F17194_LINDA-WW2
F17194_LINDA-WW2
    LEDIL(芬兰)
F17194_LINDA-WW2 数据手册
PRODUCT DATASHEET F17194_LINDA-WW2 LINDA-WW2 ~90° + 100° wide beam SPECIFICATION: Dimensions Height ROHS compliant 25.7 x 1140.0 mm 5.3 mm yes MATERIALS: Component Type Material Colour LINDA-WW2 Linear lens PMMA milky Finish ORDERING INFORMATION: Component F17194_LINDA-WW2 » Box size: 1185 x 150 x 115 mm Qty in box 160 MOQ MPQ 160 160 Box weight (kg) 11.4 Last update: 13/12/2023 Subject to change without prior notice Published: 23/08/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/10 PRODUCT DATASHEET F17194_LINDA-WW2 See also our general installation guide: www.ledil.com/installation_guide Last update: 13/12/2023 Subject to change without prior notice Published: 23/08/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/10 PRODUCT DATASHEET F17194_LINDA-WW2 OPTICAL RESULTS (MEASURED): LED SMD 3030 (BXEM) FWHM / FWTM 97.5 + 87.0° / 159.5 + 139.5° Efficiency 85 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour Tunable White Required components: LED CLUC11 FWHM / FWTM 98.0 + 85.0° / 156.0 + 143.0° Efficiency 85 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 104.0 + 92.0° / 163.0 + 170.0° Efficiency 84 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED PL-LIN-Z5 1100 280x20 FWHM / FWTM 97.0 + 86.0° / 159.0 + 135.0° Efficiency 82 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/12/2023 Subject to change without prior notice Published: 23/08/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/10 PRODUCT DATASHEET F17194_LINDA-WW2 OPTICAL RESULTS (MEASURED): LED PL-LIN-Z5 2000 280x20 FWHM / FWTM 97.0 + 84.0° / 158.0 + 135.0° Efficiency 79 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris E 2835 FWHM / FWTM 97.0 + 84.0° / 158.0 + 135.0° Efficiency 79 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris E 2835 FWHM / FWTM 97.0 + 86.0° / 159.0 + 135.0° Efficiency 82 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ E 2835 FWHM / FWTM 97.0 + 87.0° / 158.0 + 140.0° Efficiency 86 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour Tunable White Required components: Last update: 13/12/2023 Subject to change without prior notice Published: 23/08/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/10 PRODUCT DATASHEET F17194_LINDA-WW2 OPTICAL RESULTS (MEASURED): LED Fortimo LED Strip 1ft 1100lm FC HV4 & LV4 FWHM / FWTM 97.0 + 86.0° / 158.0 + 136.0° Efficiency 82 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo LED Strip 1ft 1100lm FC HV5 & LV5 FWHM / FWTM 97.0 + 86.0° / 159.0 + 143.0° Efficiency 87 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo LED Strip 1ft 650lm FC HV4 & LV4 FWHM / FWTM 97.0 + 86.0° / 158.0 + 135.0° Efficiency 83 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo LED Strip 1ft 650lm FC HV5 & LV5 FWHM / FWTM 97.0 + 86.0° / 158.0 + 142.0° Efficiency 87 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/12/2023 Subject to change without prior notice Published: 23/08/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/10 PRODUCT DATASHEET F17194_LINDA-WW2 OPTICAL RESULTS (MEASURED): LED LT-H282C FWHM / FWTM 98.0 + 87.0° / 158.0 + 143.0° Efficiency 88 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LT-Q282A FWHM / FWTM 97.0 + 87.0° / 158.0 + 141.0° Efficiency 87 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LT-S282H FWHM / FWTM 97.0 + 87.0° / 159.0 + 143.0° Efficiency 89 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LLE 24x280mm 1250lm HV ADV5 FWHM / FWTM 98.0 + 86.0° / 158.0 + 138.0° Efficiency 82 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/12/2023 Subject to change without prior notice Published: 23/08/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/10 PRODUCT DATASHEET F17194_LINDA-WW2 OPTICAL RESULTS (MEASURED): LED LLE 24x280mm 650lm HV ADV5 FWHM / FWTM 98.0 + 86.0° / 159.0 + 137.0° Efficiency 82 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/12/2023 Subject to change without prior notice Published: 23/08/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/10 PRODUCT DATASHEET F17194_LINDA-WW2 OPTICAL RESULTS (SIMULATED): LED Bridgelux SMD 5050 FWHM / FWTM 93.0 + 86.0° / 134.0 + 116.0° Efficiency 82 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON CSP HL1 FWHM / FWTM 98.0 + 83.0° / 140.0 + 109.0° Efficiency 88 % Peak intensity 0.5 cd/lm LEDs/each optic 5 Light colour White Required components: LED NFSWE11A FWHM / FWTM 96.0 + 84.0° / 180.0 + 117.0° Efficiency 83 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LM561B Plus FWHM / FWTM 86.5 + 99.6° / 146.8 + 158.9° Efficiency 91 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/12/2023 Subject to change without prior notice Published: 23/08/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/10 PRODUCT DATASHEET F17194_LINDA-WW2 OPTICAL RESULTS (SIMULATED): LED SEOUL DC 3030 FWHM / FWTM 94.0 + 86.0° / 134.0 + 114.0° Efficiency 84 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED SEOUL DC 5050 6V FWHM / FWTM 90.0 + 84.0° / 132.0 + 114.0° Efficiency 82 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/12/2023 Subject to change without prior notice Published: 23/08/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/10 PRODUCT DATASHEET F17194_LINDA-WW2 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/12/2023 Subject to change without prior notice Published: 23/08/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/10
F17194_LINDA-WW2 价格&库存
很抱歉,暂时无法提供与“F17194_LINDA-WW2”相匹配的价格&库存,您可以联系我们找货
F17194_LINDA-WW2
    F17194_LINDA-WW2
