F14563_JENNY-T4
F14563_JENNY-T4
    LEDIL(芬兰)
F14563_JENNY-T4 数据手册
PRODUCT DATASHEET F14563_JENNY-T4 JENNY-T4 IESNA Type IV light distribution for wider roads and large outdoor areas. Variant with wire channels on the sides enabling compatibility with small COBs. SPECIFICATION: Dimensions Height Fastening ROHS compliant 35.0 x 35.0 17 mm glue, pin yes MATERIALS: Component Type Material Colour JENNY-T4 Single lens Silicone clear Finish Length 35.0 ORDERING INFORMATION: Component F14563_JENNY-T4 » Box size: 480 x 280 x 300 mm Qty in box 1020 MOQ MPQ 2040 1020 Box weight (kg) 8.8 Last update: 20/12/2023 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/9 PRODUCT DATASHEET F14563_JENNY-T4 See also our general installation guide: www.ledil.com/installation_guide Last update: 20/12/2023 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET F14563_JENNY-T4 OPTICAL RESULTS (MEASURED): LED V10 Gen6 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED V8 Gen6 FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CLL02x/CLU02x (LES10) FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 20/12/2023 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET F14563_JENNY-T4 OPTICAL RESULTS (MEASURED): LED CXA/B 15xx FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED MK-R FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED MX-6 FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 20/12/2023 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET F14563_JENNY-T4 OPTICAL RESULTS (MEASURED): LED XHP70 FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XM-L EZW FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON M/MX FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 20/12/2023 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET F14563_JENNY-T4 OPTICAL RESULTS (MEASURED): LED CxM-9 (13.5x13.5) FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LC003D / LC006D / LC009D / LC013D FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED MJT COB LES 6 FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 20/12/2023 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET F14563_JENNY-T4 OPTICAL RESULTS (MEASURED): LED MJT COB LES 9.8 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 20/12/2023 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET F14563_JENNY-T4 OPTICAL RESULTS (SIMULATED): LED V10 Gen7 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ P 7070 FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 20/12/2023 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET F14563_JENNY-T4 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 20/12/2023 Subject to change without prior notice Published: 10/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
F14563_JENNY-T4 价格&库存
很抱歉,暂时无法提供与“F14563_JENNY-T4”相匹配的价格&库存,您可以联系我们找货
