DL A.A.G. STUCCHI: 8102-G2 + S-8000-12 LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 58.0° / 84.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 58.0° / 85.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL LED LUXEON K12 FWHM / FWTM 54.0° / 81.0° Efficiency 88 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12924_LENA-STD-BASE-LUXEON-K LED LUXEON K12 FWHM / FWTM 57.0° / 83.0° Efficiency 83 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12924_LENA-STD-BASE-LUXEON-K C12606_LENINA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED LUXEON K16 FWHM / FWTM 56.0° / 85.0° Efficiency 79 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12924_LENA-STD-BASE-LUXEON-K C12606_LENINA-DL LED LUXEON K16 FWHM / FWTM 55.0° / 81.0° Efficiency 85 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12924_LENA-STD-BASE-LUXEON-K LED CDM-14 (Dim-To-Warm) FWHM / FWTM 58.0° / 83.0° Efficiency 91 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 491 Typ L2 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 24/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CDM-14 (Dim-To-Warm) FWHM / FWTM 60.0° / 85.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 491 Typ L2 LED CDM-18 (Dim-To-Warm) FWHM / FWTM 64.0° / 85.0° Efficiency 91 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 491 Typ L2 LED CDM-18 (Dim-To-Warm) FWHM / FWTM 62.0° / 86.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 491 Typ L2 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 25/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CDM-9 (Dim-To-Warm) FWHM / FWTM 59.0° / 83.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 490 Typ L1 LED CDM-9 (Dim-To-Warm) FWHM / FWTM 55.0° / 81.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 490 Typ L1 LED CTM-14 (Tunable White) FWHM / FWTM 58.0° / 83.0° Efficiency 91 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 442 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 26/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CTM-14 (Tunable White) FWHM / FWTM 60.0° / 85.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 442 Typ L3 LED CTM-18 (Tunable White) FWHM / FWTM 32.0° / 76.0° Efficiency 92 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 442 Typ L3 LED CTM-18 (Tunable White) FWHM / FWTM 63.0° / 87.0° Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 442 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 27/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CTM-22 (Tunable White) FWHM / FWTM 63.0° / 89.0° Efficiency 85 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 494 Typ L3 LED CTM-22 (Tunable White) FWHM / FWTM 63.0° / 87.0° Efficiency 90 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 494 Typ L3 LED CxM-14 (19x19) FWHM / FWTM 58.0° / 82.0° Efficiency 92 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 28/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED CxM-14 (19x19) FWHM / FWTM 59.0° / 84.0° Efficiency 88 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C12606_LENINA-DL LED CxM-22 (28x28) FWHM / FWTM 58.0° / 86.0° Efficiency 92 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED CxM-22 (28x28) FWHM / FWTM 58.0° / 86.0° Efficiency 87 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 29/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED COB J-Type FWHM / FWTM 59.0° / 84.0° Efficiency 87 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 463 Typ L2 LED COB J-Type FWHM / FWTM 59.0° / 84.0° Efficiency 82 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL LED COB J-Type FWHM / FWTM 59.0° / 83.0° Efficiency 91 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 463 Typ L2 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 30/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED COB J-Type FWHM / FWTM 58.0° / 82.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ LED COB L-Type (LES 11) FWHM / FWTM 58.0° / 82.0° Efficiency 80 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11981_LENA-STD-BASE-COB-L110 C12606_LENINA-DL LED COB L-Type (LES 11) FWHM / FWTM 56.0° / 81.0° Efficiency 85 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11981_LENA-STD-BASE-COB-L110 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 31/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED NVCWJ024Z-V1MT: COB J-Type Tunable White FWHM / FWTM 56.0° / 81.0° Efficiency 91 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 498 Typ L2 LED NVCWJ024Z-V1MT: COB J-Type Tunable White FWHM / FWTM 60.0° / 84.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 498 Typ L2 LED Soleriq S13 FWHM / FWTM 59.0° / 83.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 437 Typ L1 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 32/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED Soleriq S13 FWHM / FWTM 56.0° / 81.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 437 Typ L1 LED Soleriq S19 FWHM / FWTM 60.0° / 84.0° Efficiency 92 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 462 Typ L3 LED Soleriq S19 FWHM / FWTM 60.0° / 85.0° Efficiency 87 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 462 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 33/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED Fortimo SLM L13 CoB FWHM / FWTM 57.0° / 83.0° Efficiency 85 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL LED Fortimo SLM L13 CoB FWHM / FWTM 57.0° / 81.0° Efficiency 92 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ LED Fortimo SLM L15 CoB FWHM / FWTM 56.0° / 83.0° Efficiency 85 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 34/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED Fortimo SLM L15 CoB FWHM / FWTM 59.0° / 82.0° Efficiency 91 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ LED Fortimo SLM L19 CoB FWHM / FWTM 53.0° / 81.0° Efficiency 91 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED Fortimo SLM L19 CoB FWHM / FWTM 54.0° / 83.