CS14597_HB-IP-2X6-O
CS14597_HB-IP-2X6-O
    LEDIL(芬兰)
CS14597_HB-IP-2X6-O 数据手册
PRODUCT DATASHEET CS14597_HB-IP-2X6-O HB-IP-2X6-O ~30° + 115° oval beam SPECIFICATION: Dimensions Height Fastening 173.0 x 71.4 13.1 mm screw Ingress protection classes ROHS compliant IP67 yes MATERIALS: Component Type Material Colour HB-IP-2X6-O Multi-lens PMMA clear 2X6-SEAL25 Seal Silicone white Finish Length 173.0 ORDERING INFORMATION: Component CS14597_HB-IP-2X6-O » Box size: 476 x 273 x 247 mm Qty in box Multi-lens 108 MOQ MPQ 36 36 Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 8.0 1/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O See also our general installation guide: www.ledil.com/installation_guide Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED QUICK FLUX 2x6 LED XG xxx G7+ FWHM / FWTM 116.0 + 32.0° / 149.0 + 92.0° Efficiency 91 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED QUICK FLUX 2x6 LED XT xxx G5 FWHM / FWTM 113.0 + 30.0° / 148.0 + 87.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XM-L FWHM / FWTM 36.0 + 110.0° / 96.0 + 147.0° Efficiency 91 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED XM-L2 FWHM / FWTM 36.0 + 108.0° / 92.0 + 147.0° Efficiency 91 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G FWHM / FWTM 31.0 + 117.0° / 91.0 + 149.0° Efficiency 91 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 FWHM / FWTM 32.0 + 116.0° / 91.0 + 149.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED XP-G3 FWHM / FWTM 33.0 + 119.0° / 100.0 + 150.0° Efficiency 92 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L HD FWHM / FWTM 36.0 + 115.0° / 100.0 + 149.0° Efficiency 91 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L2 FWHM / FWTM 118.0 + 38.0° / 151.0 + 114.0° Efficiency 92 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED XT-E FWHM / FWTM 31.0 + 119.0° / 99.0 + 151.0° Efficiency 92 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XT-E HE FWHM / FWTM 112.0 + 29.0° / 147.0 + 85.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON R FWHM / FWTM 30.0 + 109.0° / 89.0 + 147.0° Efficiency 91 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED LUXEON Rebel FWHM / FWTM 28.0 + 107.0° / 84.0 + 145.0° Efficiency 91 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Rebel ES FWHM / FWTM 30.0 + 110.0° / 88.0 + 146.0° Efficiency 91 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON T FWHM / FWTM 32.0 + 115.0° / 103.0 + 148.0° Efficiency 91 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED LUXEON TX FWHM / FWTM 30.0 + 111.0° / 84.0 + 147.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON V FWHM / FWTM 112.0 + 34.0° / 147.0 + 92.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON V2 FWHM / FWTM 113.0 + 31.0° / 147.0 + 91.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED LUXEON XR-TX (L2T0-xxxx012M0000) FWHM / FWTM 30.0 + 115.0° / 92.0 + 148.0° Efficiency 91 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Z ES FWHM / FWTM 25.0 + 108.0° / 73.0 + 145.0° Efficiency 90 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SST-10-B130 FWHM / FWTM 114.0 + 28.0° / 147.0 + 70.0° Efficiency 93 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type Deep Red Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED RecLED 146x45mm 2900lm 730 2x6 IP G1 FWHM / FWTM 24.0 + 103.5° / 56.5 + 143.5° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW219D FWHM / FWTM 106.0 + 32.0° / 145.0 + 85.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW219F FWHM / FWTM 112.0 + 32.0° / 147.0 + 88.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED NVSW319B FWHM / FWTM 34.0 + 113.0° / 91.0 + 148.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW3x9A FWHM / FWTM 119.0 + 33.0° / 149.0 + 100.0° Efficiency 92 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW519A FWHM / FWTM 113.0 + 35.0° / 147.0 + 90.0° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED NVSxE21A FWHM / FWTM 26.0 + 116.0° / 107.0 + 145.0° Efficiency 91 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 31.0 + 116.0° / 100.0 + 149.0° Efficiency 90 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 114.0 + 32.0° / 148.0 + 93.0° Efficiency 91 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED Duris S8 FWHM / FWTM 111.0 + 38.0° / 148.0 + 121.0° Efficiency 92 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 110.0 + 29.0° / 146.0 + 86.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square EC FWHM / FWTM 30.0 + 108.0° / 87.0 + 145.0° Efficiency 91 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED OSLON Square PC FWHM / FWTM 30.0 + 111.0° / 91.0 + 146.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON SSL 80 FWHM / FWTM 26.0 + 92.0° / 81.0 + 143.0° Efficiency 93 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Fortimo FastFlex LED 2x6 DP G4 FWHM / FWTM 32.0 + 116.0° / 91.0 + 149.