CA12166_LENA-M-DIFFUSER-LENS-CL340
    LEDIL(芬兰)
CA12166_LENA-M-DIFFUSER-LENS-CL340 数据手册
PRODUCT DATASHEET Lena-L340 series Ordering number CN12367 Description CN12367_LENA-FRESNELL Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CL-L340 Black 111 mm 89 mm Round PC PC Socket, screw Ready FWHM Efficiency cd/lm Gerber File 8 degrees 28.000 Available FWHM Efficiency cd/lm Gerber File 11 degrees Available FWHM Efficiency cd/lm Gerber File 18 degrees Available Ordering number CA12101 Description CA12101_Lena-S-CL340 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CL-L340 Metal 111 mm 86.1 mm Round PC PC Screw Ready Ordering number CA12161 Description CA12161_Lena-M-CL340 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CL-L340 Metal 111 mm 86.1 mm Round PC PC Screw Ready Ordering number CA12166 Description CA12166_Lena-M-Diffuser-Lens-CL340 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CL-L340 Metal 111 mm 87.7 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 20 degrees Available February 13th 2012 15:43 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lena-L340 series Ordering number CA12102 Description CA12102_Lena-W-CL340 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CL-L340 Metal 111 mm 86.1 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 42 degrees Available Ordering number CA12112 Description CA12112_Lena-S-Diffuser-Lens-CL340 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CL-L340 Metal 111 mm 87.7 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 12 degrees Available Ordering number CA12113 Description CA12113_Lena-W-Diffuser-Lens-CL340 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CL-L340 Metal 111 mm 87.7 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 43 degrees Available NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. February 13th 2012 15:43 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lena-L340 series GENERAL INFORMATION - Product series especially designed & optimized for CL-L340 series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PC with high UV and temperature resistance (120 degrees of Celcius / 248 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used materials from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PC%20Makrolon%202400_2407_2456_2458-UL .pdf - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (110 degrees of Celcius / 230 degrees of Fahrenheit). - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). February 13th 2012 15:43 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 A B C D 3 1 3 . 1 3 4 4 23. A Isometric view 43 5 Base part 3 87.7 Lena_reflector w/o sublens Detail A Scale: 1:1 86.1 3 Lena_sublens Lena-STD-base_CL340 11 2 Material: 1 subLens - PMMA 2 Reflector - PC - Metal coating and clear lacquer Holder base - PC - Color white 1 This drawing is our property. It can't be reproduced or communicated without our written agreement. DRAWN BY DATE CHECKED BY DATE DESIGNED BY DATE Led Teh FIN Fin DRAWING TITLE pv 26.05.2011 pl 26.05.2011 pl 11.02.2011 D SIZE Datasheet Lena-CL340 series Assy DRAWING NUMBER REV 1 A4 SCALE 1:2 WEIGHT(g) SHEET A 1/1 1
CA12166_LENA-M-DIFFUSER-LENS-CL340 价格&库存
很抱歉,暂时无法提供与“CA12166_LENA-M-DIFFUSER-LENS-CL340”相匹配的价格&库存,您可以联系我们找货
