CA11362_IRIS-RE-TAPE
    LEDIL(芬兰)
CA11362_IRIS-RE-TAPE 数据手册
PRODUCT DATASHEET Iris series last update 27/2/2012 Ordering number FCN12076_IRIS-SCREW Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Iris Lens LUXEON Rebel Black 38 mm 26.9 mm Round PMMA PC Screw, pin, glue Ready FWHM Efficiency cd/lm Gerber File 5 degrees 93 % 75.600 Available FWHM Efficiency cd/lm Gerber File 5 degrees 75.600 Available Ordering number FCX12077_IRIS Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Iris Lens LUXEON Rebel Black 38 mm 28.5 mm Round PMMA PC Pin, tape Ready NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. March 4th 2012 18:33 Copyright Ledil Oy - Subject to change without prior notice - Page 1/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Iris series last update 27/2/2012 GENERAL INFORMATION - Product series especially designed & optimized for LUXEON Rebel series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). - Fastening to heat sink with a PU foam adhesive tape of automotive grade. Please find fastening details by clicking link: http://www.ledil.com/datasheets/DataSheet_TAPE.pdf - Fastening to PCB with appropriate adhesive. By clicking link below you can find Ledil recommended glue options. http://www.ledil.com/datasheets/DataSheet_GLUES.pdf NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the tape. NOTE 2: Assembly to the surface must be made straight, so the tape bonds constant and balanced with fastening surface. Slanted assembly might cause unbalanced bond to the surface. All surfaces where tape is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer - this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the glue. NOTE 2: All surfaces where glue is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer -this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. March 4th 2012 18:33 Copyright Ledil Oy - Subject to change without prior notice - Page 2/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 Relative intensity of C4F12077_Iris-XP-G-tape 100% 75% 50% 25% 0% 20 15 10 5 0 -5 -10 -15 -20 1 A B C D . 53 20 Bottom view Tape not shown 4 4 2.5 2 ho le to PC B 8.6 c/c pin 1.35 without Tape 3 26.9 3 27.1 Front view 38 Top view 2 2 Materials: Lens PMMA Holder PC Tape PU Foam 1 This drawing is our property. It can't be reproduced or communicated without our written agreement. DRAWN BY DATE CHECKED BY DATE Led Teh FIN Fin DRAWING TITLE pv 13.04.2010 tk 19.03.2010 DESIGNED BY ol DATE 19.03.2010 D SIZE Datasheet Iris-XP-E-tape assy DRAWING NUMBER A4 SCALE 1:1 WEIGHT(g) REV - 1 SHEET A 1/1 1
CA11362_IRIS-RE-TAPE 价格&库存
很抱歉,暂时无法提供与“CA11362_IRIS-RE-TAPE”相匹配的价格&库存,您可以联系我们找货
