F14618_ANGELETTE-WW-B
    LEDIL(芬兰)
    REFLECTORROUND1POS110MM(D)
F14618_ANGELETTE-WW-B 数据手册
PRODUCT DATASHEET F14618_ANGELETTE-WW-B ANGELETTE-WW-B ~60° wide beam compatible with BJB and B+W connectors SPECIFICATION: Dimensions Ø 110.0 mm Height 57.3 mm Fastening socket ROHS compliant yes MATERIALS: Component Type Material Colour ANGELETTE-WW-B Reflector PC metal Finish Coating ORDERING INFORMATION: Component F14618_ANGELETTE-WW-B » Box size: 398 x 298 x 265 mm Qty in box 120 MOQ MPQ 90 30 Box weight (kg) 5.2 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/14 PRODUCT DATASHEET F14618_ANGELETTE-WW-B See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/14 PRODUCT DATASHEET F14618_ANGELETTE-WW-B OPTICAL RESULTS (MEASURED): LED V15 Gen6 FWHM / FWTM 66.0° / 88.0° Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS BJB: 47.319.2224 LED V15 Gen6 FWHM / FWTM 65.0° / 83.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.2224 LED V18 Gen6 FWHM / FWTM 65.0° / 88.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS BJB: 47.319.2274 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/14 PRODUCT DATASHEET F14618_ANGELETTE-WW-B OPTICAL RESULTS (MEASURED): LED V18 Gen6 FWHM / FWTM 64.0° / 83.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.2274 LED V18 Gen7 FWHM / FWTM 64.0° / 83.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.2350 LED V22 Gen6 FWHM / FWTM 63.0° / 84.0° Efficiency 87 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: A.A.G. STUCCHI: 8102-G2 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/14 PRODUCT DATASHEET F14618_ANGELETTE-WW-B OPTICAL RESULTS (MEASURED): LED V22 Gen6 FWHM / FWTM 64.0° / 88.0° Efficiency 83 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS A.A.G. STUCCHI: 8102-G2 LED CLL03x/CLU03x FWHM / FWTM 63.0° / 82.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: A.A.G. STUCCHI: 8101-G2 LED CLL03x/CLU03x FWHM / FWTM 65.0° / 87.0° Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS A.A.G. STUCCHI: 8101-G2 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/14 PRODUCT DATASHEET F14618_ANGELETTE-WW-B OPTICAL RESULTS (MEASURED): LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 62.0° / 81.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: A.A.G. STUCCHI: 8403/G2 LED CXA/B 25xx FWHM / FWTM 63.0° / 83.0° Efficiency 88 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: A.A.G. STUCCHI: 8401-G2 LED LUXEON CoB 1208 FWHM / FWTM 63.0° / 82.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: A.A.G. STUCCHI: 8301-G2 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/14 PRODUCT DATASHEET F14618_ANGELETTE-WW-B OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1208 FWHM / FWTM 63.0° / 82.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: A.A.G. STUCCHI: 8301-G2 LED LUXEON CoB 1208 FWHM / FWTM 66.0° / 87.0° Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS A.A.G. STUCCHI: 8301-G2 LED Fortimo SLM L19 CoB FWHM / FWTM 63.0° / 83.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.2030 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/14 PRODUCT DATASHEET F14618_ANGELETTE-WW-B OPTICAL RESULTS (MEASURED): LED Fortimo SLM L19 CoB FWHM / FWTM 65.0° / 87.0° Efficiency 84 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS BJB: 47.319.2030 LED Fortimo SLM L23 CoB FWHM / FWTM 64.0° / 88.0° Efficiency 84 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS BJB: 47.319.2030 LED Fortimo SLM L23 CoB FWHM / FWTM 62.0° / 84.0° Efficiency 88 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.2030 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/14 PRODUCT DATASHEET F14618_ANGELETTE-WW-B OPTICAL RESULTS (MEASURED): LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 66.0° / 88.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS A.A.G. STUCCHI: 8101-G2 LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 65.0° / 83.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.2021 LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 66.0° / 88.0° Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F13671_ANGE-RZ-LENS BJB: 47.319.2021 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/14 PRODUCT DATASHEET F14618_ANGELETTE-WW-B OPTICAL RESULTS (MEASURED): LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 65.0° / 83.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: A.A.G. STUCCHI: 8101-G2 LED SLE G7 LES15 FWHM / FWTM 63.0° / 82.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.2021 LED SLE G7 LES17 H FWHM / FWTM 59.0° / 81.0° Efficiency 88 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/14 PRODUCT DATASHEET F14618_ANGELETTE-WW-B OPTICAL RESULTS (MEASURED): LED SLE G7 LES21 H FWHM / FWTM 61.0° / 82.0° Efficiency 88 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XOB 14.5 mm FWHM / FWTM 64.0° / 82.0° Efficiency 91 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.2021 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/14 PRODUCT DATASHEET F14618_ANGELETTE-WW-B OPTICAL RESULTS (SIMULATED): LED CLL03x/CLU03x FWHM / FWTM 54.0° / 80.0° Efficiency 89 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.2021 LED CLL04x/CLU04x FWHM / FWTM 58.0° / 81.0° Efficiency 88 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.2030 LED LC040D / LC060D / LC080D FWHM / FWTM 60.0° / 81.0° Efficiency 87 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: BJB: 47.319.2030 Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/14 PRODUCT DATASHEET F14618_ANGELETTE-WW-B OPTICAL RESULTS (SIMULATED): LED SLE G7 LES21 H FWHM / FWTM 56.0° / 78.0° Efficiency 84 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15412_ANGELETTE-DL Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/14 PRODUCT DATASHEET F14618_ANGELETTE-WW-B GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 02/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/14
物料型号为 F14618_ANGELETTE-WW-B。
该产品是 LEDiL 公司生产的光学透镜,兼容 BJB 和 B+W 连接器,具有约 60° 的宽光束角度。
产品尺寸为直径 110.0 毫米,高度 57.3 毫米,并且符合 ROHS 标准。
材料方面,反射器由 PC 材料制成,颜色为金属色。
引脚分配封装信息在文档中没有明确提及,但文档提到了与不同 LED 型号配合使用的透镜和连接器组件,例如 F13671_ANGE-RZ-LENS 和 A.A.G. STUCCHI 系列连接器。
参数特性包括不同 LED 型号的光效、峰值强度和光分布。
例如,使用 LED V15 Gen6 的配置具有 66.0°/88.0° 的 FWHM/FWTM 角度和 85% 的效率。
功能详解部分描述了光学结果,包括不同 LED 型号的光分布文件和效率,以及所需的组件。
应用信息指出,该产品适用于需要宽光束角度的应用场景,并建议特别注意适当的热设计,因为使用了高功率 COB。
最后,文档包含了 LEDiL 公司的联系信息和版权声明,强调了材料和产品规格可能会在不通知的情况下更改。
F14618_ANGELETTE-WW-B 价格&库存
很抱歉,暂时无法提供与“F14618_ANGELETTE-WW-B”相匹配的价格&库存,您可以联系我们找货
    • 30+72.6797330+9.42068
