CA10953_IRIS-M
CA10953_IRIS-M
    LEDIL(芬兰)
CA10953_IRIS-M 数据手册
LEDIL F’FORM OPTICS Iris lens for Osram Ostar Lighting LEDs APPLICATIONS: TORCH LIGHTS, DOWNLIGHTS, SPOTLIGHTS - Specially designed for the new Osram Ostar lighting with Star PCB Lens material optical grade PMMA with high UV and temperature resistance (105°C/220°F). Holder material PC. Allows use of high current and temperature conditions Highest practically available optical efficiency on the market Very even color distribution over the whole beam angle. Fastening to PCB and heat sink with screws or with appropriate adhesive, e.g. Loctite 460 or other epoxy or polyurethane. NOTE: DO NOT USE SUPERGLUE. If you decide to use glue only, please take special care of correct positioning. LENS TYPES NAME Iris lens Iris lens + Sub lens ORDERING CODE CA10861_Iris CA10953_Iris-M CA10861_Iris FWHM Angle ±5.5° ±14.8 CA10908_Iris-M © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-10-06 LEDIL F’FORM OPTICS Relative Intensity of CA10861_Iris 100% 75% 50% 25% 0% 20 15 10 5 0 -5 -10 -15 -20 Relative Intensity of CA10908_Iris-M 100% 75% 50% 25% 0% 40 30 20 10 0 -10 -20 -30 -40 © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-10-06 LEDIL F’FORM OPTICS NOTE: DELIVERED UNASSEMBLED © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-10-06
CA10953_IRIS-M 价格&库存
很抱歉,暂时无法提供与“CA10953_IRIS-M”相匹配的价格&库存,您可以联系我们找货
