F14532_ANGELETTE-S
F14532_ANGELETTE-S
    LEDIL(芬兰)
    REFLECTOR ROUND 1 POS 110MM (D)
F14532_ANGELETTE-S 数据手册
PRODUCT DATASHEET F14532_ANGELETTE-S ANGELETTE-S ~10° spot beam SPECIFICATION: Dimensions Ø 110.0 mm Height 57.3 mm Fastening socket ROHS compliant yes MATERIALS: Component Type Material Colour ANGELETTE-S Reflector PC metal Finish Coating HMDS ORDERING INFORMATION: Component F14532_ANGELETTE-S » Box size: 398 x 298 x 265 mm Qty in box 180 MOQ MPQ 90 45 Box weight (kg) 7.4 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/36 PRODUCT DATASHEET F14532_ANGELETTE-S See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED V10 Gen7 FWHM / FWTM 11.0° / 31.0° Efficiency 85 % Peak intensity 6.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 F13671_ANGE-RZ-LENS Bender Wirth: 434 Typ L1 LED V10 Gen7 FWHM / FWTM 8.5° / 20.0° Efficiency 89 % Peak intensity 11 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 486 Typ L1 LED V13 Gen7 FWHM / FWTM 12.0° / 29.0° Efficiency 91 % Peak intensity 7 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213254-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED V13 Gen7 FWHM / FWTM 14.0° / 40.0° Efficiency 86 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213254-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED V22 Gen6 FWHM / FWTM 19.0° / 64.0° Efficiency 90 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2204-CT + 50-2100AN LED V22 Gen6 FWHM / FWTM 21.0° / 71.0° Efficiency 85 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS IDEAL: 50-2204-CT + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED Vero SE 13 FWHM / FWTM 11.0° / 26.0° Efficiency 90 % Peak intensity 7.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16402_CLAMP-VEROSE-13-18 LED Vero SE 18 FWHM / FWTM 16.0° / 39.0° Efficiency 90 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16402_CLAMP-VEROSE-13-18 LED VERO13 FWHM / FWTM 11.0° / 25.0° Efficiency 90 % Peak intensity 8.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED VERO18 FWHM / FWTM 15.0° / 38.0° Efficiency 90 % Peak intensity 4.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 LED VERO29 FWHM / FWTM 27.0° / 76.0° Efficiency 90 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13584_CLAMP-VERO29 LED Vesta TW 15mm DP FWHM / FWTM 15.0° / 38.0° Efficiency 87 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13658_CLAMP-VERO13-18 F13671_ANGE-RZ-LENS Bender Wirth: 482 Typ L2 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED Vesta TW 15mm DP FWHM / FWTM 13.0° / 29.0° Efficiency 92 % Peak intensity 6.9 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 482 Typ L2 LED Vesta TW 18mm (31W) DP FWHM / FWTM 17.0° / 51.0° Efficiency 87 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13584_CLAMP-VERO29 F13671_ANGE-RZ-LENS Bender Wirth: 483 Typ L3 LED Vesta TW 18mm (31W) DP FWHM / FWTM 16.0° / 38.0° Efficiency 92 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13584_CLAMP-VERO29 Bender Wirth: 483 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED Vesta TW 22mm DP FWHM / FWTM 20.0° / 64.0° Efficiency 87 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13584_CLAMP-VERO29 F13671_ANGE-RZ-LENS Bender Wirth: 494 Typ L3 LED Vesta TW 22mm DP FWHM / FWTM 18.0° / 47.0° Efficiency 92 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13584_CLAMP-VERO29 Bender Wirth: 494 Typ L3 LED CLL03x/CLU03x FWHM / FWTM 13.0° / 33.0° Efficiency 89 % Peak intensity 6 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2103CT + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED CLL03x/CLU03x FWHM / FWTM 15.0° / 44.0° Efficiency 85 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS IDEAL: 50-2103CT + 50-2100AN LED CLL03x/CLU03x FWHM / FWTM 14.0° / 35.0° Efficiency 89 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16791_CLAMP-Z45-A F13671_ANGE-RZ-LENS TE Connectivity: 2325807-3 LED CLL03x/CLU03x FWHM / FWTM 15.0° / 41.0° Efficiency 85 % Peak intensity 4.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213254-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED CLL03x/CLU03x FWHM / FWTM 13.0° / 31.0° Efficiency 90 % Peak intensity 6.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213254-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED CLL03x/CLU03x FWHM / FWTM 12.0° / 27.0° Efficiency 93 % Peak intensity 7.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16791_CLAMP-Z45-A TE Connectivity: 2325807-3 LED CLL04x/CLU04x FWHM / FWTM 19.0° / 65.0° Efficiency 90 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2204-CT + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED CLL04x/CLU04x FWHM / FWTM 21.0° / 71.0° Efficiency 85 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS IDEAL: 50-2204-CT + 50-2100AN LED CLU730/731/733 FWHM / FWTM 12.0° / 30.0° Efficiency 89 % Peak intensity 6.