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED Fortimo FastFlex LED 2x6 DP G5 FWHM / FWTM 108.0 + 29.0° / 145.0 + 72.0° Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Fortimo FastFlex LED 2x6 DP HE FWHM / FWTM 106.0 + 37.0° / 146.0 + 110.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Fortimo FastFlex LED 2x6 DPX G4 FWHM / FWTM 33.0 + 119.0° / 100.0 + 150.0° Efficiency 92 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED HiLOM RH12 (LH351C) FWHM / FWTM 107.0 + 32.0° / 145.0 + 85.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED HiLOM RM12 ZP (LH502C) FWHM / FWTM 107.0 + 37.0° / 146.0 + 111.0° Efficiency 93 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH351Z FWHM / FWTM 29.0 + 104.0° / 70.0 + 144.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED BALAM-VP-5250-750-36 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED BALAMEC-VE-5700-740-36 FWHM / FWTM 107.0 + 35.0° / 145.0 + 100.0° Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED ROY-S26XPL2 (XP-L2) FWHM / FWTM 116.0 + 36.0° / 150.0 + 98.0° Efficiency 93 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED XLE-S22C4XTEHE (XT-E HE) FWHM / FWTM 112.0 + 29.0° / 147.0 + 85.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XLE-S26XHP35 (XHP35 HD) FWHM / FWTM 118.0 + 38.0° / 151.0 + 103.0° Efficiency 91 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SMJQ-D36W12Mx FWHM / FWTM 30.0 + 119.0° / 128.0 + 149.0° Efficiency 91 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED SMJQ-D36W12Px FWHM / FWTM 121.0 + 32.0° / 151.0 + 108.0° Efficiency 92 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M1/Z5M2 FWHM / FWTM 29.0 + 105.0° / 79.0 + 145.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M3 FWHM / FWTM 32.0 + 111.0° / 96.0 + 148.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED Z8Y22 FWHM / FWTM 30.0 + 119.0° / 128.0 + 149.0° Efficiency 91 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z8Y22P FWHM / FWTM 122.0 + 32.0° / 151.0 + 111.0° Efficiency 92 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED TL1L4 FWHM / FWTM 29.0 + 107.0° / 88.0 + 144.0° Efficiency 87 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (MEASURED): LED RLE 2x6 3000lm HP EXC2 OTD FWHM / FWTM 108.0 + 29.0° / 146.0 + 82.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (SIMULATED): LED J Series 5050 Round LES FWHM / FWTM 29.0 + 96.0° / 50.0 + 141.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 HE FWHM / FWTM 103.0 + 28.0° / 144.0 + 42.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 34.0 + 96.0° / 61.0 + 141.0° Efficiency 93 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (SIMULATED): LED LUXEON 5050 Square LES FWHM / FWTM 30.0 + 98.0° / 52.0 + 141.0° Efficiency 95 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NV4WB35AM FWHM / FWTM 100.0 + 28.0° / 140.0 + 42.0° Efficiency 95 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW3x9A FWHM / FWTM 103.0 + 25.0° / 142.0 + 44.0° Efficiency 91 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (SIMULATED): LED PrevaLED Brick HP IP 2x6 FWHM / FWTM 24.0 + 97.0° / 36.0 + 141.0° Efficiency 95 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ P 3030 FWHM / FWTM 92.0 + 14.0° / 141.0 + 28.0° Efficiency 95 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ P 3737 (2W version) FWHM / FWTM 32.0 + 100.0° / 44.0 + 142.0° Efficiency 95 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 24/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 3737 (3W version) FWHM / FWTM 27.0 + 100.0° / 44.0 + 143.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ P 3737 Flat FWHM / FWTM 96.0 + 22.0° / 140.0 + 36.0° Efficiency 96 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH502D FWHM / FWTM 30.0 + 98.0° / 52.0 + 140.0° Efficiency 96 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 25/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (SIMULATED): LED SEOUL DC 3528 FWHM / FWTM 20.0 + 99.0° / 36.0 + 142.0° Efficiency 94 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SEOUL DC 5050 6V FWHM / FWTM 97.0 + 29.0° / 142.0 + 49.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M4 FWHM / FWTM 24.0 + 98.0° / 34.0 + 136.0° Efficiency 96 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 26/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O OPTICAL RESULTS (SIMULATED): LED Z8Y22T FWHM / FWTM 97.0 + 21.0° / 141.0 + 32.0° Efficiency 94 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 27/28 PRODUCT DATASHEET CS14597_HB-IP-2X6-O GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 15/04/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 28/28
CS14597_HB-IP-2X6-O 价格&库存
很抱歉,暂时无法提供与“CS14597_HB-IP-2X6-O”相匹配的价格&库存,您可以联系我们找货
