C12608_VIRPI-M
C12608_VIRPI-M
    LEDIL(芬兰)
    LENS ARRAY SQUARE 25 POS 74.9 X
C12608_VIRPI-M 数据手册
PRODUCT DATASHEET C12608_VIRPI-M VIRPI-M ~30° medium beam SPECIFICATION: Dimensions Height Fastening ROHS compliant 74.9 x 74.9 mm 9.5 mm glue, pin yes MATERIALS: Component Type Material Colour VIRPI-M Multi-lens PMMA clear Finish ORDERING INFORMATION: Component C12608_VIRPI-M » Box size: 480 x 280 x 300 mm Qty in box 360 MOQ MPQ 45 15 Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 12.2 1/12 PRODUCT DATASHEET C12608_VIRPI-M See also our general installation guide: www.ledil.com/installation_guide Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/12 PRODUCT DATASHEET C12608_VIRPI-M OPTICAL RESULTS (MEASURED): LED ML-E FWHM / FWTM 29.0° / 58.0° Efficiency 91 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XB-D FWHM / FWTM 28.0° / 56.0° Efficiency 92 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XH-B/G FWHM / FWTM 30.0° / 58.0° Efficiency 90 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 28.0° / 52.0° Efficiency 91 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/12 PRODUCT DATASHEET C12608_VIRPI-M OPTICAL RESULTS (MEASURED): LED XP-G FWHM / FWTM 29.0° / 58.0° Efficiency 92 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 29.0° / 56.0° Efficiency 91 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 29.0° / 57.0° Efficiency 91 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel ES FWHM / FWTM 28.0° / 57.0° Efficiency 91 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/12 PRODUCT DATASHEET C12608_VIRPI-M OPTICAL RESULTS (MEASURED): LED NF2x757A FWHM / FWTM 28.0° / 53.0° Efficiency 92 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19A FWHM / FWTM 29.0° / 56.0° Efficiency 90 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S5 (Single chip) FWHM / FWTM 28.0° / 51.0° Efficiency 92 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 2226 FWHM / FWTM 29.0° / 56.0° Efficiency 90 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/12 PRODUCT DATASHEET C12608_VIRPI-M OPTICAL RESULTS (MEASURED): LED OSLON Square EC FWHM / FWTM 28.0° / 55.0° Efficiency 91 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LM231 A/B FWHM / FWTM 28.0° / 52.0° Efficiency 92 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/12 PRODUCT DATASHEET C12608_VIRPI-M OPTICAL RESULTS (SIMULATED): LED J Series 3030 FWHM / FWTM 26.0° / 52.0° Efficiency 95 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 2835 Line FWHM / FWTM 22.0° / 51.0° Efficiency 95 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON C FWHM / FWTM 23.0° / 50.0° Efficiency 86 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON CZ FWHM / FWTM 20.0° / 48.0° Efficiency 94 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/12 PRODUCT DATASHEET C12608_VIRPI-M OPTICAL RESULTS (SIMULATED): LED LUXEON SunPlus 20 Line (150 deg) FWHM / FWTM 27.0° / 51.0° Efficiency 88 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON SunPlus 35 Line FWHM / FWTM 26.0° / 50.0° Efficiency 93 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON T FWHM / FWTM 26.0° / 53.0° Efficiency 91 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 27.0° / 53.0° Efficiency 92 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/12 PRODUCT DATASHEET C12608_VIRPI-M OPTICAL RESULTS (SIMULATED): LED SST-10-B130 FWHM / FWTM 24.0° / 51.0° Efficiency 94 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour Red Required components: LED SST-20 FWHM / FWTM 24.0° / 51.0° Efficiency 94 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 27.0° / 55.0° Efficiency 94 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3030 FWHM / FWTM 22.0° / 50.0° Efficiency 95 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/12 PRODUCT DATASHEET C12608_VIRPI-M OPTICAL RESULTS (SIMULATED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 26.0° / 52.0° Efficiency 93 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFH 4715AS FWHM / FWTM 20.0° / 48.0° Efficiency 94 % LEDs/each optic 1 Light colour IR Required components: LED LH181B FWHM / FWTM 26.0° / 53.0° Efficiency 93 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351B FWHM / FWTM 27.0° / 56.0° Efficiency 94 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/12 PRODUCT DATASHEET C12608_VIRPI-M OPTICAL RESULTS (SIMULATED): LED LH351C FWHM / FWTM 28.0° / 57.0° Efficiency 94 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED SEOUL DC 3030 FWHM / FWTM 24.0° / 52.0° Efficiency 94 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22 FWHM / FWTM 26.4° / 55.1° Efficiency 94 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/12 PRODUCT DATASHEET C12608_VIRPI-M GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/12/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/12
C12608_VIRPI-M 价格&库存
很抱歉,暂时无法提供与“C12608_VIRPI-M”相匹配的价格&库存,您可以联系我们找货
C12608_VIRPI-M
  • 15+34.5934215+4.32900
  • 45+33.9725145+4.25130
  • 75+33.7951175+4.22910
  • 300+33.08550300+4.14030
  • 450+32.64200450+4.08480
C12608_VIRPI-M
  • 15+40.1815915+5.02830
  • 60+39.3832860+4.92840
  • 150+38.93977150+4.87290
  • 375+38.49627375+4.81740
  • 600+37.78666600+4.72860
C12608_VIRPI-M
  • 2+50.204812+6.28260
  • 5+49.761305+6.22710
  • 20+49.1403920+6.14940
  • 40+48.7855940+6.10500
  • 100+48.07598100+6.01620