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2204-CT + 50-2100AN LED CLU730/731/733 FWHM / FWTM 14.0° / 41.0° Efficiency 85 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS IDEAL: 50-2204-CT + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED CMA1840 FWHM / FWTM 12.0° / 29.0° Efficiency 91 % Peak intensity 6.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14123_CLAMP-CXA15-18 LED CMA2550 FWHM / FWTM 16.0° / 43.0° Efficiency 91 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14036_CLAMP_CXA25-30 LED CMT14xx FWHM / FWTM 9.0° / 21.0° Efficiency 91 % Peak intensity 10.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 434 Typ L1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED CMT19xx FWHM / FWTM 12.0° / 31.0° Efficiency 91 % Peak intensity 6.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 477 Typ L1 LED CMT28xx FWHM / FWTM 19.0° / 61.0° Efficiency 90 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13584_CLAMP-VERO29 Bender Wirth: 471 Typ L3 LED CXA/B 15xx FWHM / FWTM 8.0° / 20.0° Efficiency 90 % Peak intensity 12 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14123_CLAMP-CXA15-18 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 11.0° / 26.0° Efficiency 91 % Peak intensity 8.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213130-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 13.0° / 35.0° Efficiency 86 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213401-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 11.0° / 25.0° Efficiency 90 % Peak intensity 8.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14123_CLAMP-CXA15-18 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED CXA/B 25xx FWHM / FWTM 15.0° / 38.0° Efficiency 90 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14036_CLAMP_CXA25-30 LED CXA/B 30xx FWHM / FWTM 19.0° / 55.0° Efficiency 90 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14036_CLAMP_CXA25-30 LED LUXEON CoB 1204/1205 FWHM / FWTM 13.0° / 33.0° Efficiency 87 % Peak intensity 5.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15412_ANGELETTE-DL TE Connectivity: 2213130-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1204/1205 FWHM / FWTM 12.0° / 28.0° Efficiency 88 % Peak intensity 6.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15176_ANGELETTE-LENS TE Connectivity: 2213130-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED LUXEON CoB 1204/1205 FWHM / FWTM 12.0° / 28.0° Efficiency 90 % Peak intensity 7.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213130-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED LUXEON CoB 1204HD FWHM / FWTM 8.5° / 21.0° Efficiency 90 % Peak intensity 10.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213382-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1205HD FWHM / FWTM 10.0° / 25.0° Efficiency 90 % Peak intensity 8.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213382-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED LUXEON CoB 1208 FWHM / FWTM 16.0° / 48.0° Efficiency 85 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS IDEAL: 50-2100SH + 50-2100AN LED LUXEON CoB 1208 FWHM / FWTM 13.0° / 35.0° Efficiency 89 % Peak intensity 5.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2100SH + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1208 FWHM / FWTM 15.0° / 41.0° Efficiency 85 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213130-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED LUXEON CoB 1208 FWHM / FWTM 13.0° / 31.0° Efficiency 89 % Peak intensity 6.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213130-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED LUXEON CoB 1211 FWHM / FWTM 17.0° / 48.0° Efficiency 89 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2204-CT + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1211 FWHM / FWTM 18.0° / 62.0° Efficiency 86 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS IDEAL: 50-2204-CT + 50-2100AN LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 21.0° / 71.0° Efficiency 86 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS IDEAL: 50-2204-CT + 50-2100AN LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 20.0° / 68.0° Efficiency 89 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2204-CT + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED CDM-14 (Dim-To-Warm) FWHM / FWTM 12.0° / 31.0° Efficiency 87 % Peak intensity 6.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 F13671_ANGE-RZ-LENS Bender Wirth: 491 Typ L2 LED CDM-14 (Dim-To-Warm) FWHM / FWTM 11.0° / 24.0° Efficiency 91 % Peak intensity 9.