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 35/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED Fortimo SLM L23 CoB FWHM / FWTM 57.0° / 84.0° Efficiency 85 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL LED Fortimo SLM L23 CoB FWHM / FWTM 39.0° / 76.0° Efficiency 92 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 57.0° / 82.0° Efficiency 91 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 36/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 59.0° / 84.0° Efficiency 87 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C12606_LENINA-DL LED LC026B / 033B / 040B FWHM / FWTM 61.0° / 85.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 450 Typ L2 LED LC026B / 033B / 040B FWHM / FWTM 61.0° / 84.0° Efficiency 91 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 450 Typ L2 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 37/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED LC040D / LC060D / LC080D FWHM / FWTM 59.0° / 85.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL LED LC040D / LC060D / LC080D FWHM / FWTM 59.0° / 84.0° Efficiency 91 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED ZC12/18 FWHM / FWTM 59.0° / 84.0° Efficiency 84 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C12606_LENINA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 38/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED ZC12/18 FWHM / FWTM 57.0° / 82.0° Efficiency 88 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 LED ZC25/40/60 FWHM / FWTM 60.0° / 86.0° Efficiency 82 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL LED ZC25/40/60 FWHM / FWTM 60.0° / 85.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 39/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED Mega Zenigata (GW5DGC) FWHM / FWTM 45.0° / 80.0° Efficiency 78 % LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL LED Mega Zenigata (GW5DGC) FWHM / FWTM 41.0° / 77.0° Efficiency 86 % LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ LED Mega Zenigata (GW6DME) FWHM / FWTM 59.0° / 83.0° Efficiency 83 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 40/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED Mega Zenigata (GW6DME) FWHM / FWTM 57.0° / 82.0° Efficiency 87 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ LED SLE G7 LES15 FWHM / FWTM 59.0° / 82.0° Efficiency 92 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 LED SLE G7 LES17 H FWHM / FWTM 56.0° / 82.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14547_LENA-ADAPTER-B Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 41/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (MEASURED): LED XOB 14.5 mm FWHM / FWTM 58.0° / 82.0° Efficiency 91 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 42/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (SIMULATED): LED V10 Gen7 FWHM / FWTM 55.0° / 81.0° Efficiency 85 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 486 Typ L1 LED V13 Gen7 FWHM / FWTM 63.0° / 91.0° Efficiency 87 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 477 Typ L1 LED V13 Gen7 FWHM / FWTM 48.0° / 82.0° Efficiency 88 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12606_LENINA-DL IDEAL: 50-2103CT + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 43/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (SIMULATED): LED V13 Gen7 FWHM / FWTM 46.0° / 79.0° Efficiency 90 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2103CT + 50-2100AN LED V13 Gen7 FWHM / FWTM 50.0° / 79.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 477 Typ L1 LED V22 Gen7 FWHM / FWTM 61.0° / 82.0° Efficiency 87 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 431 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 44/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (SIMULATED): LED V22 Gen7 FWHM / FWTM 61.0° / 84.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 431 Typ L3 LED CXA/B 30xx FWHM / FWTM 46.0° / 80.0° Efficiency 89 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2234C + 50-2100LN LED CXA/B 30xx FWHM / FWTM 49.0° / 81.0° Efficiency 84 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12606_LENINA-DL IDEAL: 50-2234C + 50-2100LN Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 45/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (SIMULATED): LED CxM-14 (19x19) FWHM / FWTM 60.0° / 83.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 433 Typ L1 LED CxM-14 (19x19) FWHM / FWTM 57.0° / 82.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 433 Typ L1 LED CxM-9 (13.5x13.5) FWHM / FWTM 57.0° / 82.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 434 Typ L1 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 46/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (SIMULATED): LED CxM-9 (13.5x13.5) FWHM / FWTM 54.0° / 80.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 LED Soleriq S15 FWHM / FWTM 56.0° / 81.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 LED ZC12/18 FWHM / FWTM 57.0° / 82.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 433 Typ L1 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 47/49 PRODUCT DATASHEET C12599_LENINA-W OPTICAL RESULTS (SIMULATED): LED ZC12/18 FWHM / FWTM 60.0° / 83.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 433 Typ L1 LED ZC4/6 FWHM / FWTM 54.0° / 80.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 434 Typ L1 LED ZC4/6 FWHM / FWTM 57.0° / 82.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 434 Typ L1 Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 48/49 PRODUCT DATASHEET C12599_LENINA-W GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 49/49
C12599_LENINA-W 价格&库存
很抱歉,暂时无法提供与“C12599_LENINA-W”相匹配的价格&库存,您可以联系我们找货
C12599_LENINA-W
    库存:111
    C12599_LENINA-W
      C12599_LENINA-W
