CA11476_TYRA2-M
CA11476_TYRA2-M
    LEDIL(芬兰)
    LENS ASSY 1POS 40MM RND 24.3MM
CA11476_TYRA2-M 数据手册
PRODUCT DATASHEET Tyra2 series last update 25/6/2014 Product number CA11475_TYRA2-S Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Tyra2 RefAssy MP-L Metal 40 mm 24.3 mm Round PC Pin, tape On production Product number CA11476_TYRA2-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Tyra2 RefAssy MP-L Metal 40 mm 24.3 mm Round PC Pin, tape On production Product number CA11477_TYRA2-W Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Tyra2 RefAssy MP-L Metal 40 mm 24.3 mm Round PC Pin, tape On production FWHM Efficiency cd/lm Gerber File 20 degrees 89 % (simulated) 0.000 Available FWHM Efficiency cd/lm Gerber File 32 degrees 90 % (simulated) 0.000 Available FWHM Efficiency cd/lm Gerber File 52 degrees 89 % (simulated) 0.000 Available NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. May 14th 2015 12:03 Copyright Ledil Oy - Subject to change without prior notice - Page 1/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Tyra2 series last update 25/6/2014 GENERAL INFORMATION - Product series especially designed & optimized for MP-L series of LEDs. - Special care taken to make light distribution as uniform as possible. - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (short term 100 degrees of Celcius / 212 degrees of Fahrenheit). May 14th 2015 12:03 Copyright Ledil Oy - Subject to change without prior notice - Page 2/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 Relative Intensity of CA11477_Tyra2-W-tape 100 % 75 % 50 % 25 % 0% 50 40 30 20 10 0 -10 -20 -30 -40 -50
CA11476_TYRA2-M 价格&库存
很抱歉,暂时无法提供与“CA11476_TYRA2-M”相匹配的价格&库存,您可以联系我们找货