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 491 Typ L2 LED CDM-18 (Dim-To-Warm) FWHM / FWTM 15.0° / 36.0° Efficiency 87 % Peak intensity 5.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 F13671_ANGE-RZ-LENS Bender Wirth: 491 Typ L2 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED CDM-18 (Dim-To-Warm) FWHM / FWTM 14.0° / 30.0° Efficiency 92 % Peak intensity 6.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 491 Typ L2 LED CDM-9 (Dim-To-Warm) FWHM / FWTM 11.0° / 28.0° Efficiency 84 % Peak intensity 7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 F13671_ANGE-RZ-LENS Bender Wirth: 490 Typ L1 LED CDM-9 (Dim-To-Warm) FWHM / FWTM 8.4° / 20.0° Efficiency 89 % Peak intensity 11.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 490 Typ L1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED CTM-14 (Tunable White) FWHM / FWTM 11.0° / 24.0° Efficiency 92 % Peak intensity 9.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13584_CLAMP-VERO29 Bender Wirth: 442 Typ L3 LED CTM-14 (Tunable White) FWHM / FWTM 12.0° / 30.0° Efficiency 87 % Peak intensity 6.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13584_CLAMP-VERO29 F13671_ANGE-RZ-LENS Bender Wirth: 442 Typ L3 LED CTM-14 RGBW FWHM / FWTM 10.0° / 24.0° Efficiency 90 % Peak intensity 9.4 cd/lm LEDs/each optic 1 Light colour/type RGBW Required components: C13584_CLAMP-VERO29 Bender Wirth: 500 Typ L3-1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED CTM-14 RGBW FWHM / FWTM 12.0° / 33.0° Efficiency 86 % Peak intensity 6 cd/lm LEDs/each optic 1 Light colour/type RGBW Required components: C13584_CLAMP-VERO29 F13671_ANGE-RZ-LENS Bender Wirth: 500 Typ L3-1 LED CTM-22 (Tunable White) FWHM / FWTM 19.0° / 63.0° Efficiency 84 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13584_CLAMP-VERO29 F13671_ANGE-RZ-LENS Bender Wirth: 494 Typ L3 LED CTM-22 (Tunable White) FWHM / FWTM 18.0° / 52.0° Efficiency 88 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13584_CLAMP-VERO29 Bender Wirth: 494 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED COB J-Type FWHM / FWTM 13.0° / 35.0° Efficiency 91 % Peak intensity 5.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2103NC + 50-2100AN LED COB J-Type FWHM / FWTM 16.0° / 49.0° Efficiency 86 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS IDEAL: 50-2103NC + 50-2100AN LED COB L-Type (LES 11) FWHM / FWTM 13.0° / 37.0° Efficiency 84 % Peak intensity 5.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS IDEAL: 50-2100NC + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 24/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED COB L-Type (LES 11) FWHM / FWTM 10.0° / 23.0° Efficiency 90 % Peak intensity 9.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213382-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED COB L-Type (LES 11) FWHM / FWTM 10.0° / 26.0° Efficiency 89 % Peak intensity 8.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2100NC + 50-2100AN LED NVCWJ024Z-V1MT: COB J-Type Tunable White FWHM / FWTM 12.0° / 32.0° Efficiency 85 % Peak intensity 6.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 F13671_ANGE-RZ-LENS Bender Wirth: 498 Typ L2 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 25/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED NVCWJ024Z-V1MT: COB J-Type Tunable White FWHM / FWTM 10.0° / 23.0° Efficiency 90 % Peak intensity 9.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 498 Typ L2 LED PrevaLED Core G7 L15 H1 FWHM / FWTM 15.0° / 37.0° Efficiency 89 % Peak intensity 5.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16685_CLAMP-PRV-A F13671_ANGE-RZ-LENS LED PrevaLED Core G7 L15 H1 FWHM / FWTM 13.0° / 29.0° Efficiency 93 % Peak intensity 6.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16685_CLAMP-PRV-A Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 26/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED PrevaLED Core Z4 LES19 FWHM / FWTM 16.0° / 48.0° Efficiency 86 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: OPTIC CLIP Z50 TYPE1 2213194-1 LED PrevaLED Core Z4 LES19 FWHM / FWTM 14.0° / 36.0° Efficiency 90 % Peak intensity 5.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: OPTIC CLIP Z50 TYPE1 2213194-1 LED Soleriq S13 19x19 FWHM / FWTM 14.0° / 39.0° Efficiency 84 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS IDEAL: 50-2103CT + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 27/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED Soleriq S13 19x19 FWHM / FWTM 12.0° / 29.0° Efficiency 89 % Peak intensity 7 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2103CT + 50-2100AN LED Soleriq S13 19x19 FWHM / FWTM 11.0° / 26.0° Efficiency 89 % Peak intensity 7.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213254-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED Soleriq S13 19x19 FWHM / FWTM 13.0° / 34.0° Efficiency 85 % Peak intensity 5.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213254-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 28/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED Soleriq S13 19x19 FWHM / FWTM 12.0° / 29.0° Efficiency 89 % Peak intensity 7 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2103CT + 50-2100AN LED Soleriq S19 FWHM / FWTM 16.0° / 47.0° Efficiency 85 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213407-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED Soleriq S19 FWHM / FWTM 14.0° / 36.0° Efficiency 90 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213407-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 29/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED Fortimo SLM L13 CoB FWHM / FWTM 12.0° / 29.0° Efficiency 91 % Peak intensity 6.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213130-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED Fortimo SLM L13 CoB FWHM / FWTM 14.0° / 39.0° Efficiency 85 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213130-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED Fortimo SLM L15 + SLM holder FWHM / FWTM 13.0° / 32.0° Efficiency 89 % Peak intensity 6 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 30/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED Fortimo SLM L15 CoB FWHM / FWTM 15.0° / 43.0° Efficiency 85 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213130-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED Fortimo SLM L15 CoB FWHM / FWTM 15.0° / 43.0° Efficiency 85 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213130-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED LC035T (Tunable white) FWHM / FWTM 18.0° / 46.0° Efficiency 92 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13584_CLAMP-VERO29 Bender Wirth: 502 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 31/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED LC035T (Tunable white) FWHM / FWTM 20.0° / 62.0° Efficiency 87 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C13584_CLAMP-VERO29 F13671_ANGE-RZ-LENS Bender Wirth: 502 Typ L3 LED LC040C FWHM / FWTM 10.0° / 24.0° Efficiency 90 % Peak intensity 8.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213382-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED LC040C FWHM / FWTM 12.0° / 32.0° Efficiency 86 % Peak intensity 6 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: 2213382-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 32/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED AC Zhaga COB FWHM / FWTM 14.0° / 41.0° Efficiency 85 % Peak intensity 4.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS Optosource: SEHSMJD-A LED MJT COB LES 14.5 FWHM / FWTM 14.0° / 33.0° Efficiency 89 % Peak intensity 5.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: 2213254-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED MJT COB LES 22 FWHM / FWTM 19.0° / 63.0° Efficiency 88 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13584_CLAMP-VERO29 Bender Wirth: 431 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 33/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (MEASURED): LED WU-M-484 FWHM / FWTM 13.0° / 36.0° Efficiency 85 % Peak intensity 5.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS TE Connectivity: OPTIC CLIP Z50 TYPE1 2213194-1 LED WU-M-484 FWHM / FWTM 12.0° / 29.0° Efficiency 89 % Peak intensity 7.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: TE Connectivity: OPTIC CLIP Z50 TYPE1 2213194-1 LED XTM - 19mm LES FWHM / FWTM 15.0° / 37.0° Efficiency 91 % Peak intensity 5.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16491_XTM-ADAPTER-50-A Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 34/36 PRODUCT DATASHEET F14532_ANGELETTE-S OPTICAL RESULTS (SIMULATED): LED V13 Gen7 FWHM / FWTM 12.0° / 26.0° Efficiency 92 % Peak intensity 8 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2103CT + 50-2100AN LED V13 Gen7 FWHM / FWTM 11.0° / 22.0° Efficiency 92 % Peak intensity 10.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 477 Typ L1 LED V22 Gen7 FWHM / FWTM 14.0° / 34.0° Efficiency 94 % Peak intensity 5.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2204-CT + 50-2100AN Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 35/36 PRODUCT DATASHEET F14532_ANGELETTE-S GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 36/36
F14532_ANGELETTE-S 价格&库存
很抱歉,暂时无法提供与“F14532_ANGELETTE-S”相匹配的价格&库存,您可以联系我们找货
